03-01-2017, 10:53 AM | #15 |
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
The Borla X pipe does change the sound vs the "stamped" factory X pipe which really isnt even a true X pipe.
03-01-2017, 11:01 AM | #16 |
Drives: 2016 1SS D1SC Methfed Lowered Wrapd Join Date: Apr 2016
I ran stock NPP with secondary delete for a while. It is probably the best sound for NP imo. Quiet in stealth (very quiet), and just loud enough to be tasteful in track. Pull the fuse and you get a nice mix of accel and decel.
03-01-2017, 02:42 PM | #17 |
Drives: 2016 Camaro 2ss Join Date: Feb 2016
03-01-2017, 04:35 PM | #18 |
Snackbar Tuning
I wouldn't say the X pipe makes it louder. It smooths out the flow and it just sounds better. If you search on google about true X pipes vs crossover (stamped) x pipes you will see they are not the same at all. Borla uses a true X pipe.
03-01-2017, 04:36 PM | #19 |
Just fyi. I lost a noticeable amount of low-end torque when i deleted my rear cats... Something to be aware of if you plan on doing it
03-01-2017, 05:08 PM | #20 | |
Drives: '17 2SS H50 Join Date: Mar 2016
Like the car was restricted everywhere before and now it is opened up. Heath
1100 - 5/26 0000 - Cancelled - 7/5 Contacted Becky - 7/1 2000 - 7/5 3000 - 7/6 3000 - 7/11 TPW 8/1 3100 - 7/18 TPW 8/1 3300 - 7/20 3400 - 7/21 Built - 8/2 - PS 1,182/1 of 699US 4300 - 8/3 5000 - 8/5 6000 - 8/13 |
03-01-2017, 05:46 PM | #21 |
A tune would fix that, but if you aren't doing anything else to your car I could see why you wouldn't want to void your warranty.
03-01-2017, 06:19 PM | #22 | |||
Drives: 2016 Camaro 2SS NFG M6 MRC NPP Join Date: Mar 2016
Borla x-pipe (60606) connected to the stock NPP muffler does change the sound to a more refined note, which makes the car sound way better than the stock x-pipe. I did the 2nd cat delete, so it's also a bit louder and didn't lose any torque. It feels like I gained torque with smoother acceleration.
Check out my VIDs... Cold start in stealth mode: Cold Start in Sport mode: Highway acceleration: |
03-01-2017, 06:48 PM | #23 |
Stock NPP exhaust. Yeah a tune would fix it but i really dont want to void warranty for now...
03-01-2017, 06:49 PM | #24 |
Don't you lose the pops and crackles when you remove the crush pipe???
03-01-2017, 06:55 PM | #25 | |
Heath
03-01-2017, 07:06 PM | #26 |
03-01-2017, 07:09 PM | #27 |
03-01-2017, 07:10 PM | #28 |
This was my car after i took out the rear cats...
https://www.instagram.com/p/BLrn01Tg...by=tom_swift21 |
Tags |
cat, cat delete, exhaust, mid pipe, muffler |
