Old 01-21-2014, 03:19 PM   #1
ALacorte515
ALacorte515's Avatar
Drives: 2016 2LT Vert
Deep Scratch Problem, Help please!
Unfortunatley I woke up one morning and it looked as though someone tried to break into my car via the key whole. The cover was partially off (thankfully didn't crack) and beneath it and slightly past it is a very deep scratch. (See Pictures)
I was wondering what should I do with this? I do not want it to cause rust. What is the best scratch filler and touch up paint to use in this situation?
ALacorte515 is offline   Reply With Quote
Old 01-21-2014, 03:29 PM   #2
SSTG
Drives: 2014 Z51 Corvette
Dr. ColorChip.
Good match and easy to use.
SSTG is offline   Reply With Quote
Old 01-21-2014, 03:34 PM   #3
24ZZZZZ
Drives: 2013 2SS/RS BLACK M6
Go to the dealership they offer touch up paint that will be the same paint code that your car was painted with. I would lightly wet sand the area and use the touch up paint, or you can have the door repainted through your insurance company and pay your deductible. The touch up paint will hide the scratch and prevent it from rusting. Its just a minor scratch, but if your like me, and just knowing its there will bother me till I repaint the door. A good painter can repaint just that area but will have to clear the entire door.FYI Good luck!
24ZZZZZ is offline   Reply With Quote
Old 01-21-2014, 03:53 PM   #4
ALacorte515
Thanks for the help!
Old 01-21-2014, 05:10 PM   #5
SSTG
You will have better results with the DCC as a novice.
If you know how to wet sand then you can go the other way as suggested.
Old 01-21-2014, 08:36 PM   #6
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
Originally Posted by SSTG View Post
Dr. ColorChip.
+1
Sent from my HTC One using Tapatalk 2
[B]
CamaroDreams07 is offline   Reply With Quote
Old 01-21-2014, 08:37 PM   #7
CamaroDreams07
Drives: Slow V6
Agreed. I'll never understand people advising others to wetsand. If the OP had any business wet sanding, he wouldn't have to ask the question.
That's not a knock on you OP, just in general.
[B]
Old 01-21-2014, 09:26 PM   #8
charlietuna
charlietuna's Avatar
Drives: 2013 ZL1
Call the dealership or a Chevy dealership in your area and ask them who they use for their preowned cars touch up work. We have a company in Chicago called carnica. Many of these places have mobile services and shops that you can bring your camaro to. This is all they do and they do excellent work.
This is an alternative I would investigate prior to purchasing a do it yourself kit or having the entire door repainted.
I have a few rock chips on the front of my car and I will be using Carnica to touch them up prior to doing some film protection that I should have done the day I bought my car.
Laus Deo
charlietuna is offline   Reply With Quote
Old 01-22-2014, 10:02 AM   #9
CamaroRyan
CamaroRyan's Avatar
Drives: 11' Camaro LS (Black)
is Dr. Color Chip better than those little paint repair kits sold at Discount Auto Parts?
CamaroRyan is offline   Reply With Quote
Old 01-22-2014, 10:06 AM   #10
SSTG
Yes. The touch up pens at AP stores glob up easily and aren't easy to work with.
DCC has great paint applicators and the access paint is easily removed with the solution they include in their kits.
For a DIY repair, it can't be beat.
Old 01-22-2014, 10:23 AM   #11
CamaroRyan
CamaroRyan's Avatar
I used a touch up pen for a couple scatches i had. the paint difference is pretty noticable. (black). would the DCC do a better job? could i use it over the current job?
Old 01-22-2014, 10:47 AM   #12
SSTG
I want to state I have no affiliation with Dr. ColorChip. I own a Detailing company and have used it several times.
That being stated, I have noticed very good paint matches with DCC.
As far as going over a previous repair, I would remove the old paint, clean the area with paint thinner/ wax grease remover and apply DCC.
You will have a longer lasting repair this way.
Old 01-22-2014, 11:01 AM   #13
CamaroRyan
CamaroRyan's Avatar
Thank you for your help
Old 01-22-2014, 11:31 AM   #14
24ZZZZZ
All the info suggested in this forum are suggestions, no need to knock ones answer or suggestions! Ive noticed alot of that in this forum.
