Vararam
Old 08-17-2017, 01:49 PM   #1
andrewpeanut
Drives: 2015 Chevy Camaro 1SS
Question for SS to ZL1 brake upgrades
Hey everyone
first thread ive made here even after having my car for 3 years
i have a 2015 1SS
thinking bout upgrading to the ZL1 front brakes
besides calipers, rotors, pads, and packing plate
what else would i need? im already running the granatelli stainless lines
andrewpeanut is offline   Reply With Quote
Old 08-17-2017, 05:52 PM   #2
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
The lines for the ZL1 are different than your SS lines. You can get backing plates from Amazon for like 13 bucks ea. There's a good thread in the 1LE section about the vented pistons, I ordered them through www.Iamgmparts.com 120 a set. An I bought a set of OEM pads with 30 miles on them from www.corvetteforum.com for 65 bucks so scour the forums. Some things you'll more than likely have to buy new.
Orange Krush II
1LE Front sway bar, Splitter, shocks and struts, Z28 dual mode mufflers, Intake, UCA Bushings, and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, ZL1/C7 Calipers, and 32mm JPSS Rear Bar. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 1 7/8 LTs. DSE and PAFDT Suspension components.
olblue75 is offline   Reply With Quote
Old 08-17-2017, 05:55 PM   #3
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Here you go
http://www.camaro5.com/forums/showth...=Brake+upgrade
Orange Krush II
Old 08-17-2017, 06:44 PM   #4
andrewpeanut
so i would have to get OE ZL1 lines or find SS braided ZL1 lines
i see the talk about ZL1 vs Corvette
so if i read this correctly are they vented on the corvette and not on the ZL1 and i dont see pistons seperately
and ok cool good price on pads
Old 08-17-2017, 07:56 PM   #5
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Yes the you need ZL1 lines the are longer than the SS lines. The Corvete Caliper for the Z06 Non Ceramic brakes use the vented pistons good for a 80 degree drop. The PN for the pistons are in the thread I linked just have to read through it.
Orange Krush II
Old 08-17-2017, 11:37 PM   #6
Superman09
Account SNAFU
Superman09's Avatar
Drives: 13 Tahoe 79 Scout II 15 1LE
I have a 15 1ss 1le and I didn't have to swap the backing plate. As olblue said you will need new ZL1 specific lines. And if you can, get the vented pistons. I'm running vented pistons in mine and have had no problems, but a buddy with stock pistons boiled his fluid during fest at NCM.
Sent from my VS995 using Tapatalk
Superman09 is offline   Reply With Quote
Old 08-18-2017, 02:13 PM   #7
andrewpeanut
so ive been reading around and apparently the Corvette Z06 for 2015 calipers are the same as ZL1 just have the vented pistons
so if ive read everything correctly the Z06 caliper would bolt straight on and i could use either a ZL1 front rotor or Z06 rotor?
ive found brand new front calipers for a Z06 400 each
backing plates are only 16 each
so far
if everything im understanding is correct
get the Z06 calipers
ZL1 backing plates
ZL1 lines
ZL1 or Z06 rotors
Z06 pads with hardware
but what mounting bolts? Z06 bolts?
Old 08-18-2017, 06:04 PM   #8
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Pretty sure you can't use the Z06 rotors it's a off set issue on the hat.
Z06 Pads on steel rotors are the same as the ZL1 pads.
I think all the bolts are the same Z06, ZL1, or CTS-V.
ZL1 Rotors are about 250 a piece new you can use CTS-V rotor about 125 a piece.
Orange Krush II
Old 08-18-2017, 06:57 PM   #9
andrewpeanut
i read deeper and i see that about offest
so
Z06 calipers
ZL1/V rotors
ZL1 lines
Caliper Mounting Bolts from either V, ZL1, or Z06
ZL1/Z06 Pads
Z06 Pad hardware Kit
ZL1 Backing Plate
Old 08-18-2017, 07:22 PM   #10
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
I think you got it and don't forget DOT 4 brake fluid. There's a thread on here about a DOT 4 Cap too.
Orange Krush II
Old 08-23-2017, 10:17 AM   #11
andrewpeanut
already running Motul 600
Old 03-14-2018, 12:54 PM   #12
andrewpeanut
Question for everyone out there
for the V/Z06 brake upgrade
does it clear the factory 20 inch silver wheel from the 1ss or does it require the 1LE wheel?
I figure it would clear and I shouldn't have issues
im just making sure before I go and buy a set of wheels that clear the factory brakes
Old 03-14-2018, 07:56 PM   #13
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
If your running 20s you'll be good I was running the 2010-13 RS wheel without issue but have changed to the 6th Gen 1LE wheel.
Orange Krush II
Old 03-26-2018, 09:29 AM   #14
alexmak
alexmak's Avatar
Drives: 2013 1LE
so
Z06 calipers
ZL1/V rotors
ZL1 lines
ZL1/Z06 Pads
ZL1 Backing Plate
I assume this wil work for 2013 1LE as well, correct?
alexmak is offline   Reply With Quote
