10-17-2017, 05:18 PM | #1 |
Drives: 2015 2SS Join Date: Aug 2017
Longevity and the A8 transmission?
10-17-2017, 05:47 PM | #2 |
Drives: 2017 2SS Summit White Camaro M6 Join Date: Mar 2012
Buying a manual has helped me!
10-17-2017, 06:20 PM | #3 |
Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
Its like GM seems to think that clunks, slamming into gear, and other rough shifting dosent matter. My 8L80 does the same things. Downshifting while breaking it will sometimes clunk bad on the I think 4-3. The 3-4 is usually way harder than it needs to be. The worst part about it is the inconsistency.
As for you're question, even though it feels like over time it would fatigue and break parts, I wouldn't worry about it. I think the combination of the backlash and slop GM builds into the gears and the tuning they do that dosent emphasize drivability causes them to seem so unrefined and undividable. Ive driven, 4L60's, Allisons, and 6L80s that have these exact same characteristics, but I may have not driven long enough other transmissions in cars made by other manufactures to really see if they have the same problems. For as stiff a chassis and quite as the cabin is in the 6th gen, you can really notice the bad shift quality and driveline slack and it ruins the whole experience. |
10-17-2017, 07:04 PM | #4 |
Drives: 2018 2SS Join Date: Aug 2017
I chalk it up to the 80-20 rule. Get 80% right and 20% good enough not to cause any SAFETY problems. Mine shifts flawlessly most of the time - probably 95% actually - and when accelerating it's amazing.
However, it is not perfect and I have no expectation that it should be. These are very complex components with intricate electronic management. I have other modern cars with auto transmissions that have their quirks too. Ever since they went beyond 4 gears and added all the fuel management algorithms, they sometimes act strange hunting for the right gear. It's a balancing act responding to driver input and trying to adhere to the almighty EPA mandates. They will never be perfect but I enjoy the heck out of mine...that's all that matters to me. If it's enough to make you worry and seems like a problem to you, take it to the dealer and have it checked. Longevity...only time will tell. I haven't seen a lot of 2016 owners with higher mileage raising big concerns, but it may still be too soon. |
10-17-2017, 09:30 PM | #5 |
10-17-2017, 11:35 PM | #6 |
Drives: 2017 1LT RS V6 A8, 2020 Fusion Join Date: Jun 2017
I'm pretty sure these are software issues that could be tuned out with "a proper" reprogramming (which unfortunately will void the warranty.)
10-18-2017, 07:18 AM | #7 |
Drives: 2SS, Hyper Blue, Sunroof, NPP, MRC Join Date: Jul 2016
Multi Displacement seems to be the biggest issue with not only GM but every other company that implements this technology. MY 10 Camaro drove me crazy on the freeway, my 16 is much better but I ended up with the shutter issue.
My Mustangs never had any of these issues but they were slower and typically got 26 MPG while my 16 Camaro is much quicker and will pull 27 - 28 MPG consistently on the freeway. A lot of this is driven by CAFE and EPS standards. As another poster stated most of these issues could be "programmed" out but then you'd be dealing with warranty issues. I keep my cars about 4 years and drive about 10K a years which should keep me in the drive train warranty period. I feel very confident that I'll be fine within those parameters but would worry more if I were planing to keep the car for 100K. |
10-18-2017, 09:13 AM | #8 | ||
Retired from GM
Drives: 2017 Camaro Fifty SS Convertible Join Date: Mar 2017
Any of these potential causes can be investigated and hopefully remedied by taking it to the dealer. Hope that helps. jlm
A8 | MRC | NPP | Nav | HUD | GM Performance CAI | Tony Mamo LT1 V2 Ported TB | Kooks 1-7/8” LT Headers | FlexFuel Tune | Thinkware Q800 Pro front and rear dash cam | Charcoal Tint for Taillights and 3rd Brakelight | Orange and Carbon Fiber Bowties | 1LE Wheels in Gunmetal Gray | Carbon Fiber Interior Overlays | Novistretch bra and mirror covers | Tow hitch for bicycle rack | |
10-18-2017, 09:44 AM | #9 |
Drives: 2016 Camaro SS, Garnet Red Join Date: May 2013
I think the A8 transmission is the worst part of the car. On my 2016 SS the 1-2 and 2-3 shifts in D are often awful at low throttle. But it's unpredictable; some days it's smooth, other days it's jerky as hell. Quite embarrassing if you have a passenger. I often drive in M to avoid the jerky gear changes - it shifts much better in M.
I had a 2013 SS A6 previously, and that had no problems at all. Just recently I got the Torque Converter shuddering issue, and this week my dealer did the triple transmission flush and reset the computer. He told me the car would be in learning mode for a few hundred miles. At the moment it's shifting firmly but not jerking. I hope it continues that way. |
10-18-2017, 03:02 PM | #10 | |
Sent from my XT1635-01 using Tapatalk |
10-18-2017, 03:49 PM | #11 |
Drives: MB 1SS Join Date: May 2017
You can't compare an Acura to this machine. Maybe you need a Buick or Cadillac.
10-18-2017, 03:51 PM | #12 | |
Retired from GM
10-18-2017, 04:00 PM | #13 |
10-18-2017, 04:11 PM | #14 | |
Retired from GM
This is not true. Transmission gears are machined to some of the most precise specs you'll find anywhere in the car. This is true not just of GM, but of any company that produces a marketable planetary automatic transmission. There is not a "gear" or pair of gears that meshed together give you 2nd gear, 3rd gear etc... What you have are a set of ratios that are achieved by the relative motion of planetary pinions in a carrier spinning around a pair of sun gears. What gear you are in is determined by the spin direction and speed ratio for the pinions relative to the sun gears. This is all executed hydraulically through the application and opening of multiple clutches and opening and closing of valves and oil channels. Until this year, all Honda / Acura produced auto transmissions were layshaft (same principle as a manual) with a pair of gears that determined 2nd gear, another pair that engaged 3rd, etc. A couple years ago they started buying planetary transmissions from ZF, and now they make their own planetary transmissions. The original Saturn automatic transmissions were also layshaft transmissions. That's why GM was able to build the automatic and the manual transmission on the same line and fit them in the same transmission case. Most modern automatic transmissions are planetary in design, with very sophisticated hydraulic power flows managed through equally sophisticated electronic controls. As for the precision of the gears, I've seen gears rejected because they were out of specification by the equivalent of a fraction of the width of a human hair. I've also seen transmissions trashed because of a single metal shaving, again smaller than the width of a human hair, getting lodged in the wrong channel of a valve body. Planetary transmission gears are ridiculously precise.
