09-20-2023, 11:30 AM | #29 |
I was just going by what you had posted for wheel/tire weights before: stock wheel/tire 62 lbs, vms/hoosier 32 lbs, vms/mt 52 lbs. Saving 30 ea on front and 10 ea on rear added up to 80.
09-20-2023, 12:08 PM | #30 |
Drives: 2022 Camaro LT1 A10 Join Date: Nov 2015
FWIW here's my notes from my weight notepad. I weighed everything myself.
WHEELS+TIRES Stock 20x8.5 black carbon flash wheel + stock 245 40 20 run flat tire = 60LBS VMS 18x5 wheel 21lbs + Hoosier 28x4.5x18 13lb = 34lbs VMS 17x10 wheel 22lbs + Mickey Thompson RT ST R 305 45 17 31lbs = 53lbs Savings per wheel front 26lbs Savings per wheel rear 7lbs Total savings = 66lbs The weights are within 1-2lbs of what I have seen from Don and others.
2022 Camaro LT1 A10 - Drag Pack/AxleBack -11.849@118.67MPH/1.798 60' 2001 Camaro SS A4 - HCI/Stall/Bolt-on/Gear/Tune/DR/Diet - 429HP/392TQ - 10.99@123.58MPH/1.584 60' 1998 Camaro Z28 A4 - Bolt-on 1999 Camaro Z28 A4 - Stock FJB |
09-20-2023, 02:03 PM | #31 |
Here's where the drag pack weight figures in my post came from, posts from lt4camaro (previous owner of your drag pack):
Stock and skinnies here https://www.camaro6.com/forums/showthread.php?t=612258 Rears here https://www.camaro6.com/forums/showt...=603483&page=5 Even at the lower figure of 66 that your scale is reading Dynamical, that would still be a decent reduction in rolling weight. |
09-20-2023, 03:03 PM | #32 | |
I plan on going back in mid/late Oct to grab some negative Density altitude
09-20-2023, 07:14 PM | #33 |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
That is where the discrepancy is, the OE tires/wheels where approx 57 lbs each when I put them on a bathroom scale. My error reporting that before I weighed them.
10-21-2023, 10:19 PM | #34 |
Drives: Camaro 1SS 2024, Camaro Z28 2000 Join Date: Aug 2023
Completely Stock ? Really.....Check out these numbers
2024 1SS A10 Completely stock is Goodyear Eagle F1 SUMMER ONLY run flat tires. 37 psi tire pressure. 1500 miles and a couple oil changes.
10-22-2023, 05:27 PM | #35 |
