Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 08-06-2014, 02:51 PM   #29
My Caroline
My Caroline's Avatar
Drives: Black 2011 Camaro LS
Bump.
White Fender Hashes from Big Worm Graphix with Custom White Bowties
GM Factory Remote Start and Factory Key Fob
SS Fascia, Factory RS HIDs, Plasma P13W fog lights
Non-RS to RS and fog light harness by Gen5DIY
LED Interior, Trunk, and Licence Plate lights in white
ZL1 Spoiler with Gen5DIY harness
Factory NPP cat back
Blacked out tail light bezels
Factory 20 inch wheels wrapped in Nitto Motivos
Lowered 1.25inch on Eibach Pro springs
My Caroline is offline   Reply With Quote
Old 08-09-2014, 07:41 AM   #30
My Caroline
Car goes in Thursday. I'll keep you posted.
Old 08-09-2014, 08:01 AM   #31
Towlie
Towlie's Avatar
Drives: 2013 2SS/RS L99
i have a SS and when i bought it in florida they had crappy 87 in it. every time i started it hot/warm it would give a knock on start up like that. I changed gas to 93 after that tank was gone and reset the fuel tables and....presto, start up knock gone!
Towlie is offline   Reply With Quote
Old 08-10-2014, 01:02 AM   #32
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Interesting.
Old 08-26-2014, 06:00 PM   #33
My Caroline
Well y'all, she's back.
And I have an answer.
As it turns out, the choke on the start up was caused by "excessive carbon build up" on the throttle body. The tech took apart, cleaned, reassembled and relearned the idle. THIS LAST STEP IS IMPORTANT. Over time the carbon on the throttle body caused the throttle to relearn a new position.
NOW, normally I would say this all sounds like bull.... But it worked.
And its only crazy if it doesn't work.
I have been driving the car for a week now just to be sure before I posted, and so far, i have not had one start up issue.
On to the cause of the build up...
bad gas quality.
Now, due to no fault of mine, all the gas where i was out at school was crap gas. I had no choices.
Now that I have transferred schools, I am able to get the good stuff.
Good Luck to anybody else experiencing the issue. Maybe you can tell your dealer where to start.
Old 08-26-2014, 07:18 PM   #34
RobertRS
RobertRS's Avatar
Drives: 2014 2SS L99
I'm wondering how low grade gas would cake up a throttle body on a direct injected engine? Maybe the poor fuel quality caused the rings to gum up which led to excessive blow by and hence ended up on the throttle body. Maybe a good cylinder decarb would be in order as a follow up to the throttle body cleaning.
RobertRS is offline   Reply With Quote
Old 08-26-2014, 08:48 PM   #35
My Caroline
Not sure, but everything is going smoothly. It used to do that every, single, time
I would imagine it has something to do with the "catch can" territory.
Old 08-26-2014, 10:47 PM   #36
PQ
Booooosted.
PQ's Avatar
Cool to know what the issue was.
I was going to say the same thing as RobertRS. Gas should not ever get on the TB. The port injection is too far downstream.
Catch can vapor is PCV so it wouldn't get on the TB either.
It's the 'clean' side crank case venting vapor getting on it. Along with anything that bypasses your air filter. You'll have to just clean the TB every year or so or, correct, buy a clean side catch can.
Old 08-27-2014, 04:24 PM   #37
TommyTheCat
SHKE BKE
TommyTheCat's Avatar
Drives: 2013 Camaro
It is not because of bad gas quality, it is because you need a catch can. These 3.6L engines have excessive blow-by
See here
http://www.camaro5.com/forums/showthread.php?t=374218
TommyTheCat is offline   Reply With Quote
wrong subforum
