Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 07-23-2014, 01:46 PM   #29
RobertRS
RobertRS's Avatar
Drives: 2014 2SS L99
One of the primary things I didn't care for when I test drove a 2014 LS3 1LE was the clutch feel. Firm for the first half of travel and then the bottom half almost falls to the floor. Anyway, if GM was to relocate something it should have been the DIC menu button on the L99 automatics. Try and hit that thing on the go without bumping the downshift paddle.
RobertRS is offline   Reply With Quote
Old 07-23-2014, 03:23 PM   #30
The Flash
The Flash's Avatar
Drives: Firebird 95, Equinox 05, Camaro 2SS
DITTO
Originally Posted by Da Mammer View Post
I went the opposite direction. I actually added the Lingenfelter return spring on top of the stock.
I just installed my LINGENFELTER return spring this past sunday.
I only experienced cluth return-failure issues twice since delivery of the car ('bout 4 years ago). Had driven it very aggresively but no further issues in the last two years.
Yet having extremely low mileage (I just got to 8,500 mi two weeks ago) I decided to install it just to be on the safe side.
Just noticed a slightly increased effort on initial push and a bit firmer return on the last inch and a half of travel up.
I do not know a reason to take the OEM spring out.
Safe driving,
The Flash
The Flash is offline   Reply With Quote
Old 07-23-2014, 11:09 PM   #31
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
One thing I noticed while swapping in a manual trans from an automatic is that when I installed the clutch pedal that the factory spring flips near the bottom of the travel, and actually holds down the pedal. ive been thinking about swapping it out to the lingenfelter spring, but haven't yet. I can feel the factory spring in the pedal when I depress the clutch.
as far as removing the spring causing the throwout bearing to go bad, anyone who has had the transmission out of their car knows that there is a big spring under the green cover putting pressure behind the throwout bearing, which keeps the bearing in contact with the clutch fingers at all times.
I had issues with the clutch pedal not returning a couple times, but was caused by poor bleeding and the factory's crappy master cylinder.
I've installed a master from ideal garage and have had no more clutch issues.
2018 MBM ZL1 1LE - Stock
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 07-23-2014, 11:32 PM   #32
two_wheel_mayhem
Would rather be riding
two_wheel_mayhem's Avatar
Drives: No car no more
It doesn't matter if the spring is there or not, whatever floats your boat. The weight of the clutch pedal won't ruin your throwout bearing.
The spring is there to insure the clutch safety switch remains reliable.
No dog in this fight anymore.
5th Gen owner 2009-2016.
two_wheel_mayhem is offline   Reply With Quote
Old 07-08-2015, 02:44 PM   #33
tlevando
Drives: 2010 Victory Red 2SS
Has anyone else had any more success with removal of the clutch spring? Recently picked up a 2010 SS and after driving the car for awhile just hate how the clutch lets out.
tlevando is offline   Reply With Quote
Old 07-09-2015, 03:35 PM   #34
White_SS/RS
White_SS/RS's Avatar
Drives: 14 1LE
I took it out, it makes the travel feel more linear and smooth.
LMS Engineering
White_SS/RS is offline   Reply With Quote
Old 07-09-2015, 04:55 PM   #35
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Any pictures of the spring an its location???
olblue75 is offline   Reply With Quote
Old 07-09-2015, 05:10 PM   #36
White_SS/RS
Drives: 14 1LE
It's pretty easy to spot, just look on the pedal arm just above the foot pad and you'll see it.
LMS Engineering
Old 07-17-2015, 03:54 AM   #37
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
i took mine out and it shifts smoother i think. need to drive it more than 5 miles
Old 07-17-2015, 04:51 AM   #38
Bo White
Bo White's Avatar
Drives: 2015 Summit White 2SS 1LE
The G8 GXP doesnt come with a spring for easier pedal effort.
Bo White is offline   Reply With Quote
Old 11-30-2017, 10:53 AM   #39
rviper24
rviper24's Avatar
Drives: 2013 Camaro SS 6-Speed
Took mine out and like it driving it a lot more, I hated the springing back feeling.
2013 Camaro 1SS 6-Speed LS3
All stock.. For now...
rviper24 is offline   Reply With Quote
Old 11-30-2017, 11:02 AM   #40
Bo White
Bo White's Avatar
This is with the hyd. disconnected. As you can see its like a pendulum spring. Loaded in the wrong direction coming off the floor.
https://youtu.be/U5FSEtDuys8
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 11-30-2017, 12:41 PM   #41
xc_SS/RS
Drives: 2010 Camaro SS/RS
I removed mine a few weeks ago and the clutch engagement is more consistent. Definitely recommend this, and if you're worried get the Lingenfelter return spring. I'm also running that and I like it. It's annoying in really bad bumper to bumper traffic but that is it.
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 11-30-2017, 02:22 PM   #42
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
See posts 6&7 on this Vette forum about the dual role the assist springs plays and GM bulletin on not removing it and denial of warranty if removed. Assuming it's also applicable to the Camaro spring ?
http://www.z06vette.com/forums/f62/a...spring-115662/
Here's an excerpt
One purpose of the over center spring is to return the clutch pedal to the very top of the stroke to expose the compensation port. The clutch master cylinder has a compensation port that is positioned within 1 MM of the top of the stroke. The compensation port allows internal pressure in the clutch hydraulic system to be exhausted into the master cylinder and also provides for system refill as the clutch disc wears. Removing or disconnecting the spring may allow the clutch pedal to hang at rest position with the piston short of the compensation port. If the internal pressure is not exhausted the CSC may get stroked too far and a clutch hydraulic system failure may result.
The second purpose of the spring is to provide for the designed clutch pedal feel
(ie. make it easier to hold down in stop/go traffic)
camguynj is online now Report Post
camguynj is offline   Reply With Quote
wrong subforum
