TireRack
Old 03-07-2014, 07:49 AM   #1
DandDC09
DandDC09's Avatar
Drives: '10 2LT/RS, '13 Malibu
Anvil Spoiler owners?
This is a question for the Anvil Spoiler owners. Did you raise your spoiler off your trunk slightly or mount it as normal. Ive read where some have talked about the ends over the trunk rubbing. Did yours and what did you do to correct it?
To me the end gap would be considered for in making it, so is it possible the rubbing would be from closing the trunk to hard and thats what is rubbing over time?
Let me know what you guys have done? Mine comes in today!
DandDC09 is offline   Reply With Quote
Old 03-07-2014, 08:11 AM   #2
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
Just install as normal, if needed you can adjust the rubber stoppers/bunpers in the trunk to raise the lid ever so slightly.
Soprano 4/1/00-6/14/11, Gone but NEVER forgotten!
FSP tuned: 377/389
nyrfan is offline   Reply With Quote
Old 03-07-2014, 08:40 AM   #3
Denis
Denis's Avatar
Drives: 2010 SS
I would raise it slightly if you can. The passenger side on the spoiler I had rubbed and it's noticeable on the paint...
Denis is offline   Reply With Quote
Old 03-07-2014, 08:41 AM   #4
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: 2023 ZL1 Sharkskin
installed normal
hrpiii is offline   Reply With Quote
Old 03-07-2014, 10:13 AM   #5
DandDC09
DandDC09's Avatar
That's a pretty good idea too. Didn't think about that... See how it fits after being painted...
Thanks for the help guys!
Old 03-07-2014, 10:23 AM   #6
billd579
billd579's Avatar
Drives: 2010 Camaro SS/RS
Installed Normal and I have had no issues
billd579 is offline   Reply With Quote
Old 03-07-2014, 02:09 PM   #7
mbrusco103
mbrusco103's Avatar
Drives: 2011 2SS/RS (M6) 427 Twin Turbo
Installed normal with no issues. The ends came with a foam pad to stick onto the underside of the ends of the spoiler so those touch but nothing else
2011 Camaro 2SS/RS ERL 427 M6 TT
-AGP Twin Turbo 55/57 .83ar | ERL 427ci | Squash Fuel System | Stainless Works Chambered 3" | Mcleod RXT | Factory Hurst Short Throw | Black Forgestar F14s | CTS V 6 Piston Brembo | VIS AMS Carbon Fiber Hood | Anvil Carbon Fiber Spoiler
mbrusco103 is offline   Reply With Quote
Old 03-07-2014, 04:25 PM   #8
DandDC09
DandDC09's Avatar
Its here!
Is it supposed to come with any kind of gasket or double sided tape? How about nuts or just use the stock ones?
So the ones that have been installed normal, did you use the pads they sent with it?
Old 03-07-2014, 04:39 PM   #9
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Send a message via AIM to SSE 4 2SS Send a message via Yahoo to SSE 4 2SS
I've got a three piece spoiler... I mounted it just like the instructions... no issues... I realize the one piece spoilers hang out and can contact the body sides...
I used one sided 1/8th inch foam tape to pad under it as well... Keeps the spoiler from sitting right on the paint.. and I cut the tape in sections that don't touch so water would not pool in front of the spoiler...
If the car feels like it is on rails, you are probably driving too slow. -Ross Bentley
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
“If everything seems under control, you're just not going fast enough.” Mario Andretti
If you can turn, you ain't going fast enough...
SSE 4 2SS is offline   Reply With Quote
Old 03-07-2014, 05:10 PM   #10
nyrfan
Let's go Rangers!
nyrfan's Avatar
Originally Posted by DandDC09 View Post
Its here!
You use the stock nuts, make sure you use some locktite (spelling) and do not over tighten. The is no double sided tape but the should be a thin gasket on it.
Sent from my AGM, 2SS/RS
FSP tuned: 377/389
Old 03-07-2014, 05:47 PM   #11
miltp
Jim Pappas
miltp's Avatar
Drives: Rally Yellow 2SS/RS,Auto,G/X
I just put protective clear film on on area where spoiler overlaps onto body.
miltp is offline   Reply With Quote
Old 03-21-2014, 08:30 AM   #12
DandDC09
DandDC09's Avatar
Is this surface wave normal for any of your anvil spoilers?
Old 03-21-2014, 08:51 AM   #13
Denis
Denis's Avatar
Drives: 2010 SS
its not gonna be perfect...but thats a little much i think
Old 03-21-2014, 08:55 AM   #14
BigBlock69RS
Ed
BigBlock69RS's Avatar
Drives: 2013 AGM Camaro 2SS/RS/1LE
I had to enlarge the mounting holes so the spoiler so it would sit flush and level. Also provided were some pads of rthe ends.
As along as you get the spoiler flush and use the provided end pads, you shouldnt have rubbing issues.
BigBlock69RS is offline   Reply With Quote
