dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 10-14-2013, 08:12 PM   #1
JackalopeZL1
JackalopeZL1's Avatar
Drives: 2013 ZL1
Rear end howl on decel
Hi again..lol 950 miles now.. Just went through a tug of war to get me pulling problem fixed.. Seems good so far after 2 front tires. Now for my next issue. The rear end howls on decel. How many have had issues? Not taking back to the same dealer after the experience I just had with them. Will finish breaking it in then take it back to the dealer I bought it from. Just wondering how many people have some rind and pinion noise?
2013 Silver ZL1
JackalopeZL1 is offline   Reply With Quote
Old 10-14-2013, 08:38 PM   #2
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
I believe whine on decel is backlash to tight. Whine on accel the backlash is too loose.
Bryan 2018 ZL1 M6
ZO6 Bryan is offline   Reply With Quote
Old 10-15-2013, 01:26 AM   #3
djnice
djnice's Avatar
Drives: 13 ZL1 SIM, 99 Z28 Black
Mine has a whine on decel when in the 60 to 70 mph range. It happens when slightly letting up from nuetral throttle. I am not sure what can be done about it.
2018 C7 Z06 - WGG, M7. / 2013 ZL1 - SIM, 6 spd, RotoFab CAI, Can. / 1999 Z28 - Black, 6 spd, K&N, Subframe. / More Fun Stuff - www.inlandspeed.com
djnice is offline   Reply With Quote
Old 10-15-2013, 07:25 AM   #4
oldfriend
Drives: Fiat 500 E
Just wonder if you got your's from a Davis st dealer ?."
oldfriend is offline   Reply With Quote
Old 10-15-2013, 11:13 AM   #5
Sven59
HAMMER PILOT
Sven59's Avatar
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado
Try doing some figure 8s in a parking lot, if you get the sound there also it it probably needs the service bulletin performed.
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
Sven59 is offline   Reply With Quote
Old 10-15-2013, 11:27 AM   #6
JackalopeZL1
Drives: 2013 ZL1
Yea, Figure 8's won't do anything for a ring and pinion set up issue.. If I was having noise from the limited slip I would
2013 Silver ZL1
Old 10-15-2013, 11:28 AM   #7
JackalopeZL1
Drives: 2013 ZL1
No. Got it at Maita in Elkgrove ca.. They are not the folks who did the previous warranty work. Am out of town so Had to go to a local dealer where I am working
2013 Silver ZL1
Old 10-15-2013, 11:30 AM   #8
Sven59
HAMMER PILOT
Sven59's Avatar
A lot of the noise seems to come from the clutch packs. They replaced my ring and pinion because the backlash was off but that didn't clear the noise. After they performed the service bulletin it went away.
Old 10-15-2013, 11:42 AM   #9
JackalopeZL1
Drives: 2013 ZL1
the noise I am having is a ring and pinion noise.. Been setting up rear end gears for over 25 years.. Clutch Packs will never make noise in a straight line
2013 Silver ZL1
Old 10-15-2013, 11:46 AM   #10
Sven59
HAMMER PILOT
Sven59's Avatar
Hence why they do the figure 8's for the service bulletin, good luck it took me three trips to resolve it. It seems they have two different issues going.
Old 10-15-2013, 11:52 AM   #11
JackalopeZL1
Drives: 2013 ZL1
Yep.. figure eights again will do nothing for a ring and pinion noise. Hence that is why I have said all along it is a ring and pinion noise.. Hopefully I get a service writer and tech who are compitant the first time and will see the obvious noise for what it is.. I think they will.. Thinking positive
2013 Silver ZL1
Old 10-15-2013, 09:41 PM   #12
GAZL1
Drives: 2013 ZL1
Jackalope you're not alone!
Definition of "Irony"...owner of driveline shop for over 20 years...has set up over a thousand differentials...orders a brand new ZL1 and gets one with one of the noisiest ring and pinions I have ever heard coming out of the factory!
The car made noise from mile one! Heard it the first time I drove it. Of course, if it makes noise, the only two things you are guaranteed is that it will either stay the same or get worse...they never get better. Car currently has about 1800 miles on it.
Jackalope is right...ring and pinion "whine" or "howl" is not to be confused with "figure eight chatter" or a "growl" when tuning. Gear noise has been somewhat prevalent with the manual cars from what I've been told. There is another member on this forum that didn't get a quiet set of gears until his third set. I'm lucky, one of my old employees is a tech at a GM dealership and I'm going to have him replace my gear set under warranty...he knows what he's doing! I'm probably not going to do it until spring as the car is getting close to being pickled for the winter.
I'll be curious to see how yours gets handled.
Good luck!
GAZL1 is offline   Reply With Quote
Old 10-15-2013, 09:57 PM   #13
ZO6 Bryan
ZO6 Bryan's Avatar
Pinion nut also might be loose. Ring and pinion pull themselves together on decel. And on accel the ring gear is trying to be pushed out the rear. If the nut is loose it will set tight in the bearing race on accel but try to be pulled into the ring on decel.
Bryan 2018 ZL1 M6
Old 10-16-2013, 12:11 AM   #14
djnice
djnice's Avatar
I am trying to figure yout if mine is the same thing. Do you guys hear this at all speeds? Does harder and lighter decel make the noise change?
