Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 06-11-2014, 07:54 PM   #15
Da Mammer
Drives: 2010 camaro SS... shell...
I went the opposite direction. I actually added the Lingenfelter return spring on top of the stock. When you start making serious power, and are driving hard the clutch fluid starts to heat up and when you let up on the clutch the pedal won't come up the whole way. Your pedal travel will cut in about half with each shift, to the point the pedal travel is about 2-3 inches instead of the normal foot or so. The engagement point changes each time too. It makes it really difficult to change gears properly and wears hard on clutch parts. That's why that spring is there to help. If anything I want a stronger spring. But if you aren't making big power or driving hard, and just kind of cruise around it may not ever be an issue for you, but for the power junkies I'd highly recommend keeping it.
tried LSXTC...now I'm LSXOD...
Da Mammer is offline   Reply With Quote
Old 06-11-2014, 08:27 PM   #16
blazerk5
Drives: 2013 1LT RS Victory Red M6
Originally Posted by blazerk5 View Post
How many of you have removed your clutch pedal return/overcenter spring?
I have and the clutch feels real now.
Tim
This is my question. Please only answer if you have removed the spring.
Tim
blazerk5 is offline   Reply With Quote
Old 06-11-2014, 09:44 PM   #17
Stealthpanda
Thread Ender
Stealthpanda's Avatar
Drives: 2010 Camaro 2SS/RS L99
Tim
Stealthpanda is offline   Reply With Quote
Old 06-11-2014, 10:33 PM   #18
McRat
McRat's Avatar
Drives: 2010 ZR1 "Satan"
A clutch return spring stops you from running weight on your throwout bearing the whole time you are driving if you rest your foot on the pedal.
This is true on all cars.
Remove it, and it's possible your throwout bearing will not live as long.
2002 Z06 "Blue Meanie" 11.36 ET
2003 Z06 in progress
2009 CTS-V "Spooky" 12.36 ET, bone stock at 1600 mi. Rainy day in Sacramento. Sadness.
2010 ZR1 "Satan" no times yet.
2013 Volt SCCA Solo2 #771 HS3.
And a bunch of Duramaxes.
McRat is offline   Reply With Quote
Old 06-14-2014, 09:28 AM   #19
shrinkdoc
Drives: SRT Yugo GT Super Sport with Manual
Tim
There is another post here saying dont do it because it can cause your clutch to slightly drag causing premature wear.
shrinkdoc is offline   Reply With Quote
Old 06-14-2014, 01:58 PM   #20
invaderzim
invaderzim's Avatar
Drives: 45th SS, '12 ducati 1199 on order
Tim
Tim
Dude. Like seriously. The whole point of this thread was to get yes answers. Get it together, man. Don't bother him with your opinions and/or facts on the matter....
invaderzim is offline   Reply With Quote
Old 06-15-2014, 08:44 PM   #21
blazerk5
Thank you. That is what i am looking for.
I can not believe how much better my car drives now. I never rest my foot on the clutch, no issues there. Wish the aftermarket would come up with a new design.
Tim
Old 06-15-2014, 08:48 PM   #22
Stealthpanda
Thread Ender
... but he put the rolleyes emoticon after what he said... did you not notice?
Old 06-15-2014, 08:51 PM   #23
Baer383
Baer383's Avatar
Drives: 2013 ZL1 Ashen Gray
That's Fvcking stupid.
I don't have to know everything,I just need to know,what I need to know,when I need to know it!
MODS, a lot of money,a lot of parts,a lot of time,a lot of patience.
754 RWHP 747 RWTQ 93 Octane
http://www.camaro5.com/forums/showthread.php?t=347243
Baer383 is offline   Reply With Quote
Old 07-22-2014, 10:41 PM   #24
Hooper
Camaroholic
Hooper's Avatar
Drives: 2011 2SS/RS 6M
Tim
Could not agree more, Tim. I had read up a bunch on this issue over the last year as I hate the way the stock pedal feels. The pedal springiness and stiffness peaks right at the catch point, which makes it very difficult to clutch it smoothly and is also uncomfortable to drive. I could live with it if I had to but its an obviously a GM engineering flaw (just like the worthless radio controls on the right side of the steering wheel rather than the left). I removed my spring today and am astonished how much better the car drives. The clutch pedal still extends to full position easily without the spring, and I don't ride the clutch either so it should not cause any problems. I read that the Vette guys do this first thing on the brand new Vettes, too.
For all of you considering this, try it and you will likely be very happy. You can always put it back on later if you wish.
Hooper is offline   Reply With Quote
Old 07-23-2014, 07:22 AM   #25
Destructo09
Drives: 2010 CGM Camaro 2SS/LS3
I'm pretty sure the spring is not a return spring. While I was doing my Clutch master cylinder I accidentally pushed the pedal and the spring actually pushed the pedal to the floor. ( At the same time spraying fluid under the hood since I had disconnected the line already ).
So I believe this spring is actually the help reduce the pedal effort. So you really aren't hurting anything by removing it, just making the pedal effort slightly higher. I don't think there's any requirement to have springs even on a hydraulic clutch.
2010 2SS
BMR 1" Springs
Koni Orange struts/shocks
1LE rear sway bar
SRP Racing Pedals
Hurst Billet short shifter
Square tire/wheel setup
Elite Engineering Catch Can
Stainless Power longtubes/highflow cats
K&N Typhoon CAI
RPM Motorsports of Garner, NC dyno tune (421 RWHP)
Destructo09 is offline   Reply With Quote
Old 07-23-2014, 01:06 PM   #26
maddoggyusa
maddoggyusa's Avatar
Drives: 2013 Camaro Dusk 2SS/6
if you right, then I guess everybody is removing it to make it "harder"
too funny.
maddoggyusa is offline   Reply With Quote
Old 07-23-2014, 01:13 PM   #27
K1SSRSS
Chief Many Camaros
K1SSRSS's Avatar
Drives: A paid off Camaro!!!
too funny.
He is right is the funny thing that clutch "assist" spring is different than lingenfelter's clutch return spring. Most drag racers will remove the assist spring and install a return spring to aid in proper clutch function.
504hp/478tq
Performance: Kooks LT, 3'' Exhaust, V-Max TB, Roto-Fab CAI, Custom Ported/Port Matched Heads and Intake
Suspension: BMR Adjustable LCA's, BMR Trailing Arms, Poly Bushings, BMR Toe Rods
Coming Soon (still in the box): Procharger F1R, G-Force Axles, 3:91 gears w/Eaton Truetrac
K1SSRSS is offline   Reply With Quote
Old 07-23-2014, 01:27 PM   #28
Squillo
Drives: 2013 Camaro 2SS/RS BRM LS3
Do you have to change the station while you're shifting gears? I just don't understand why it's a big deal to have the radio controls on the left or the right side of the steering wheel.
Squillo is offline   Reply With Quote
wrong subforum
