04-17-2016, 08:30 PM | #1 |
Drives: 2017 SS 1LE Join Date: Oct 2015
NT01 WTF
I've been running the OEM Goodyear F1G2 on my 2015 1LEe for track days.
I switched to Nt01 Nittos and lap times were 2-3 seconds slower on 2 different tracks. I thought these would be faster than the OEM Goodyears. FYI, I have tracked Camaros and Vettes for 15 years, I have tried Hoosier/Hankook/BFG R comps with lots of success. Maybe these tires will get better with more wear but they don't have the grip, I can carry more speed in some sections of the track on the Goodyears and they just howl driving down the road. Maybe a got a bad set of tires Thanks for any feedback for those of you who have tracked NT01's. |
04-17-2016, 08:32 PM | #2 | |
Drives: One of the baddest handling Gen 5s Join Date: Feb 2011
04-17-2016, 09:13 PM | #3 |
04-17-2016, 09:17 PM | #4 |
Lover of Speed
Drives: 2018 ZLE Join Date: Feb 2016
Did you heat cycle them correctly the first time?
Also yes, the Nt01s howl just driving down the road. I have a set from my last car and every time I drove on them I thought my transfer case was whining but it went away when I switched tires. Lastly, the Nt01s like to be hot, so try more time at the lower tire pressure and get them hot and hopefully the grip will come alive. |
04-17-2016, 09:30 PM | #5 | |
I did not heat cycle them. I tried lower pressures, they got hot and greasy and were sliding around a lot by lap 4-5, warm day temps in the mid 80's. I just can't believe they are that much slower then the goodyears. Other drivers at the track who have ran this tire couldn't figure it out either. |
04-18-2016, 09:02 PM | #6 |
Lover of Speed
Was that your first use of them then? I know with R-comps you need to get them hot for their first cycle then put them away immediately for 24hrs. This causes the molecules to reform and some other magic happens then they become like glue. I am thinking if that was your first use, it was probably that, but that first cycle is very important in order to get the tire to perform correctly. I use just pay the $15 a tire at Tire Rack for them to do that. After that I have no issues.
04-18-2016, 10:47 PM | #7 | |
I guess there is not much I can do now to help improve their grip, hopefully they'll get better when the grooves are worn down. |
04-19-2016, 12:30 AM | #8 |
04-19-2016, 07:10 AM | #9 |
04-19-2016, 08:50 AM | #10 |
Scenic City Camaro
Drives: 2022 Camaro ZL-1 /1974 Firebird 400 Join Date: Jan 2014
35 in the book is cold
2022 Camaro ZL-1, grey
1974 Firebird Formula 400, white https://www.facebook.com/groups/Camaro/ https://www.facebook.com/CRFinTN/?modal=admin_todo_tour |
04-19-2016, 12:52 PM | #11 |
Track > 1/4 Mile
When I had my Camaro I ran NT01's and thought they were like glue compared to Pilot Super Sports, Eagle F1's and Yokohama ADVAN AD08R's. I would run them at 35-36 PSI HOT, usually 27-28 COLD.
04-19-2016, 02:07 PM | #12 | |
Doesn't make sense. I tried higher pressures to see if I could improve the grip, didn't make much difference in times, but did feel less tread squirm. Maybe a bad set of tires, but I've never seen that before, only tread splicing or other issues, not lack of grip. |
04-19-2016, 03:27 PM | #13 |
Drives: '16 C7 Z51 Join Date: May 2012
Your results are very confusing for sure. I went to track with G:2s, and made a respectable 1:58.2 with them at ORP, a very technical track here. Later, I did 1:57.1 with Hankook RS-3s at the same track. NT01s are significantly better than RS-3s on other cars, so I'd think it would do at least 2 seconds better than G:2s on the same size, in contrast to your experience. One caveat for my remarks: I am still yet to try NT01s on my 1LE (but I've used them on other cars with great success).
I'm obviously not questioning your results, but trying to understand what might have gone wrong.
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD) '13 Mazda MX-5 Club (Build Thread) '17 RAM 1500 Crew Cab 4x4 Night Edition '15 Nissan Rogue S AWD |
04-19-2016, 03:35 PM | #14 | |
3. Everything the same except these tires, no mechanical or power issues. 4. They are OEM sizes: 285/30/20 5. I did not do an initial heat cvcle, I ran 7 sessions on them last weekend. Everything I've read/researched also showed that they should be faster than F1's and Rs3's and comparable with RE71R's. I called Nitto, of course they said they've never seen this problem before. Thanks for your input |
