Old 07-02-2017, 10:03 PM   #1
KyleL
Drives: Slow
Over rev
So a little while ago I tried to downshift to 4th and grabbed 2nd by mistake and saw the revs peg out the tach (7500+ rpm) for a split second. The car is bone stock so if I have to take it in it's no big deal. No cel's at the moment. I know at 6600 it cuts fuel so what damage is caused by over revving a completely stock motor? What safeguards are in place to help protect an m6 from a mishap at the track like I had?
2016 Toyota 4Runner
2017 Camaro ZL1
KyleL is offline   Reply With Quote
Old 07-02-2017, 10:28 PM   #2
Inspector 17
I love crepes
Inspector 17's Avatar
Drives: 2017 ZL1 NGM A10
Hitting the Rev limiter or high revs for a short time isn't going to do any significant damage. However, I would certainly avoid prolonged high RPMs to avoid unnecessary wear or damage. The rev limiter is there to protect the engine and keep from damaging it as best as possible. Downshifting into too low of a gear is obviously another story. I don't know that there is much that can be done to prevent damage in this scenario except cutting or limiting the fuel to prevent the RPMs from going any higher.
Inspector 17 is offline   Reply With Quote
Old 07-02-2017, 10:34 PM   #3
KyleL
Drives: Slow
This was for less than a second, it just surprised me that the revs shot to over 7500 when there's supposed to be safeguards in the Ecu to save the engine. I mean, I can't leave a light without it falling down to protect the engine/drivetrain, surely it shouldn't have hurt the car?
2016 Toyota 4Runner
2017 Camaro ZL1
Old 07-02-2017, 10:40 PM   #4
unavailablezl1
unavailablezl1's Avatar
Drives: 2019 Silverado Z71 6.2L A10
I would assume it should have cut power at 100 rpm above redline, which seems to be a fair observation. My M3 and Mustang GT both cut power and the entire dash light up in red on the Mustang. Quite alarming.
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's.
Past Rides
2017 M6 Camaro ZL1 Hyper Blue
2016 M6 GT350 White with blue strips
2014 M6 Mustang GT Premium Track Pack Ruby Red
2012 M6 M3 Melbourne Red Metallic
unavailablezl1 is offline   Reply With Quote
Old 07-02-2017, 10:40 PM   #5
ChevyRules
Drives: 2021 Tesla Model 3 LR
The ECU won't protect you from the money shift. Nothing the ECU can do when the engine is mechanically spun up to 7500 RPM due to the vehicle speed+too low of a gear selected.
ChevyRules is offline   Reply With Quote
Old 07-02-2017, 10:43 PM   #6
KenB925
Drives: Raptor
not much the computers can do to protect the car from a money shift, totally mechanical. The rear wheels are turning the engine, cutting fuel or spark does nothing.
That said, if the car is acting fine, it's probably fine
KenB925 is offline   Reply With Quote
Old 07-02-2017, 10:45 PM   #7
utsteve98
Drives: 2018 ZL1 1LE, 2017 Ford Raptor
Nothing can protect from this scenario. Sure it can cut fuel but can't make an engine not over rev if too low a gear is selected. If you're doing 100 and you downshift to 2nd then the gear ratio may be shooting your engine speed up to 8k or more. However if your engine didn't blow at that moment and it runs smooth still then I imagine nothing is wrong.
utsteve98 is offline   Reply With Quote
Old 07-02-2017, 10:46 PM   #8
KenB925
Drives: Raptor
Thumbs up
looks like you were posting while i was typing
Old 07-02-2017, 10:49 PM   #9
nicktechla
nicktechla's Avatar
Drives: 2012 Porsche 911 Turbo S
ahh never heard money shift. i just heard Mechanical Over-Rev before.
IG: 2fast2nick
-- Current --
2012 Porsche Turbo S - PDK - Basalt Black Metallic
-- Past --
2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101
2015 Mustang GT PP - Whipple Supercharger
nicktechla is offline   Reply With Quote
Old 07-02-2017, 10:55 PM   #10
KyleL
Drives: Slow
Yeah it was definitely a money shift. I can honestly say it hasn't happened in the last 20yrs but i made it home just fine and didn't throw any codes so I guess it'll be fine. I guess it hasn't happened to anyone else yet lol
2016 Toyota 4Runner
2017 Camaro ZL1
Old 07-02-2017, 11:01 PM   #11
ChevyRules
Oh and to answer the question of what damage can be done to the engine when you end up money shifting it.... When the engine is over rev'd, it can cause valve float and can result in the valves and pistons coming into contact with each other causing major damage to the components.
The rev limiter is not the engines true absolute limit before valve float can occur. There is some buffer room built in obviously for further protection. But if the car is still operating normally, think you lucked out and shouldn't be any damage to the engine.
Old 07-02-2017, 11:37 PM   #12
PinHead
Drives: Duramax
CONGRADULATIONS
You passed the Gen6 Valve Train Over Rev Beta Test(without breakage ver1).
Engines have a safety margin built into them just for situation like these.
Sounds like the worst that probably happened is that he stressed a valve spring by the mechanical over Rev.
You can take in to a private shop have them check the ECM for Max RPMs Data and Duration.
If you have some Extra $$$, They can also pull a pair of valve strings off and test them, (if it would make you feel better).
(Btw the Money Shift only occurs when you're seated in the front row directly in front of the Brass Pole with a fist full of $$$)
If it was for a short duration you should be Ok
Here's a more in-depth explanation
http://performancedevelopments.com/w...rev-really-is/
PinHead is offline   Reply With Quote
Old 07-02-2017, 11:58 PM   #13
Evolvedx27
Evolvedx27's Avatar
Drives: 2017 ZL1
Pretty sure that red light is a shift light...
Evolvedx27 is offline   Reply With Quote
Old 07-03-2017, 12:31 AM   #14
KyleL
Drives: Slow
Drove it back home a few minutes ago and it ran just fine, just have a rattle now coming from behind the gauge cluster. So it looks like I'll take it in to the dealer my friend works at so I can have him take a look at it. I'm guessing the excess vibration from the motor over revving caused something to become a-loose under the hood or behind the cluster
2016 Toyota 4Runner
2017 Camaro ZL1
