Old 12-11-2014, 03:33 PM   #1
RatedZ
RatedZ's Avatar
Drives: Camaro SS
Trailing Arms / Toe Links Upgrade
Looking to do a little suspension upgrade and would like to start with some trailing arms and toe links. Looking at a few options but my question is how difficult are they to install and can they be done on stands in the garage? Any DIY guides to help out?
RatedZ is offline   Reply With Quote
Old 12-11-2014, 04:35 PM   #2
ActNup NY
ActNup NY's Avatar
Drives: 2011 1LT Black Camaro
I don't know the difficulty of installing them as I paid to have mines installed . But I did watched one of my boys installed his in front of his house on jack stands. I tell ya one thing it will be a very tight squeeze working like that GL !!
The DREAM is free... It's the HUSTLE that is sold seperately
ActNup NY is offline   Reply With Quote
Old 12-12-2014, 09:39 AM   #3
BigNate
BigNate's Avatar
Drives: 2010 Camaro 2SS/RS Supercharged
Doing mine tonight. I might make a video since I couldn't find any on youtube. "BMR"
2010 2SS/RS Magnuson Supercharged, Headers, Corsa Exhaust, CAI
BigNate is offline   Reply With Quote
Old 12-12-2014, 01:17 PM   #4
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
BMR provides good instructions. It's pretty strait forward, but you will have to drop the cradle a little bit to get the drivers side inner toe link bolt out. The outer trailing arm bushing in the knuckle can be a PITA as well, but it's definitely all doable on jack stands if you are mechanically inclined.
Best regards,
Tyler
888-308-6007
JDP Sales is offline   Reply With Quote
Old 12-17-2014, 04:28 PM   #5
Trentin24
Trentin24
Trentin24's Avatar
Drives: 2011 2SS/RS
What trailing arms are you going with? I went with BMR on my '10 V6. But not sure which ones for my '11 SS. I would like to stick with BMR though.
Trentin24 is offline   Reply With Quote
Old 12-17-2014, 08:02 PM   #6
RatedZ
RatedZ's Avatar
Drives: Camaro SS
I'm picking them up tomorrow when I swing by BMR. I ended up placing an order for:
DTB004 Tunnel Brace
SFC015 Subframe Conector
TR002 Toe Links
TCA026 Trailing Arms
Old 12-17-2014, 08:47 PM   #7
stratman2SSRS
stratman2SSRS's Avatar
Drives: Lingenfelter Camaro
The ZL1 toe links are as good as any aftermarket parts out there.
Just ask Pete.
stratman2SSRS is offline   Reply With Quote
Old 12-17-2014, 11:51 PM   #8
camarossdusk
whippled 5th gen
Drives: 2013 camaro ss
you will love how good it hooks once finished, I added the bmr toe rods, trailing arms, upper control arm bushings, and full cradle bushings. then just recently added the sb 039 rear sway bar, helped me out a lot but to me the biggest difference were the toe rods and trailing arms. I also have their tunnel brace and subframes. just make sure you get their trailing arm bushings
Whipple running 13 lbs of boost, Innovators west 8 rib with 10 percent over drive crankshaft pulley. Fore level 2 Dual pump fuel system, with duel TI auto fuel pumps, ID 1300 fuel injectors, tuned on e85. Driveshaft shop aluminum driveshaft, 1400 hp half shafts, Detroit tru-trac. ls9 camshaft, CNC ported heads, with trunion and dual valve spring upgrade, LS9 head gaskets, ARP 2000 head studs, Manley stainless valves. Adjustable Bmr toe rods, trailing arms, rear adjustable sway bar, full cradle bushings, upper control arm bushings, BMR diff. bushings, bmr driveshaft safety loop.
camarossdusk is offline   Reply With Quote
Old 12-18-2014, 07:30 AM   #9
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Just ask Pete.
No, just no.
Apex Motorsports is offline   Reply With Quote
Old 12-18-2014, 07:35 AM   #10
Spartan01
Spartan01's Avatar
Drives: Evil Eva, 2010 2SS LS3
Originally Posted by Apex Motorsports View Post
No, just no.
Ha! BURN!
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
Spartan01 is offline   Reply With Quote
Old 12-18-2014, 08:43 AM   #11
Apex Motorsports
Originally Posted by Spartan01 View Post
Ha! BURN!
It wasn't meant to be. I feel like he was being sarcastic but didn't know if other people would realize it.
Old 12-18-2014, 08:51 AM   #12
Spartan01
Spartan01's Avatar
It was still funny
Old 12-18-2014, 09:30 AM   #13
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Just ask Pete.
Yeah, I hope that was sarcasm!?!?!? For anybody who needs this explained, the ZL1 toe rods do have an improved bushing in both ends of the toe rod. It is more of a sealed ball-joint type connection, which is a definite improvement over the regular rubber bushings. However, the arm itself is still the same flimsy stamped steel arm that is used on any other Camaro, and it is still capable of unwanted deflection and twisting under heavy loads. There is certainly room for improvement with a set of good aftermarket toe rods, such as the TR002, TR003, or TR004!!!
Old 12-18-2014, 01:29 PM   #14
RatedZ
RatedZ's Avatar
Drives: Camaro SS
Got em today and the BMR stuff is top quality and make the stock stuff look like aluminum foil. Can't wait to get em installed. Best customer service and got a tour of the plant. Can't say enough on how awesome they are.
