Old 05-02-2018, 07:54 AM   #1
ZL1_Craig
ZL1_Craig's Avatar
Drives: 17 ZL1 HBM M6
Supercharger oil?
Hello everyone. My ZL1 has 5k miles on it now and was wondering if I should change the supercharger oil. What oil does it require and how much? Thanks
ZL1_Craig is offline   Reply With Quote
Old 05-02-2018, 08:01 AM   #2
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
I don't even see it listed as a serviceable item in the manual. I'm pretty sure if I remember right, that EATON makes a specific gear oil for the blower, and it's 4-5 oz.
Old 05-02-2018, 09:48 AM   #3
garfin
Resident Disciple
garfin's Avatar
Drives: 2010 CTS-V 6MN '98 Camaro SS (Sold)
Right... and there really is no need to change out the supercharger oil unless it's a very high mileage car, it has seen extreme service or new supercharger oil is necessary after replacing the supercharger. It is a closed system.
However, out of interest, I found this online but I'm not sure if this is applicable to our units.
Since these Eaton superchargers do not have an oil drain plug. You normally will have to drain the oil from the oil fill hole. We find that using an old spay bottle works very well and since most people have them laying around the house it does not require you to make a special trip to the store. You can also use a Syringe or a baster depending on what is available to you.
Be careful and do NOT overfill the supercharger with oil. If you over fill the supercharger oil beyond the recommended oil requirements, it can cause the oil to expand and leak out of the supercharger seals. If this happens you will need to get a rebuild performed.
Only use the GM supercharger oil. Nothing else. They come in 4 oz. bottles and the capacity in the unit is 6-7 oz.
Best regards,
Elie
2010 Cadillac CTS-V 6MN Thunder Gray
1998 Camaro SS # C079 SOLD
garfin is offline   Reply With Quote
Old 05-02-2018, 10:52 AM   #4
Rlhay2
Rlhay2's Avatar
Drives: 2017 ZL1
Recommended interval is 100,000 miles.
Rlhay2 is offline   Reply With Quote
Old 01-03-2021, 11:56 AM   #5
Daddy_OZL1
Drives: 2020 Chevy Camaro ZL1
Does anyone know the GM part number for this type of oil
I see two different numbers on Amazon ?
Daddy_OZL1 is offline   Reply With Quote
Old 01-03-2021, 12:10 PM   #6
puppykat33
puppykat33's Avatar
Drives: Black 2019 ZL1 M6,
here you go
2019 Black ZL1, M6, CF Hood and Dash, Nav System, ZL1 Addons rock guards and lift points, Michelin Pilot Sport 4S, DD Smoked Marker Lights, Ceramic window tint, Gtechniq 9yr ceramic coating. JL Audio stealth box 12W6, Dyanamat trunk, Dead pedal cover, Soler TB/TC, Green Filter, Carbon-fiber Borla S-Type
puppykat33 is offline   Reply With Quote
