09-01-2023, 01:06 AM | #1 |
Drives: Chevy Camaro 2SS Join Date: Oct 2020
Built SS 800whp 1/4 time guess.
I have a built 19 SS with A10 tranny that I just got built about a month ago. I am taking it to the track next weekend and wanted to see what kind of times I should expect. Tranny is tuned/ D1X on 15psi/ meth/ BTR intake/ lt4 fuel system. I will be rolling on 20s 1le with 555r2 in the rear. Like stated, I am 800whp on pump with meth, 890whp with C16.
2019 2SS D1X/CAM/METH/DROP-INS 800whp on 93/ 890whp/670tq C16
09-01-2023, 07:07 AM | #2 |
Under ideal conditions, mid-high 9s at mid 140s? If i had to put a number on it 9.7@143?
Thats a barely educated guess. I think 700 whp gets you dipping in the high 9s at low 140s, and 1000whp gets you into middle 9s (around 9.4 to 9.6 or so).... Now lets let the folks who ACTUALLY know stuff talk
09-01-2023, 07:09 AM | #3 |
Just realized you have a D1X... do you have a stall conv? Otherwise, you are going to have to take a tenth or two off i think.
09-01-2023, 08:07 AM | #4 |
Drives: Chevy Camaro Join Date: Sep 2022
On 20's and no mention of converter, I'm saying mid to low 10's in the 140's mph.
'20 Camaro LT1
Twin 67/62 turbo 401(L8t) Texas speed forged piston & rod, BTR stg1 turbo cam, holley ultra lo, port injection, circle d 3600 stall, hoosier bias ply quick time pro's on racestar recluse wheels 1.45 4.01 6.07@120.74 9.28@153.43 '94 Camaro Z28 6mt cc306 cam, 4:10's, longtubes with x pipe, getting an engine rebuild |
09-01-2023, 08:18 AM | #5 |
Drives: 2016 Camaro SS Join Date: Oct 2021
I would say mid 10's, betting traction is going to be an issue.
I have learned from experience having the power to run 9's on paper is not the same as actually putting down that power effectively. Though with the D1x and no converter it will not hit as hard off the line so you might not have the traction issues I have. Good luck.
2016 Camaro 2SS 759whp 686wtq tuned by KingLt1
Procharger D1SC - Diamond Pistons/Manley Rods BTR stage 3 cam - Circle D converter American Racing headers - Borla S-type |
09-01-2023, 10:00 AM | #6 |
rcoe has a very good point, dyno sheet saying '9-second car' does not translate to 9-sec timeslips in MANY cases. SO many times I have seen cars run slower or even much slower ETs than they should. Setup and driving technique need to be sorted out if quick ETs are desired.
My suggestion is to have fun, and try to learn what works for your car. Tech requirements mean that you should bring a Snell 2015+ Helmet and an SFI 3.2A/1 race jacket. Helmet is for running under 14sec, and SFI jacket is for adding a supercharger (also required under 11.5sec), these are NHRA tech requirements. Not sure how your tech guys will be, but I have seen locally a driver who had installed a Procharger on a Coyote stuck in tech, and they would not pass him until he was able to borrow a jacket. |
09-01-2023, 11:30 AM | #7 |
BAMF SS
10.2 - 10.3 @ 143
You won't be able to get out of the hole, at all, unless you are the stig You have the power, but none of the other stuff that makes for an efficient ET.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
09-01-2023, 01:56 PM | #8 |
I seen cars really moving at the track and most not having jackets. Sometimes running with no helmets. I always wore mine but don't have a jacket. Next upgrade will be drag pack, maybe stall converter depending on how much I want to chase 9s. I have seen zl1 do 9s with just headers, intake and E.
09-02-2023, 06:26 AM | #9 |
Without a converter and running a ProCharger I'd say 10.40@144. My Camaro makes 707 and ran 9.80@142.96 but its a Maggie with THPSI port injection and it doesn't need a converter to launch as boost is instant. My 16ss with a 2650 with over 850 rwhp ran 9.41@147 but once again with a PD blower and instant boost, with the right stall converter mid 9s should be achievable but not on a 20" drag radial or street tire. Gonna have to go to a 17" drag radail or slick
09-02-2023, 06:29 AM | #10 | |
09-02-2023, 07:02 AM | #11 |
I just went back and looked at my 9.80 pass and I was at full boost (177 kpa) in just under 3/4 second on the launch. Wish someone would post a Centri with no converter for a comparison, that would be interesting or even with a converter. Not a dragy, but track pass.
09-02-2023, 07:14 AM | #12 | |
What cam are you running?
09-02-2023, 07:41 AM | #13 |
Only responding because Dan doesn't post here much...I believe his time in sig was with the stock long block and cam.
2016 NFG 1SS A8
09-02-2023, 09:52 AM | #14 |
Didn't see the cam, he's got a good running ride for sure. Brett seems to tune those ProChargers as well as anyone. I know you have some fast ones out there also.
