Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Tuning / Diagnostics -- engine and transmission
Old 01-07-2019, 09:36 AM   #1
bub
Drives: '17 1SS 1LE & '15 Corvette Z06
2010 L99 P219A Cylinder Imbalance Bank 1
Has anyone solved this Code P219A or B (Cylinder Imbalance Bank 1 [A] or 2 [B])? Searched but saw no definitive solutions.
2010 SS with L99 auto. 143k miles.
Thus far I have done & observed the following:
* Cleaned air filter - still throwing code
* Searched for vacuum leaks - no finds - still throwing code
* Swapped left and right front heated O2 sensors to see if code would switch banks - it did not - stayed with left bank 1, so assume O2 fine
* Swapped left and right fuel injectors, again to see if code would switch banks - it did not - stayed with left bank 1, so assume injectors are fine - they looked clean. O ring seals checked for vacuum leaks, some seem "loose".
* Installed new plugs left bank 1 - still throwing P219A code after about 30+ miles.
Freeze data when code is set is usually 70+ mph, seems like prolly when DoD is disabling V4 and going back to V8 mode.
Next step is to tune out AFM/DoD altogether and see if it still throws it.
bub is offline   Reply With Quote
Old 04-02-2019, 03:08 AM   #2
John_C
LSx FTW!!!
John_C's Avatar
Drives: 2010 Camaro 2SS RS
Ever figure this out?
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X
Circle D 3400 Triple Disc
Kooks Jet Hot Headers
Kooks Full 3in exhaust
Trick Flow GenX 255's
Polished PAC .660's & Ti-retainers
TSP VVT 3.2 cam kit w/DoD Delete
Smith Bro's Trunnion kit
AEM X-Series OBDII Widebands
FIC ID1300x Injectors
GM ZL1 High Output Fuel Pump
DSX Tuning Flex Sensor
DSX Auxiliary Fuel System
Tim King Stage 4 Max Effort CTSV 6L90
DSS 1 piece aluminum driveshaft
JRE 6L80E / 6L90E Dipstick
NGK Iridium IX spark plugs #7 heat range
Mighty Mouse Camaro 5 Wild w/-12an and Billet Black
HP Tuners VCM Suite
John_C is offline   Reply With Quote
Old 04-03-2019, 11:52 PM   #3
Pro-tuned
Angewendet Ingenieur
Pro-tuned's Avatar
Drives: 14 Camaro ZL1
Pull down your cats and check them...
LQ9, Iron Block, Forged internals, 408CI, Jannetty custom cam, TS short block, Whipple, Hardened Jackshaft, PRC 260, 2X3 Dynatech Full Competition, HF Cats, CAI, NW 103, Chee, ID 1300, COPO Breather, MSD, Fore Dual Pump, ultratorque, E85, dual Meth, True Trac, 3:45, 1500hp axle-shafts, DSS CF, BMR, custom Pearl/Candy paint by Jaidah.
Pro-tuned is offline   Reply With Quote
Old 06-18-2020, 02:25 PM   #4
wasthatacop?
wasthatacop?'s Avatar
Drives: 2010 2SS
.. same problem here.
Driving home on freeway and a P219A code popped up on my 2010 Camaro SS. I had the local Chevy dealership supply and install a crate engine (same L99 6.2 L) at 93,000 miles. Im currently at 139,000 miles. No engine mods. Nothing seems out of order while it's running.
"bub", did you ever figure this problem out?
2010 2SS living in Los Angeles
replaced engine @ 93,000 miles w/ crate engine, camshaft by Comp Cams installed by me, replaced valve train parts,
1.4" BMR lowering springs
ZL1 factory rims
misc: drilled and slotted rotors, fresh air brake cooling system, new speakers, installed reverse camera, muffler delete
wasthatacop? is offline   Reply With Quote
