Old 05-09-2016, 10:30 PM   #15
AdvanSuper
AdvanSuper's Avatar
Drives: 1SS HBM w/MRC NPP
Do you have an image of the the car on 19's?
AdvanSuper is offline   Reply With Quote
Old 05-15-2016, 11:27 PM   #16
crankaholic
crankaholic's Avatar
Haven't gotten my summer wheels/tires yet, but here it is on the winder set - 19x8.5 ET35 without spacers (so they sit a bit far inward).
crankaholic is offline   Reply With Quote
Old 05-16-2016, 01:50 AM   #17
G Fo12ce
G Fo12ce's Avatar
Drives: '16 2SS
Thanks for the info, saving. I've always been happy with Continental's. I've had various Sport Contacts on other cars and DW on my last car. I think they perform well and are a good value. The times I've looked at them compared to to other brands on the Tire Rack chart they've always been the lightest too.
My Intro Post | My Order | My Ordering Guide
TJCR2Q | 2SS Red Hot|Adrenaline Red|MX0 A8|56R Wheels|5ZU Blade Spoiler|NPP Exhaust|F55 MRC|IO6 Nav
• 4/06/16 1100 Ordered (waiting for 5ZU acceptance)
• 4/19/16 2000 Accepted with 5ZU
• 4/23/16 3000 TPW:5/16/16
• 5/06/16 3100
• 5/13/16 3400 Broadcast Sheet
• 5/24/16 3800 Vehicle Produced
• 5/25/16 4B00 Bayed
• 5/27/16 4300 Intermediate Delivery
• 7/9/16 Delivered!
G Fo12ce is offline   Reply With Quote
Old 06-05-2016, 09:02 PM   #18
samsumon
Drives: 4 wheels
Originally Posted by crankaholic View Post
I bought the spacers for a set of winter wheels - 19x8.5 ET35 wheels are plentiful and much cheaper than ordering a set with a proper offset... considering winter tire grip and less enthusiastic driving style, using a spacer to bring the +35 offset back to +20 is a cheap solution that won't hurt anything in this case.
Using a spacer to offset a wheel further than stock will have negative consequences... both short and long term.
Can you explain why its negative? I have 20mm spacers on all four rims and the car performs just as the day I bought it. Don't notice anything negative with the ride or how the rims are sitting..
samsumon is offline   Reply With Quote
Old 06-06-2016, 11:57 AM   #19
crankaholic
In the immediate category, you just changed how the wheels transfer forces into the suspension... effectively messing up the factory suspension geometry setup. You probably won't notice anything while driving around town, but if you're in tune with your car (and cars in general) you'll feel it when pushing it past 8/10th.
Long term you're putting more stress on the hub bearings, wheel studs and other suspension components. Depending on how everything is designed it might shorten the life of some of those components.
If you're mostly cruising around and the roads are nice and smooth where you live, it might not actually matter that much... but if you're hooning your Camaro daily in the northeast, bushings and bearings will become a regular maintenance item.
Old 06-20-2016, 03:39 PM   #20
crankaholic
Forgestar CF10s in 19x9ET20 standard concave and 19x10ET30 deep concave.
Front @ 25.2 lbs
Rear @ 25.1 lbs
Old 06-24-2016, 04:45 PM   #21
crankaholic
With tires mounted and balanced - Sumitomo HTR Z IIIs, 245/45ZR19 front and 275/40ZR19 rear.
Front - 54.5lbs
Rear - 55.7lbs
Old 03-29-2017, 01:30 PM   #22
drivingagain
drivingagain's Avatar
Drives: 2015 Tiger XCX,2016 Camaro 1SS,LBZ!
Ok so the forged VS forged rims in 20x10 et23 and 20x11 weights et43.
drivingagain is offline   Reply With Quote
Old 03-29-2017, 05:00 PM   #23
drivingagain
And now with tires and the rest. Very happy with the weights at this size and still under factory weights for sure!
Old 09-30-2017, 09:42 AM   #24
ninetres
ninetres's Avatar
Drives: Crush ZLE M6 | 2000 Corvette FRC
OEM ZR1 wheel weights? Searched for an hour last night to no avail.
ninetres is offline   Reply With Quote
Old 03-18-2020, 01:21 PM   #25
Eric10905
Geezer_loves_Camaros
Drives: 2018 2SS, Black, A8
An older post, but for what it's worth, I'll add some verification of what is already here.
As i took the stock 245 / 275 silver wheel/tires off, I found the same weights. ~ 64 lbs for the rear, and 59-60 for the fronts. That was everything but the lug nuts.
I replaced those with GM ZL1 wheels tires, and found them to be 59# front (285/30/20) and 62#rear (305/30/20). Also everything but the lugs.
I weighed the car at certified truck scale, full tank of gas: 3740#. That is for a 2018 2SS NPP A8 sunroof.
Last edited by Eric10905; 02-08-2021 at 01:54 PM. Reason: corrected typo on car weight
Eric10905 is offline   Reply With Quote
Old 07-14-2021, 02:58 PM   #26
s346k
s346k's Avatar
Drives: like an old lady
factory ss 1LE wheel tire combo
front 58 lb 20x10 285/30/20 goodyear sc3
rear 59 lb 20x11 305/30/20 goodyear sc3
17x9.5 racestar w 275/40/17 mt et street r - 51 lb
18x5 racestar w 26x6 mt sportsman sr - 38 lb
i have a set of loose gy sc3s in factory 1LE sizes, i'll weigh them and post up soon. i have a couple other sets of wheels i can add. 19" winter setup w snow tires and a vs forged factory size ss 1LE wheel setup.
also full weight, half tank of gas, when stock: 3720 lb
