Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Wheels and Tires Talk Sponsored by The Tire Rack
Old 05-13-2017, 01:20 AM   #1
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
Tires comparable to MPSS?
Any tires that are comparable to MPSS but not break the bank??? I would love to have those tires again, but damn they are crazy expensive.
TMS 427, Dart iron Block, Forged assembly, Frankenstien heads, AGP TT 62/62 BB turbo's, AGP/Fore triple fuel system, Tilton clutch, Holley 1 7/8 shorties, Technostalgia tail lights,Oracle, Aeroforce, MGW shifter,Flowmaster, Pegasus subframe bushings,BMR trailing & toe arms,Z28 UCA bushings,Zl1 rear sway bar,Prothane,BMR,Goodridge brake lines,Ridetech HQ coilovers,3.91,Trutrac,billet caps,DSS axles,HE offest,built TR6060,1LE diffuser,Havoc spoiler,SSclones,20in MRR 017, Pirelli P Zero, Nitto NT555RII
More to come.
Black_SS10 is offline   Reply With Quote
Old 05-13-2017, 08:41 AM   #2
PostNup
CAR-DASHIAN
Drives: 2015 Ashen Gray Metallic 2SS/RS L99
Firestone Indy 500s. Stick Pirellis would spin the 3-4 shift... now, only the 1-2
And they are only $170 a piece.
PERFORMANCE: ColdAirInductions CAI, ADM Race Scoop, Cordes Performance Racing Ported TB/IM/Custom VVT Cam, WFO Milled Heads, Stainless Power 1 7/8" LT/3" HFCs, JBA 3" Comp. Cat-Back, Taylor 10.4mm Plug Wires, Tim King Performance Stage 3 6L80, Circle D Billet 3600 Stall, Nic D ECM/TCM Tune, - 458rwhp/413rwtq (prior to PIM), Forgestar F14 (F)18" / (R)17" Rims.
SUSPENSION: Z/28 Rear UCA Bushings, Carlyle Racing LCA/TA, BMR Adj. Toe Rods/Xtreme Anti-Roll Bar, Justice Pete Castor Locks/Radius Rod Inserts, Pegasus Billet Rear Cradle Bushings, Mickey Thompson Street SS II 305/45/17 tires.
PostNup is offline   Reply With Quote
Old 05-13-2017, 12:21 PM   #3
Black_SS10
SomeguyK
Black_SS10's Avatar
Thanks for the reply. Those Indy 500 grip well?
More to come.
Old 05-13-2017, 02:57 PM   #4
PostNup
CAR-DASHIAN
First 50-100 miles is real sketchy - thought I made a mistake buying them, haha.
After you get the soap or whatever they coat it with you will love them.
First day out after getting the soap off - 42 degrees. I was expecting them to be like hockey pucks like the Pirellis. Nothing like that. 1-2 shift spins a little. Held in the corners.
Check my posts with "Alignment Specs" and I would highly suggest Firestone''s Lifetime alignment for $169.00. They will do it to these specs.
End of the day - you will love the tires and want to do more to the car. Follow the suspension part of my sig and your car will have:
1) Zero wheel hop.
2) Zero slop in the rear end over bump and hard acceleration and corners.
3) Although bumps are more noticeable, the car still rides very smooth.
4) You will break 1.0g cornering - even with you still have stock Pirellis in the front
5) Car will return to straight out of corners much faster.
6) Greatly reduced trammeling - following ruts in the road.
7) When you replace parts that require an alignment - you will already have it paid for!!!!
Hope this helps,
Sammy
Old 05-13-2017, 08:53 PM   #5
Black_SS10
SomeguyK
Black_SS10's Avatar
Thanks for the reply and info! I am gonna check these out! I have reviewed them on Tirerack and they do not seem like a bad tire at all.
More to come.
Old 05-13-2017, 09:07 PM   #6
Burt
Cone Killer
Burt's Avatar
Drives: 2012 SS
It's hard to beat the MPSS. The Continental Extreme contact Sports are brand new and supposed to be an MPSS beater, and the Nitto NT555 G2s seem to be a good tire as well.
2012 Camaro SS - Sold
Selling off my remaining wheels, tires, 27mm front sway bar, and MGW shift knob. Get them out of my house before my wife puts me out!
Burt is offline   Reply With Quote
Old 05-13-2017, 09:26 PM   #7
Black_SS10
SomeguyK
Black_SS10's Avatar
Don't get me wrong, the MPSS are great tires. I just cant afford the $1800 price tag for all four installed. 275 front and 315 rear. I don't even autocross the car and have separate radials for drag racing.
More to come.
Old 05-13-2017, 09:38 PM   #8
toehead93
Drives: 2014 2SS/1LE
Forget the old MPSS, they are being replaced with the PS4. The new Continentals are supposed to be very close in performance.
Used Racing Brake 2 Peice Rotors for sale:
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 05-13-2017, 09:41 PM   #9
Black_SS10
SomeguyK
Black_SS10's Avatar
Hell, the PS4 are just as expensive if not more!
More to come.
Old 05-14-2017, 05:37 PM   #10
toehead93
Sorry missed the part about not breaking the bank. The closest tire I know of are the continental extreme contact sports that were already mentioned. Not sure what they cost though.
2010 2SS A6 - sold.
Old 05-14-2017, 09:52 PM   #11
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
I just installed the Indy500s. I only have ~50 miles on them but I am liking them.
But, the largest tire they make is a 305/35X20. That's ~0.14" smaller radius than the 315/35 and 275/40s.
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 05-14-2017, 10:02 PM   #12
Black_SS10
SomeguyK
Black_SS10's Avatar
I noticed the same. A 305 instead of a 315 wouldn't be a big deal. I think I am going to try them and see how it goes.
More to come.
Old 05-19-2017, 04:52 PM   #13
Black_SS10
SomeguyK
Black_SS10's Avatar
So I went to order a set of Firestone Firehawk Indy 500 and the size 305/35/20 is on back order. To make matters worse supposedly they wont have another production run for something like 90 days!!! ugh....guess I need to find a different tire option.
More to come.
Old 05-19-2017, 05:02 PM   #14
PostNup
CAR-DASHIAN
I just checked Firestone's site and they show limited quantity avail in the 305.
HTH
