Old 01-06-2022, 05:49 AM   #15
dmcmahan60
dmcmahan60's Avatar
Drives: 2017 SS
You can buy a cheap hand held scanner like I did before I had it repaired and just turn the CEL off. Used to do it about once a month. Good luck
dmcmahan60 is offline   Reply With Quote
Old 04-01-2023, 09:31 PM   #16
Haole
2017 SS
Haole's Avatar
Drives: 2017 Summit White 2SS
Mine is in the shop at this moment with thos exact issue. Thank God I have the top warranty. They are test driving it now and will get back to me. Not sure of total I will need to pay yet, but I'm sure I have to cover the diagnostic test for sure. 2 weeks ago my thermostat went bad and warranty covered all by $123.
Haole is offline   Reply With Quote
Old 03-28-2024, 12:36 PM   #17
Spaceme1117
Spaceme1117's Avatar
Drives: 2017 Camaro SS, 2011 Corvette GS
So my 2017 SS just threw the P0700 and P0711 CEL combination. From some searching, this looks to be a somewhat common issue on the 8L90 automatic transmissions.
It is an issue with the wiring harness in the trans and there is an updated part to fix this. The harness has the temp sensor integrated into it.
I will have to drop the trans pan to swap out the harness but looks to be relatively easy.
Have a new trans filter, fluid, and the new harness on order.
It's always something.
Spaceme1117 is offline   Reply With Quote
