Go Back   CAMARO6 > Members Area > Ask the Camaro Team
Old 05-12-2023, 01:40 PM   #1
T D
T D's Avatar
Drives: 2010 Camaro SS
Cool Air con
My a/c is not functioning atm.
I've had an auto electrician up to have a look, and his computer came up with the following:-
1. Evap solenoid circuit faulty .
2. Ac refrigerant circuit low voltage pressure sensor.
3. Heater control circuit faulty.
He thought that I should get the gas refreshed/refilled and then get no 2 sorted, and it should get the a/c working again.
I've done both of them, but still no joy.
Can somebody advise me which parts I should buy to cure the two other faults please?
I've looked at lists of parts for the system, but there's so many and I don't want to buy things that I do not require.
Many thanks in anticipation.
T D
You're never alone with a schizophrenic
Ian Hunter 😎
T D is online now Report Post Edit/Delete Message Reply With Quote Multi-Quote This Message Quick reply to this message
Old 05-04-2023, 12:30 PM #2
T D
T D's Avatar
View My Garage
iTrader Rating: 0 reviews
TD😎
Ian Hunter 😎
T D is offline   Reply With Quote
Old 05-13-2023, 01:36 PM   #2
h422694
h422694's Avatar
Drives: '16 Z06 7 Spd, 2024 High Country HD
T D
The Camaro Team no longer exists. You'll probably get more responses if you post this in the General section of the forum.
h422694 is offline   Reply With Quote
Old 05-14-2023, 01:16 AM   #3
T D
T D's Avatar
Originally Posted by h422694 View Post
T D
OK Buddy , thank you.
Ian Hunter 😎
