Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > Engine Internals
Old 04-27-2023, 12:39 PM   #1
RPIDon
RPIDon's Avatar
Drives: Camaro
Send a message via AIM to RPIDon
Roto-fab Air Intake System W Sound Tube Delete ROF10161050 For 2016-2023 Camaro Ss
Sixth-generation Camaro owners take a look at this cold air intake system. If you are one of those Camaro owners who demand the best and will not settle for the so-so then you definitely want to top list this Roto-Fab cold air intake. Not only is this system built in America that are also built to the strictest quality standards of any Camaro cold air intake. If all of this sounds good to you but in reality, you're in this for the performance, then Roto-Fab is what you want, known to produce a horsepower of at least 20 this intake is sure to please.
Roto-fab is a leader in high-performance air intakes systems. This intake has been built without compromise. Roto-fab uses every available square inch of underhood space to maximize performance and power. This package delivers great performance and awesome sound without a tune or any modifications to the vehicle. This intake has an oiled filter and sound tube delete option that deletes the sound tube assembly from the inlet elbow to the firewall. The package is well designed and boasts a smooth inlet elbow with no sound tube provision and has a block-off plate for the sound tube entry in the firewall.
Roto-fab uses an open-top design that effectively joins the hood which increases air box volume and provides all the benefits of a lid. Roto-fab only uses top quality components from top to bottom including high gloss silicone hose couplers, stainless steel fasteners, stainless steel hose clamps, molded-in inserts for the air box and high-quality filters designed to last a lifetime. This package of air intake with a dry filter is sure to deliver great performance and awesome sound without any major modifications to the car. Installation is easy as it comes with a step-by-step color instruction booklet.
RPIDon is offline   Reply With Quote
