TireRack
Old 10-31-2020, 06:16 PM   #1
Axe55
Drives: 2012 Camaro SS
Broken spring - replace both or one?
So this isn't related to my Camaro, but my winter beater (2013 Jetta) hit a pothole and broke the front driver's side spring. The car has 65k miles on it, and I don't want to put any money into it (need the $$ for the Camaro). Can I replace just the spring on the driver's side or if I'm putting a new spring on that side should I do the passenger's side too? Thanks folks.
2012 Camaro SS LS3, JRE Scoop, CAI intake, Whipple Supercharger, Fast 85lb injectors, ZL1 pump, McLeod RXT clutch, MGW shifter, Stainless Power 1 7/8 headers w/HFC, Ridetech coilovers, BMR sway bars, trailing arms, toe rods, cradle bushing inserts, 2020 Speed Tuned.
Axe55 is offline   Reply With Quote
Old 10-31-2020, 06:21 PM   #2
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
Would make sense to replace them both but, start with just the one that broke and if the ride feels ok...call it good. As you said, you don’t want to put money into it.
0stones0 is offline   Reply With Quote
Old 10-31-2020, 06:43 PM   #3
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
Pretty sure if you go with auto parts store replacement parts they sell them in pairs. I can't imagine some Moog type replacements would be that expensive.
Sent from my SM-G973U using Tapatalk
Firefighter is offline   Reply With Quote
Old 10-31-2020, 08:37 PM   #4
KillboyPowerhead
Drives: 2015 Z/22
As mentioned I'd just do the one spring if this is a beater and you want to spend as little as possible. Being a VW I wouldn't even want to do that, but I guess you already have it...
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
KillboyPowerhead is offline   Reply With Quote
