TireRack
Old 04-29-2013, 05:46 PM   #1
kosmo
Finally Satisfied
kosmo's Avatar
Drives: 2017 Hyper Blue 2SS M6
DIY Ghosted Side Markers
I purchased and installed the Oracle LED side markers last summer. I was too cheap at the time to buy them ghosted so I just added smoked covers and convinced myself that they were good enough. After seeing photos of others who have them ghosted I have decided to try and paint them myself. Of course I have to perfect my technique before I do them for real so I decided to practice using one of the OEM ones I had removed.
I am posting this for two reasons. First to get opinions on how the test piece turned out and second I am looking for any advice from others who may have already done it. The process I used was as follows.
1. Wet sanded the marker with 2000 grit sandpaper.
2. Applied 2 coats of plastic adhesion promoter.
3. Applied 1/8" wide detail tape that I will use to cover the led strips
4. Applied 3 coats of paint (CGM)
5. Removed the tape
6. Applied 2 more coats of paint
7. Wet sanded to blend in the area around where the tape was.
8. Applied 1 more coat of paint
9. Applied 3 coats of clear coat
Here are a few photos of the outcome. The last one I used a small flashlight to make sure the light would only show through the area I had masked off.
kosmo is offline   Reply With Quote
Old 04-29-2013, 05:50 PM   #2
Tyler360
Tyler360's Avatar
Drives: 2011 Camaro 2SS/RS
I would say it turned out pretty decent! Good job!
Tyler360 is offline   Reply With Quote
Old 04-29-2013, 06:03 PM   #3
UF4LIFE102SS
Treasure Coast Camaro 5
UF4LIFE102SS's Avatar
Drives: 2010 2 SS
Good job on the paint.
UF4LIFE102SS is offline   Reply With Quote
Old 04-29-2013, 08:18 PM   #4
camaro_RS
Emerald Coast Camaros
camaro_RS's Avatar
Drives: A lot of show, not much go.
Looks really good for DIY!
-White Mary Jane....build thread [COTW 6/11/12] :
camaro_RS is offline   Reply With Quote
Old 04-29-2013, 09:02 PM   #5
kosmo
Finally Satisfied
kosmo's Avatar
Thanks guys! Will be doing it for real this weekend and will post pics when done.
Old 04-29-2013, 09:30 PM   #6
cyberLS
cyberLS's Avatar
Drives: 2010 Cyber Grey LS
willing to sell the oem painted ones?
cyberLS is offline   Reply With Quote
Old 04-30-2013, 07:07 PM   #7
kosmo
Finally Satisfied
kosmo's Avatar
I actually only painted one. The rest are in their original condition.
Old 05-04-2013, 12:26 PM   #8
kosmo
Finally Satisfied
kosmo's Avatar
Well I did them for real last night. Here some photos of the progress and the results. Not bad if I say so myself
Old 05-04-2013, 12:38 PM   #9
camaro_RS
camaro_RS's Avatar
Looks great!
Old 05-04-2013, 12:41 PM   #10
UF4LIFE102SS
Drives: 2010 2 SS
Old 05-05-2013, 02:40 AM   #11
IPT
Drives: '02 Trailblazer, '12 Camaro 2SS/RS
nice job!
IPT is offline   Reply With Quote
Old 05-05-2013, 03:37 AM   #12
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Do you mind saying what primer and clear coat you used on them?
Click Picture for Build Thread
lscamaro is offline   Reply With Quote
Old 05-05-2013, 01:18 PM   #13
kosmo
Finally Satisfied
kosmo's Avatar
Ordered plastic adhesion promoter, paint and clear coat from automotivetouchup.com.
Old 05-05-2013, 01:26 PM   #14
menendez1293
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
Looks pretty good
