Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 02-12-2014, 01:23 AM   #1
13ZL1BLove
Drives: 2013 Camaro ZL1
Spring Awakening
Hey guys so my Z has been sitting cozy and comfy since November. Car covered, fully detailed, exhaust wrapped up so nothing can get in and to help keep out cold ass air since I live 45 mins south of the Chi. She has been filled with 93 and fuel stabilizer. Since it's almost the middle of February she gets to come out soon. Should I just start her up and let her get fully warm or take it easy in a sense and break it back in on the tank. She has 6500 miles on her so recommendations would be appreciated.
thanks,
Brandon
2013 Summit White ZL1
13ZL1BLove is offline   Reply With Quote
Old 02-12-2014, 01:57 AM   #2
DavidW
Drives: 2013 ZL1 Vert Auto IOM
don't start it till you're gonna drive it
DavidW is offline   Reply With Quote
Old 02-12-2014, 03:29 AM   #3
13ZL1BLove
Yeah, I got that, just wondering if I should let it get warm and then I can drive the wheels off of it, or get it warm, then slightly break it back in.
Old 02-12-2014, 06:32 AM   #4
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
You should always let it get to operating temp before stomping on it. Also, the tires are likely flat spotted, especially if you didn't air them up before putting it away. Take it easy for the first few miles until that irons itself out.
Old 02-12-2014, 06:42 AM   #5
DavidW
I typically wait until the oil is at 100C or 212F as indicated by the four pack to drive hard, sometimes I may start geting into it as low at 70C or 158F (which isnt too bad, considering my cobalt turbo with the same oil weight would always keep its oil right aroumd at 180F / 80C)
If you are still in the break in and are choosing to follow gm's instructions then you shouldn't be driving it hard at all
Old 02-12-2014, 07:43 AM   #6
Whos_Drivin
Drives: '12 Camaro ZL1, '16 Silverado Z71
I let my car warm up for 10-15 minutes before driving out of storage. My logic is to let oil find its way throughout the engine again after sitting for 5 months. I'm not sure if it really helps, but I figure it can't hurt as long as I'm going to drive it.
2012 ZL1: M6, Rotofab CAI, ATI balancer w/8.66 overdrive, PFADT long tube headers w/cats
2016 Silverado LTZ-Z71 Midnight Edition: 6.2L, 8 speed auto, Borla exhaust
Whos_Drivin is offline   Reply With Quote
Old 02-12-2014, 08:23 AM   #7
sengli
sengli's Avatar
Drives: 2015commemorative vert 2SS
You know with affects of global warming, caused by supercharged V8's emissions....... spring will never come here in the northern US.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded
2015 commemorative vert 2ss
sengli is offline   Reply With Quote
Old 02-12-2014, 09:01 AM   #8
13ZL1BLove
I inflated my tires to I think 40-45 been a while since November. And the tires are on carpet squares as well. I usually let her get to 180-190 before it moves so maybe I'll wait until 200 degrees, get the oil nice and warm and back through the engine. I definitely will be using a can of sea foam with 93 octane after this tank with the stabilizer runs out.
Old 02-12-2014, 09:17 AM   #9
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
You guys are way over thinking it. Could you imagine the factory taking as long on a fresh engine before moving a car, we would never get our new builds.
SlingShot is offline   Reply With Quote
Old 02-12-2014, 11:08 AM   #10
Realist
Realist's Avatar
Drives: No Camaro :(
Your in luck Brandon, I'm in Lemont and will be happy to swing by as soon as we start hitting the 40 degree temps and wake it from hibernation free of charge of course. Don't start it till then.
Realist is offline   Reply With Quote
Old 02-12-2014, 11:16 AM   #11
ZED SLED
ZED SLED's Avatar
Hopefully they aren't trying to outdo each others 60' times on the lot.
Old 02-12-2014, 11:43 AM   #12
Jekyll-N-Hyde
I put the FU back in FUN
Jekyll-N-Hyde's Avatar
Drives: 1969 SS 396 , 2010 Camaro SS
Some of you are cracking me up lol If you are running the OEM oil weight then crank the car over give it time to idle down and then put it in gear and go. let the car warm up to normal opperating temp before you romp on it. Normal opperating temp at legal speed limit driving takes about 5/8 minutes to get to!
Just sitting there at idle for long periods of time does nothing but build condensation and etc in your mufflers. 5W30 circulates through your motor in the matter of maybe half a minute due to it being a 5 weight motor oil.
a car warms up faster while driving it rather than just sitting there idling.
If it makes you feel better give it maybe 2 minutes after winter storage to idle then go. The zddp/zinc protects the engine parts at start up no matter if it sits one day or 8 months. Once it cranks over the oil starts to fluctuate.
I run 15w50 and mine takes about 22 seconds to idle down after my seatbelt is on and everything else I need to do is done I go and just take it easy until the guage says its fully warmed up.
Jekyll-N-Hyde is offline   Reply With Quote
Old 02-12-2014, 05:23 PM   #13
Whos_Drivin
Just here for your amusement.
I bet you get more condensation in you muffler for longer periods when you wash your car than my 10 minute warm up period once a year.
Old 02-12-2014, 07:34 PM   #14
ss/rs/378
ss/rs/378's Avatar
Drives: 2012 ZL1 Camaro Victory Red
Hell I think it will be July before I can even think about firing mine up to much freaking snow around here dam it!!
2.55 UPPER PULLEY,100MM IDLER PULLEY,160 STAT,PORTED TB,PORTED SNOUT,MSD PLUG WIRES,NKG PLUGS,KENNE BELL EXTERNAL FUEL PUMP,2"KOOKS HEADERS,HIGH FLOW CATS,3"CORSA 60LB DEKA INJECTORS TUNED BY FROST 580RWHP,571RWTQ.
ss/rs/378 is offline   Reply With Quote
