Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum
Old 01-29-2013, 02:12 AM   #1
c5dreamer
Drives: Tacoma/2LTRS
Just saw this at ********.com
/Users/Cava/Desktop/int12jblb.JPG
For those of you that have the side corner box, how do you like it?
c5dreamer is offline   Reply With Quote
Old 01-29-2013, 02:20 AM   #2
tramtwo
tramtwo's Avatar
Drives: 2021 1LE
Damn that's fine!
tramtwo posted this on the go
tramtwo is offline   Reply With Quote
Old 01-29-2013, 07:15 AM   #3
Steve@Subthump
Drives: 2011 2SS IOM Vert
I see you found our new integrated kit. Same box as always, just using jbl now that kicker has become a sell-out to big box stores only. The great thing about the JBL gear is that it is actually better stuff for the same money as the kicker gear were using previously. That jbl amp is 500w rms, whereas the kicker amp in the old kit was 400w.
[IMG]http://********.com/images/int12jbla.JPG[/IMG]
Steve@Subthump is offline   Reply With Quote
Old 01-29-2013, 07:53 AM   #4
Bad@ssCamaro
BeckyD Rocks :-)
Bad@ssCamaro's Avatar
Drives: 2015 1SS/1LE
JBL was the shizzle back in the day. I think this is going on the mod list.
2015 CRT 1SS/1LE RS/Recaro's/NPP/Nav/Rear vision pkg./BA speaker upgrade. Stage 3 BMR cam, ARH 1 7/8 headers, CAI,
BMR 1.25 drop springs, JPSS Billet Bushings, Peddars Cradle Bushings...460 whp...so far....SOLD, but not forgotten!
Bad@ssCamaro is offline   Reply With Quote
Old 01-29-2013, 08:33 AM   #5
Moriartii
Moriartii's Avatar
Drives: 11 IOM 2SS/RS M6 w/Hurst
Steve-
Could you offer that with an option of JL Audio? Can you get JL Audio stuff?
Cheers
K
Moriartii is offline   Reply With Quote
Old 01-29-2013, 08:34 AM   #6
Mikes SS
Mikes SS's Avatar
Drives: '10 CGM 2SS/RS 6M
you're not worried about over-heating the amp in this set-up? I see there is a rectangular hole where the fins are, but that just doesn't seem to be enough?
Mikes SS is offline   Reply With Quote
Old 01-29-2013, 08:58 AM   #7
LineofPerfection
LineofPerfection's Avatar
Drives: 2010 2SS Camaro "Big Blue"
I personally like the old Infinity set-up. My amp has never over heated with this set-up.
Big Blue
LineofPerfection is offline   Reply With Quote
Old 01-29-2013, 09:02 AM   #8
Moriartii
Moriartii's Avatar
I suspect that is a D-class amp which is much cooler than an A or A/B amp.
Cheers
K
Old 01-29-2013, 09:12 AM   #9
Steve@Subthump
Should run cool I'd say. The kickers never gave us any problems and most of their fins were completely behind the cover. I contemplated on different cover designs and thought that one looked best, having only the controls and fins exposed.
Old 01-29-2013, 09:23 AM   #10
DuskSS
Bayou City Muscle Cars
DuskSS's Avatar
Drives: 2013 2SS Dusk Edition
is that just the "sub" amp or is that the 5 channel replace for all?
and how much trunk does this actually take and number 3 can this be setup to be easily removed for trips when I need ALL of the trunk.
Lethal Racing Stage V
PER 418ci Forged LS3
530/520 SAE
DuskSS is offline   Reply With Quote
Old 01-29-2013, 10:37 AM   #11
Sapper12b
HTCC Member
Sapper12b's Avatar
Drives: 2013 Camaro SS
Looks interesting , I would probably do this with a 5 channel amp
Sapper12b is offline   Reply With Quote
Old 01-29-2013, 11:08 AM   #12
Steve@Subthump
This particular amp is the 500w mono sub amp. The 5ch amp is too large to fit unfortunately. The nice thing about having only the sub amp in the box and not a 5ch is that if you do take it out, you still have the rest of your system intact. But yeah it is really easy to remove. Disconnect the power, ground, and rca cable and pull it out. The amp has an auto turn-on feature so you don't even need to connect a remote wire. These amps are really nice to work with since the controls are right on top and easy to see and extremely uncomplicated.
Old 01-29-2013, 11:12 AM   #13
DuskSS
DuskSS's Avatar
Thanks Steve!
Looking forward to getting one very shortly.
530/520 SAE
Old 01-29-2013, 12:52 PM   #14
Steve@Subthump
An amp swap using the xd400/4 and this kit for bass would be a lot better than any 5 channel system.
