12-25-2017, 07:26 AM | #15 |
Drives: 2014 2SS blue Join Date: Jun 2016
My understanding of the purpose of either drilled or slotted rotors, is to allow the superheated gasses, which form between the pad and the rotor surface, to vent. It supposedly prevents the gasses from floating the pads. A dimple does not allow escape of the gasses.
12-26-2017, 07:26 AM | #16 |
Drives: 2014 2SS/RS 1LE Join Date: Aug 2017
I'd honestly stick with the stock brembo rotors. From friends that track their cars they tell me that as long as you have a decent vented rotor, you can use upgraded pads with a fluid change, season them and you're ready to tear up the track as far as stopping power goes. Here is a track prep guide that should translate over to a 5th gen if I'm not mistaken. https://my.chevrolet.com/content/dam...tion-guide.pdf
2014 2SS/RS 1LE Blacked Out
12-26-2017, 04:20 PM | #17 | |
Drives: Camaro Justice Join Date: Jun 2007
12-26-2017, 08:45 PM | #18 |
LT4 M6
Drives: 2018 ZL1 1LE Join Date: Nov 2010
I realize its a different animal. But the grandsport corvette has drilled rotors from the factory. Atleast thats how my dads 2017 vette came. Wonder why they are so bad?
12-27-2017, 07:31 AM | #19 |
'Maro
Drives: 2015 SS 6.2L Auto 2SS Join Date: Sep 2016
Thanks!
2015 SS 2SS Auto 93 SCT Perf, Kooks LTH & HFC MBRP Axleback Muffler Delete "Z/28" Spoiler and Grille OEM ZL1 wheels 285/305/35R20 BFG G-force Pro Comp 2
01-03-2018, 10:25 AM | #20 | |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
Each hole drilled in a brake rotor represents a location where the stresses from thermal expansion are intensified. This is mainly a fatigue situation where many low-stress cycles can be withstood but far fewer high-stress cycles. Each cycle is a "thermal transient event", and I used to do a little thermal transient analysis and quite a lot of fatigue evaluations back when I had a day job (not automotive-related, but the principles are the same). There was a time when venting pad off-gassing was the more critical need, when pad formulations weren't what they are now. I remember a couple of cars that only half a dozen snubs from about 70 down to 40 in quick succession was enough to fade the brakes into near-worthlessness. I don't think you can even find a new car that bad any more. Norm
'19 WRX 6M (the family sedan . . . seriously) |
01-03-2018, 12:44 PM | #21 |
Drives: 2014 Camaro 2SS 1LE NPP Join Date: Nov 2013
Simply search for "cracked rotors". Now, many of what's pictured are blanks, but that's expected as only track-guys tend to crack rotors (outside of neglect, abuse, or accident) and track guys tend to use blanks.
But take note of where the cracks on drilled rotors start: https://www.google.com/search?q=roto...=lnms&tbm=isch
My thoughts on some things:
01-03-2018, 12:59 PM | #22 |
Drives: 2014 Camaro LS / 13 zl1 Join Date: May 2016
I have Stop-tech drilled & slotted rotors on my '14 LS , but I don't track or drag race with it, I have no issues with them . Only reason I got them was I liked the look of them.
