05-25-2021, 06:25 AM | #29 |
i think that you are good,but get an overflow bottle.without it air can be sucked into the system when the car cools,and that can lead to air pockets which you have just experienced.
05-25-2021, 10:26 AM | #30 | |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. Last edited by CamaroCracka; 05-25-2021 at 01:48 PM. |
05-25-2021, 01:06 PM | #31 |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
The rubber hose can be purchased cheaply at an auto parts store.
An overflow bottle can be anything if you don't have the time and money to install the exact old one. For example use something you have around the house. It doesn't need to seal tight and won't work properly if it was totally sealed anyways. Just sealed enough to keep out dirt so if the hole is too big at the top stuff some plastic bags around it. You could use a couple zip ties to hold it right side up and in place. I don't recommend glass because it is harder to hold onto and would fall and break on the road. None of your old Corona bottles Just make sure the hose goes to near the bottom of the bottle to suckup the liquid when the engine cools, like a straw in a cup. No fastfood cups either they deteriorate too quickly. No zipties? Duct tape works too. Electrical tape tends to melt underhood and not stay holding so good. Growing up poor helps you think creatively |
05-25-2021, 02:17 PM | #32 |
GrINned & JUICEd
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1 Join Date: Nov 2009
Next time be certain the radiator was full and measure how much came out. The same amount should go back in. If not, then there is an air pocket(s) that is in the cooling passages of the engine. The cooling system is sealed. As the engine heats up, the thermostat opens to allow additional coolant flow. The coolant continues to heat up and expands. Thus creating pressure. The radiator cap has a pressure rating, say 16 psi. When the pressure in the system exceeds that value, the radiator cap, which has a spring set to 16 psi, will open and release coolant into the reservoir/overflow tank to relieve pressure. When the engine is turned off, the coolant contracts and the rad cap allows coolant from the overflow back into the cooling system. In your case, without an overflow, the rad cap would open and the coolant would have just dumped on the ground. And air sucked back into the system when cooling. This cycle would have been done enough times so that your radiator would now be low on coolant. So a portion of your radiator is filled with air. Air is compressible, liquid is not. So as the engine would heat and coolant would expand, the air would compress in the radiator and therefore no coolant would pushed out the rad cap. I'd bet if rad cap was removed before draining, the coolant level would not have been to the top.
05-25-2021, 07:04 PM | #33 | |
Drives: 2015 Camaro RS Join Date: May 2021
05-25-2021, 07:09 PM | #34 |
How can I figure out at what temperature my thermostat opens? Putting the overflow basically helps with not losing coolant or sucking in air right?
05-25-2021, 07:18 PM | #35 |
Thanks! I was mostly paranoid about engine damage but at the same time there wasn’t any smoke or steam coming from under the hood
05-25-2021, 07:40 PM | #36 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
I think it is a moot point from this point forward. Bottom line, things won't change till you get a reservoir. That should be priority.
2010 Inferno Orange 2SS/RS M6 Black Leather, Sun Roof, OBX Headers, Borla touring axle back, Cold Air Inductions CAI , non synthetic fluids, BMR total bushing upgrade/1" lowering springs, DSE 32mm rear sway bar. GM fe4 shocks/struts/LCA's, AAM 3.91 diff, Vertini RFS1.8 20x9 +30. Conti ExtremeContact Sport 275/35/20. sjm autoprod ABL dash kit. Mike Norris tuned 413/419.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
05-25-2021, 07:40 PM | #37 | |
05-25-2021, 07:47 PM | #38 |
05-26-2021, 01:42 AM | #39 |
GrINned & JUICEd
Yes to all the questions you asked in my quoted statement. I'm confident you under stand how the system operates now. Your thermostat is fine, imo. Get the oem overflow bottle. On the 3.6 LFX I have, different vehicle, there is no cap on the radiator. The pressurized cap is on the coolant overflow. Same principle.. Looking at replacement rads for your car, it shows a rad cap. Fortunately I had no issue when I did a coolant flush a few months ago. Get an overflow bottle and fill it up about 2/3. Top off rad. Run the car with the heat on to purge the heater core. Put gloves on and squeeze the upper rad hose. Do this till the upper hose gets warm or the coolant wants to spill out of the radiator, add if necessary. Then replace the rad cap. Also light revs occasionally from 1500 to 2000 rpm during the entire process. Keep squeezing hose for about 10-15 minutes after replacing cap. If temp hits about 235F. Shut it off and let cool. Take cap off after cooling and check level and overflow level, replace cap. Ride around locally in case of overheating. Run the car slightly hard after warming up to get any air out of the engine. Let cool. Check levels. Keep an eye on the levels for a few days. Should self bleed/purge as well, if not severe. My Camaro was a real bear to bleed, different engine though. Careful of the belts and your clothing and hair. Did you use orange coolant? Dexcool. BTW, the coolant overflow bottle will have an overflow hose that will flow to the ground if there is too much coolant in the overflow bottle.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
05-26-2021, 10:17 AM | #40 |
If it's stock, it's 192* They do sell an number of variations between 192 and 160, but the only way I know to tell is take it out and put it in hot water with a thermometer. I would not worry about when it opens. These cars are designed to run in the low 200s. Even racers argue over the value of earlier opening thermostats.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
Tags |
2015 camaro, coolant temperature, overheating, reservoir |
