02-06-2014, 12:02 PM | #1 |
Drives: 2010 2SS RS M6 Join Date: Mar 2011
NGK TR6 plugs
I recall reading somewhere that with the LS3 (maybe other engines too) replacing the stock plugs with NGK TR6 plugs was a good thing. Any thoughts on this? Also, if so, what gap?
Traded-in car: K&N Typhoon intake, JBA Shorty headers, Solo mid-pipes/hi-flow cats, GMPP Track Pack axle-back, Vmax ported TB, Billet Custom catch can, billet tensioner pulley, Hines Hex Vents, Z/TA rear spoiler, ProCustom headlight covers, Drake black/riveted quarter window covers, GM satin fuel door, chrome and brushed caps/covers under the hood, EmblemPros underhood bowtie & fuel rail "Camaro" plates, chrome "SS" door kick-panels, chrome trunk latch plate & strut rods, Street Scene lower grille ducts w/LED lights, front bowtie-delete, Yates Performance pedals, 35% tint, etc.
02-06-2014, 02:25 PM | #2 |
Drives: 2012 2SSRS Vert, Black w/M6 Join Date: Jan 2013
The TR6 is a colder plug, you don't want to do that unless you have to. Also, they are just a cheap copper core plug, they won't last long. The iridium version of the TR6 is ok, but too cold unless you are running a decent amount of boost. The stock ACDelcos are a good plug. If you prefer NGKs, the TR5 heat range plug is about stock, but get the iridium version of that also, not the copper (NGK 7243/TR5-1IX).
02-06-2014, 02:54 PM | #3 | |
Drives: 2010 Camaro SS Join Date: Jan 2014
02-06-2014, 03:01 PM | #4 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
I put autolite coppers in my old LS3.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
02-06-2014, 03:02 PM | #5 |
Its a good plug for a cammed setup or lower boost levels. No nitrous use. For what its worth the LS7 comes with a #6 heat range plug stock, same as the zr1
02-06-2014, 03:50 PM | #6 |
Drives: 2010 aqua blue SS/RS M6 Join Date: Feb 2010
Yes I am running the ls9 myself, a step colder then stock. They make a difference.
10.91 at 122 H/C stock block N/A
02-06-2014, 05:46 PM | #7 |
Drives: 1994 1LE / 2006 Z51 Corvette Join Date: Jul 2009
It isn't quite a full heat range colder...maybe 1/2 step but close.
I see zero issues with a copper plug in the cars other than having to change them every 15-20k miles. Honestly there isn't much better conductor of electricity than copper. Sometimes a colder plug will allow you to run a little more timing, sometimes help prevent detonation when under a heavy load like towing or racing. For a daily driver...it isn't something you have to do...nor is it going to make 100000 more HP by changing the plugs. |
02-06-2014, 06:33 PM | #8 |
I'm running the NGK TR55 with my cam/bolt-on setup. So they are just a little colder than stock. I changed them out at 15000 - just because. They looked great and could have run longer. But a set of 8 only cost $24 so why not.
On a stock motor I don't think a plug one range colder is bad necessarily but I also don't see much advantage either.
02-06-2014, 06:36 PM | #9 |
Drives: 2010 2SSRS headers/CAI/tune/corsa, Join Date: May 2010
NGK TR6 plugs
That's what Livernois put in mine with only headers intake and tune. So how many miles should you go between changes?
Stainless works headers/cats Roto fab CAI /
Corsa install and tune Livernois TSW Nuburgring 9 &10" x 20 on Invos (315 & 275 ) JL Audio XD400/4 amp Pfadt trailing arms & tie rods sway bars. pedders street 1 package. ,Hurst short throw shifter With bronze bushings . |
02-06-2014, 08:42 PM | #10 | |
NGKs tech literature say that for every 100 hp you modify over stock, to go one heat range colder. I personally just run the hotter plug, unless reading the plug indicates that I need a colder one (I.e. porcelain cracking). Less risk of fouling out, especially without a catch can. |
02-06-2014, 08:55 PM | #11 | |
And, FWIW, I'm an NGK fan over delcos. I'll have TR6IX (iridium TR6) plugs in mine next week to go with the Maggie. |
02-07-2014, 07:49 AM | #12 |
[QUOTE=2012LS3VERT;7401352]Read them at around 15k.
Thanks
Corsa install and tune Livernois TSW Nuburgring 9 &10" x 20 on Invos (315 & 275 ) JL Audio XD400/4 amp Pfadt trailing arms & tie rods sway bars. pedders street 1 package. ,Hurst short throw shifter With bronze bushings . Last edited by skar; 02-07-2014 at 06:18 PM. |
05-24-2016, 12:27 PM | #13 |
Build,Race,Break,Repeat
Drives: 2010 Red Jewel Camaro 2SS 6M Join Date: Dec 2012
I was told to gap mine to .030 (tr6)
30 thou. Sound correct? |
05-24-2016, 12:41 PM | #14 |
