TireRack
Old 01-17-2014, 08:49 AM   #1
markas214
markas214's Avatar
Drives: 2012 2SS/RS L99 SIM convertible
best headers for max clearance on 1" lowered
I am lowering my vert 1" with Hotchkiss. Which headers have the best clearance? I would be looking at 1 7/8 or 1 3/4" headers and high flow cats.
markas214 is offline   Reply With Quote
Old 01-17-2014, 08:55 AM   #2
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Pfadt headers seem to have the best clearance. They are the only headers that can be installed on the ZL1 without cutting the under tray. However, with 1 inch springs you not really setting yourself up for clearance issues with any of them.
Apex Motorsports is offline   Reply With Quote
Old 01-17-2014, 10:14 AM   #3
Kiernans88
TRI-COUNTY CAMARO TAMPA
Kiernans88's Avatar
Drives: 2011 Camaro SS/RS IBM M6
I'm lowered 1.25" and the only time my LT's bottomed out was on a long speed hump where I was probably going a little too fast. It has never happened since. As long as you're careful, ground clearance shouldn't be too big of an issue @ 1" lower.
FSP Custom Grind Comp Cam - K&N CAI - 1 3/4" BBK Full Length Headers - BBK High Flow Cats - Kooks 3" Street Screamer Catback - VMax TB - Barton Short Throw - BMR Suspension/Bushings - Eibach Pro-Kit Springs -Tuned by Florida Speed and Power (FSP)
Kiernans88 is offline   Reply With Quote
Old 01-17-2014, 10:17 AM   #4
caverman
caverman's Avatar
Drives: '69 SS Convertible
Pretty much any of the major Mfg should be fine. I have KOOKS with HF cats and my car is lowered about 1.5". I've only barely scrapped over a large speed bump maybe two times. In general I don't have an issue with my headers.....now my front spoiler is another issue.
Also, if you're buying new you might as well get 1 7/8" so you have room to grow if you need down the road. Nothing wrong with 1 3/4" though...from which I can attest.
-2010 Camaro 2SS | M6 | VR w/White Stripes | 1 3/4" KOOKS - 3" Magnaflow | LPE 3.91 gears | ADM tuned | Halltech w/ADM Scoop | Spohn/BMR Trailing Arm/Toe Rod | BC Coilovers| Pedders FE4 ZL1 swaybars | Cradle/Diff/Radius Rod bushings | VMax TB | Morimoto Projectors | MGW shifter | Red Calipers
Build Journal
caverman is offline   Reply With Quote
Old 01-17-2014, 01:03 PM   #5
grocerygetter
instigator
grocerygetter's Avatar
Drives: 2020 6.2 Trail Boss, 2022 XC90
mine clears great...pfadt springs...Kooks with no cats.
-John S.
grocerygetter is offline   Reply With Quote
Old 01-17-2014, 03:03 PM   #6
davidcroft
Sellin Chevy's since '06
davidcroft's Avatar
Drives: 18ZL1 02Z-28
Are you a previous Mustang owner? The reason I ask, my lowered Mustang dragged my X and H pipes everywhere. The 5th Gens don't have anywhere near those clearance issues.
'19 Z06-7Speed and lowered on stock bolts
'02 Z28-Kooks true dual headers/TSP heads&cam/full suspension & Kmember sub40K orig miles. https://youtu.be/h6faSdcvNew
TRADED!'17 ATS-V Coupe w/ Carbon Black pkg https://youtu.be/GH_t-R-TJV0
SOLD! '18 ZL1 Mosiac Blk
SOLD!'16 SS Sedan-Forgestars/ARH/rotofab
TRADED!2014 SS Sedan
SOLD! 2013 Blue Ray1SS/1LE 1of20.
TRADED! 2012 White 1SS/RS
davidcroft is offline   Reply With Quote
Old 01-17-2014, 03:06 PM   #7
Apex Motorsports
Or maybe 4th Gen SS.
Old 01-17-2014, 03:08 PM   #8
ssmike
BL1ZZRD
ssmike's Avatar
Drives: '16 Camaro 2SS, '20 Equinox Redline
Like caverman said, pretty much all the major brands hang down about the same. I'm lowered 1 1/2" with Dynatech's and only scrape the dirt at times at car shows when they make us park on the lawn. Also, don't even consider 1 3/4" go with 1 7/8 primaries!
ssmike is offline   Reply With Quote
Old 01-18-2014, 08:09 PM   #9
SteveDoten@ARH
SteveDoten@ARH's Avatar
Drives: 2010 SS, (ARH/Farks 8sec car)
ARH
SteveDoten@ARH is offline   Reply With Quote
Old 01-18-2014, 10:20 PM   #10
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
Yes, my 4th gen scraped on everything with Hooker LT's and a Eibach pro kit. My 5Th gen SS is lowered 1" with Kooks and I have never scraped anything. I mean NOTHING. The headers only sit about 1/2" at most below the frame. To put it into perspective. The 5th gen has 4x4 truck clearance in comparison.
BLK/BLK 1SS/RS Ordered 11-01-2009 Took delivery 12-22-2009. Heads/cam/converter/bolt ons. SOLD Feb 2015 to fund 6th gen LT1 SS with 8L90E.
VADER SS L99 is offline   Reply With Quote
Old 05-12-2014, 06:01 PM   #11
camaro500
camaro500's Avatar
Drives: 2017 Jaguar F Type R Tuned 498awhp
I have bmr 1 inch drop and dynatech headers and I scraped once on a big speed bump because I went straight over it. I think if you can take it slightly at an angle (diagonal) you can avoid this.
JRE cammed w.full bolt ons 444rwhp/422rwtq SOLD
''Life moves pretty fast. If you don't stop and look around once in a while, you could miss it.'' - F. Bueller
camaro500 is offline   Reply With Quote
Old 05-12-2014, 06:02 PM   #12
Bo White
Bo White's Avatar
Drives: 2015 Summit White 2SS 1LE
Im 2" lowered driving on Alabama roads with cheapy OBX headers.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Bo White is offline   Reply With Quote
Old 05-12-2014, 10:30 PM   #13
Hard Parker
OMWTFYB
Hard Parker's Avatar
Drives: ZL1
lovin your sig pic btw Bo
2017 Camaro 1LE Nightfall Gray Metallic RIP ☠️☠️☠️
2017 Camaro ZL1 Black Exposed CF|Sunroof|6 Speed
Click HERE to follow my build!!
Click HERE to follow me on Instagram
#savethemanuals
Hard Parker is offline   Reply With Quote
Old 05-13-2014, 04:53 PM   #14
MarylandSpeed
Drives: 2012 ZL1 & 2010 2SS/RS
My car is lowered with Kooks and we have no issues. If you want the hook up, call us @ the number in the sig.
MarylandSpeed is offline   Reply With Quote
