dave@hennessey
Old 07-21-2017, 05:57 PM   #1
SSallday
SSallday's Avatar
Drives: ‘18 ZL1 / ‘22 ZLE
Haze & Marring after using FG400
My car was in need of a detailing so I took out the equipment. Everything looked great until I held an LED light over the paint. I saw that there was some marring and a haze in the paint. I was using a Meguiars mf pad with some Menzerna FG400. Also, I tried using a Buff and Shine orange pad, but that didn't work. From what I researched, it looks like a Menzerna polish will correct that. I'll spend the money to get it, but I want to make sure that it will fix the problem since their products are a bit of money. What should I do?
SSallday is offline   Reply With Quote
Old 07-22-2017, 03:03 PM   #2
Joe M 2012 2SS
Joe M 2012 2SS's Avatar
Drives: 2012 2SS
Haze after compounding is normal. You need a finishing polish to clean up the haze/marring caused by the compound.
Lot's of different finishing polishes you can use. Menzerna makes good polishes. A Tangerine Lake Country Hydrotech pad works great with finishing polish for compounding haze removal.
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles.
Joe M 2012 2SS is offline   Reply With Quote
Old 07-22-2017, 03:25 PM   #3
GVA 45TH 2SS
KNGTFALL
GVA 45TH 2SS's Avatar
Drives: 2012 2SS 45th edition
MF pads are more aggressive than foam of the same color, so you will notice more marring.
I use hexlogic Orange pads with FG400
Followed by SF 3800 to remove the compounding micro mars that can happen by using 400.
GVA 45TH 2SS is offline   Reply With Quote
Old 07-23-2017, 02:39 AM   #4
SSallday
SSallday's Avatar
Thanks guys, I appreciate the advice. I ordered some SF3500 to see if that would correct it
Old 07-25-2017, 07:45 AM   #5
MyLocalDJ
MyLocalDJ's Avatar
Drives: 2015 2LS
I just did one of my cars this past week starting with wet sanding all the way up through the wax. I used the Meguiar's Ultimate products mostly. (I know its not a Camaro, but it still turned out great.)
I had just had the car repainted about 2 weeks ago and there was a lot of hazing from their buffing and trash still in the paint. Take your time and work it. A good random orbital like the Porter Cable 7424 will also be your best friend!
MyLocalDJ is offline   Reply With Quote
