Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Dragstrip and Launch Techniques Discussion
Old 03-09-2018, 06:38 PM   #1
PlatinumIce
WILD CANADIAN HEARTBEAT
PlatinumIce's Avatar
Drives: 2014 2SS 1LE RS, 2014 ZL1& 2024 ZL1
27.5” front skinny, 29” rear . Any issues down the track
Any body these size tires on the 1/4 mile track. Any issues with the diameter sizes. Want to know before I order some tires.
700/633 91Octane Street Tune=750/670 VP109 Race Tune TVS2300 Heartbeat SC,ADM Dual Fuel Pumps/ Module, BRM lowered 1", performance rotors, hawks pads, SS Braided lines, GT-14cam, 78mm pulley, AR LT Headers, Cat Deletes, Borla S catback, tinted, 1/LE emblems, 65lb Injectors, Elite catch can,dual valve springs, titanium retainers, super conductor wires and insulators, Robo Fab CAI, Oversize intercooler reservoir, Oracle ghost side markers, Black out Bowties & SS,ZL1 splash guards, Michelin PSS. Built and tuned by Davenport Motorsports (WILD1LE)
PlatinumIce is offline   Reply With Quote
Old 03-09-2018, 06:58 PM   #2
PlatinumIce
According to website skinny is 27,8” and rear is 28.8” so 3.48% diameter difference?
Old 03-10-2018, 01:30 PM   #3
robrocketanski
robrocketanski's Avatar
Drives: ZL1 Convertible Auto
I have mainly seen people say no more than half an inch difference otherwise it sets ABS but I don't know the limits
LS3 intake and throttle body, Huron Speed Products twin turbo with 6265 oil less turbos, and 3" header back, JRE smooth cam, ID1300, Fore dual 450lph pumps with MSD voltage booster, A6, 305/45/17 MT Street R
robrocketanski is offline   Reply With Quote
Old 03-10-2018, 02:04 PM   #4
PlatinumIce
I am 3% different on my street tires and zero issues.
Old 03-11-2018, 09:10 PM   #5
KGoddard
KGoddard's Avatar
Drives: 2013 Camaro 2SS/RS
I'm running 27" in the front and 28" in the back and the computer was not a fan. Had to pull the fuses.
Sent from my Pixel using Tapatalk
12.3 @113MPH - Full Bolt-Ons w/ Nitto 555r on 18" wheel
KGoddard is offline   Reply With Quote
Old 03-11-2018, 09:26 PM   #6
PlatinumIce
Any issues racing down the track with fuses pulled?
Old 03-12-2018, 05:24 AM   #7
KGoddard
KGoddard's Avatar
It just turns off traction control and stability. You Just won't have abs, braking wasn't much different at all.
Old 03-13-2018, 06:47 AM   #8
Motorboy8769
Drives: 2015 2ss
I pulled fuses on mine spun just a hair on the launch and it knocked the rev limiter down to 5000 I was waiting for my shift light at 6200.... put them back and problem solved. I would prefer to have them pulled so I don’t have to disable traction control plus I liked the steering better. Idk how to fix that problem though
Motorboy8769 is offline   Reply With Quote
Old 03-13-2018, 11:36 AM   #9
WoodBoss
"Old School"
Drives: 2010 2SS L99
When I pulled fuses I could no longer do a burnout. Best to match tire sizes and not create new issues.
WoodBoss is offline   Reply With Quote
Old 03-13-2018, 12:22 PM   #10
KGoddard
KGoddard's Avatar
I haven't experienced anything like that. Shift light came on for me at the usual 6200 and she kept moving.
Old 03-13-2018, 02:00 PM   #11
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
I think the biggest difference people go is 3%. 285/35/20 and 315/35/20. You might be okay with your selections. Might. You a gambler?
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads.
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
Old 03-13-2018, 03:00 PM   #12
lazerlemonta
lazerlemonta's Avatar
Drives: 2010 C6 1LT
Tune out traction control for the drag strip. I ran 315/35/17 25" rears and stock fronts. Fuses pulled zero issues. Mine was a 2015
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85
Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE
10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake
Best 1/8 6.80@105.75
Best MPH 134.82
lazerlemonta is offline   Reply With Quote
Old 03-13-2018, 04:33 PM   #13
Motorboy8769
Drives: 2015 2ss
Have no clue why mine did what it did only if I spun a little bit. I don’t spin much when I launch. I wonder if you just disconnect the sensors if that would work better...???? No idea
Old 03-13-2018, 09:39 PM   #14
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
I have been racing with the fuses pulled for a couple years. Heck my ABS has not even worked for the last year I think we broke a sensor.
But 27 front and 29 rear will will most likely trigger ABS.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II
13.15@106 1.95 | 100% Stock
12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune
12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune
11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts
10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800
Pro Stock John is offline   Reply With Quote
