Old 07-04-2012, 07:52 PM   #43
ShnOmac
ShnOmac's Avatar
Drives: 2006 Silverado SS, 2009 G8 GT
Originally Posted by meissen View Post
Only a handful of people really know what's going in the 6th generation Camaro and none of them are going to spill the beans.
It's fun speculating though......
ShnOmac is offline   Reply With Quote
Old 07-04-2012, 07:53 PM   #44
FenwickHockey65
General Motors Aficionado
FenwickHockey65's Avatar
Drives: 2023 GMC Canyon, 2020 Colorado
Originally Posted by shrinkdoc View Post
If our cars were 300lbs less the v6 would be turning mid 13s in stock form. With the now available bolt on mods we would be at high 12s to low 13s.
The SS would in the low 12s in stock form. Our v6s pull nicely as well as cruise at highway speed at 17 or 18k rpm. A 4 cyl I suspect would would require hi rpm and buzz with lots of unecesary shifting!!
Not with a turbocharger. You'd have peak torque available at early RPMs, persisting through most of the engine's power band.
2023 GMC Canyon Elevation
2020 Chevrolet Colorado W/T Extended Cab (State-issued)
Old 07-04-2012, 08:14 PM   #45
cbass
Drives: .
OK...I have been anal-lyzing and I predict that the base camaro v8 will be the 5.3 and the 6.2 will used specifically in the ZL1 after being reworked to produce about 600+hp in stock form. The 5.3 DFI will produce about 420hp in stock form. There will be an optional 3.6 twin turbo option producing 400hp.
I think if they go with a DI 5.3L V8, then it will produce more than 420 hp. The 5.0L coyote engine without direct injection right now is capable of 420 hp. A direct injected 5.3L v8 should be capable of more than that. It should at least pull off 450 hp, but I think it will produce more. I am not sure if it will reach 500 hp, but 470 and 480 should be possible. It will depend on how much CARB fuel economy regulations will cut into power output.
cbass is offline   Reply With Quote
Old 07-04-2012, 09:49 PM   #46
KEEP RT
Wonderfully Awful Idea
KEEP RT's Avatar
Drives: 2010 2SS/RS
I'm still sticking with my 5th Gen.
KEEP RT is offline   Reply With Quote
Old 07-04-2012, 10:12 PM   #47
fielderLS3
fielderLS3's Avatar
Drives: 2016 Mazda6, 2011 Mustang 5.0
Not unless it goes DOHC as well.
My guess is the GenV used in the Camaro/Corvette will be bigger than 5.3L if it stays 2 valves/cyl.
2022 1SS 1LE (Arrived 4/29/22)
"The car is the closest thing we will ever create to something that is alive."
. 2022 1SS 1LE (Coming Soon)
fielderLS3 is offline   Reply With Quote
