05-19-2015, 05:22 AM | #1 |
Drives: 2014 Summit White 1LE Join Date: Sep 2013
Best track brake pad for 1LE
Any good recommendations for this?
Currently running OEM rotors with Motul RBF600 Sticking with the 1LE Stock 4piston F/R Calipers. Looking to buy a set of dedicated race pads. Opinions? Hawk DTC-70s? Carbotechs XP12? Cobalt XR1? How about the rear? Thanks all! |
05-19-2015, 06:46 AM | #2 |
Drives: 15 Lexus RCF, 17 Vette Grand Sport Join Date: Apr 2013
I use DTC-70 front and DTC-60 rear. Works pretty good!! get 3 to 4 days on the fronts. I hear Cobalts are great
2013 Summit 1SS 1LE w/NPP, SW 1 7/8" Long Tube Headers, CAI Intake, Ported TB, Cammotion 224/232 113 LSA, BTR Valvetrain, Melling Oil Pump, 468 HP 423, Apex Catch Can, Tank Plates, RPM 4 Point Roll Bar with SCCA/NASA Cross Brace, Schroth 6 Point Han's Harness, OMP WRC Front Seats, F.M.T Trailing Arms, F.M.T Solid Aluminum Subframe Bushings, Moreno Motorsports Camber Plates, BMR Bushings Front and Rear, Essex/AP Racing Radi-Cal Endurance Front Brakes, Quantum Brake Cooling Ducts, ZL1 Rockers, ZL1 Air Deflectors, Heritage Grill, Pfadt Springs.
05-19-2015, 07:34 AM | #3 |
Drives: 14 1LE Join Date: Mar 2013
Can't go wrong with any of them. I run Raybestos ST43 front and rear but I also have 6 piston fronts.
LMS Engineering
05-19-2015, 01:01 PM | #4 |
I hear Raybestos will make a custom set of fronts for the 6 piston fronts. I may try them next as I have heard great things
05-19-2015, 01:39 PM | #5 |
Drives: 2011 Boxster Spyder (best car ever) Join Date: Aug 2014
I run carbotech xp12/10 they are the best I have used (HATED the hawks). I really like them, because if bedded PROPERLY, they are near silent on the street....They are not cheap and they last me 8 days and I AM HARD ON BRAKES. When I first started tracking my car, I called EBC and they recommended Carbotech over their own products for my situation. I don't think it gets any better than that. You will need ducts most likely too...I am going to start a thread later this week on my $22 Ace hardware ducts, that worked much better that the ZL1 ducts....
05-19-2015, 02:54 PM | #6 |
Ya, I had mine custom made for the front. They use some nice thick backing plates too and they don't charge you more just because they are custom. I think they price somewhere between Hawk and Carbotech.
LMS Engineering
05-19-2015, 03:00 PM | #7 |
I just wanted to follow up white ss/rs...... I have ZL1 6 pistons now, but i used the same pad setup with the 4 piston ss.... Just so there is no confusion.
05-19-2015, 03:04 PM | #8 |
Drives: 2019 Chevy Equinox Premier AWD Join Date: Mar 2011
I'm a fan of the Hawk pads but I have never tried the Carbotechs. Ducts are a must if you plan on tracking with race pads IMO. One thing I noticed is you will need to stagger the compounds front to rear. Like backeddy said, you can go XP12/XP10 or for hawk DTC 70 front DTC-30 or 60 rears you should be okay. I had tried the Hawk Street/Race (DTC-30) front AND rear and the car had an ABS issue in the rears when stopping on the street. If it's that bad on the street, I'd hate to see what happens when you try to do that on the track. One final note, DTC-70 or other race compounds will eat through your rotors more on the street and be dusty as hell. So I recommend to change back afterward and buy a different set of rotors/pads for the street.
2013 AGM 1SS/1LE, NPP, Camera
(1 of 43) |
05-19-2015, 08:32 PM | #9 |
Used the dtc 30 initially and they were horrible!! Definitely recommend the cooling ducts and castrol srf
05-19-2015, 08:47 PM | #10 |
I love my cobalt xr1/xr3 brakes I run stock rotors in rear racingbrakes up front and these are the best combo I just had a track day Saturday and was amazed at the performance. My hawks would always deposit pad on the rotor ad cause a warpage issue half way through the day. no such issue with the cobalts
05-19-2015, 09:06 PM | #11 | |
Do you swap street pads for the street? I swap between hawk ceramics. They leave zero dust!
05-19-2015, 09:20 PM | #12 |
05-19-2015, 10:56 PM | #13 |
Drives: 14 1SS Camaro 1LE, NPP, Recaros Join Date: Nov 2013
I have Raybesto's ST47 on front ZL1 brakes, ST45 on rear. They are AWESOME. I have more than 5 track days on mine, was too lazy to take them out between events, almost no wear, rotors look great, was able to brake even with a C7 Z06 with carbon brake package this past weekend from 120 down to 35mph. I have experienced the brakes overpowering the tires one time in 10 track days or so (overtook a car late in the braking zone and really laid into them to insure I didn't blow the entrance with a car on my door), the ABS goes into like an ice mode where it lets the rotor roll more than it brakes. I use ABS on most all big braking zones.
I'll buy them from now on without hesitation, no issues with dust etching into wheels either. |
05-19-2015, 11:10 PM | #14 | |
