Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > Engine Internals
Old 04-21-2023, 08:52 AM   #1
southerncarparts
southerncarparts's Avatar
Drives: 2009 Corvette Z06
Ss K&N Typhoon Cold Air Intake 69-4534TP For 2016-2023 Camaro
Get the most our of your Camaro SS with this K&N Typhoon Cold Air Intake kit. Dyno tested to add 18.2HP to a stock 6th Gen Camaro SS. The Camaro SS already performs like crazy, but a little extra HP never hurts!
The K&N 69-4519TP Typhoon air intake system is a free-flowing, mandrel-bent aluminum tube air induction system designed to fit some Chevrolet Camaro SS models. The restrictive factory air filter and air intake housing are replaced by the K&N Typhoon air intake which is designed to dramatically reduce air flow restriction as it smoothes and straightens air flow. This allows your engine to inhale a larger amount of air than the factory air intake. More air means more usable power and acceleration throughout the engine’s RPM range. The 69-4519TP air intake comes with a chrome topped K&N high-flow air filter and a heat shield that installs into the previous air box space. Air is directed through the intake tube into the engine’s throttle body for a guaranteed power gain. The intake tube has a chrome-like finish that's made to last and accommodates the factory mass air sensor and a replacement silicone crank case vent hose. The oversized cone shaped air filter can be used for up to 100,000 miles before servicing is needed depending on driving conditions. This air intake is relatively easy to install usually in 90 minutes or less using existing factory mounting points. The tools needed are a couple of screwdrivers, a ratchet set and several wrenches. Some Typhoon air intakes are not legal for sale or use in California and other states adopting California emission standards while others are CARB exempt and 50 state legal. Check the K&N catalog or website for vehicle applications and specific CARB status for each vehicle and air intake.
APPLICATION: 2016, 2017, 2018, 2019, 2020, 2021, 2022, 2023
CAMARO
southerncarparts is offline   Reply With Quote
