02-01-2017, 12:35 PM | #1 |
Drives: 2017 2SS Garnet Red Convertible Join Date: Sep 2016
Best Camaro SS Axle Back Exhast
Hey everyone! I have a 2013 Camaro SS (with cold air intake and ground effects if that makes a difference.) I'm wanting an axle back exhaust system to make my car sound meaner, but I don't want anything that makes my car sound stupid or like something is wrong with it. Sometimes muscle cars rev when they pass me, and I think to myself "That sounded crappy, not cool," so I'm trying to avoid that, but I would like to sound more badass and intimidating. In your opinion, what should I get? Thanks for the help!
02-01-2017, 12:51 PM | #2 |
Drives: White 2013 2SS/RS L99 Join Date: Jul 2015
Muffler delet honestly. Sounds nice and deep and isn't super loud. Take a look on YouTube. Other than that a lot of people seem to like the Solo axel back with J pipes
02-01-2017, 12:54 PM | #3 |
Drives: 2010 Camaro SS Join Date: Dec 2006
Flowmaster American Thunder...or Pro Series. Both are great sounding axle back options.
But...sound is a preference thing and you need to decide for yourself. Youtube is your best friend. |
02-01-2017, 01:11 PM | #4 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
Magnaflow. Flow master outlaws but drone is bad
02-01-2017, 03:05 PM | #5 |
Drives: 2014 Camaro SS L99 Join Date: Dec 2016
It's all preference. I had the magnaflow street series with my LT's and it was too much cab noise for me. So, me personally, wanted something quite on the inside (drone), but screamed at WOT. The only three I have found to work are Borla's S-Type, Flowmaster's Delta Force II (which I have), and anything corsa. I have two other buddies who one has the corsa extreme and the other with the s-type. Both scream at WOT, but super quiet inside the cab when you cruise. Again, it's preference. Another friend of mine has the borla atak, way too loud (IMO). Like cc-rider mentioned, check out YouTube and see what you like best.
Sent from my iPhone using Tapatalk |
02-01-2017, 03:14 PM | #6 |
Drives: 2015 2SS White Convertible CE/INDY Join Date: Mar 2016
The CAI will help give you a little more rumble in your tone. If these are the only mods, then a muffler delete is a nice option... in fact, this is what I will be doing in the spring. If you've done other mods to your car (cam, headers, cats... etc) then a muffler delete will drone and drive you crazy. Please keep in mind that any changes to your exhaust system will cause your AFM to be much more noticeable. I got the Range to keep my SS in v8 mode all the time.
Good luck, joe...
ARH LTH/HFC/Legato muffler, RDP Custom Tune, K&N Blackhawk CAI, Bigworm Blackout kit, ZL1 Rims, Phantom Grills, VMAX PTB
02-01-2017, 03:58 PM | #7 |
Drives: 1SS-2013 Join Date: Jul 2016
Bora Attack. Not too loud.. NO Drone At all
02-02-2017, 09:54 AM | #8 |
OEM? Whats that?
Drives: 2014 Camaro SS Black Widow Join Date: Sep 2016
Hooker BlackHeart exhaust
2014 Southern Comfort Black Widow SS LS3
Magnuson Supercharger, ceramic coated ARH headers w/cat deletes, BTR blower cam, Mahle forged pistons, AEM Methanol injection, JRE 8 rib Super tensioner, Innovators West 8 rib serpentine pulley system, Melling high flow oil pump, Lingenfelter high flow fuel pump, McCleod RXT ceramic coated Twin disk clutch, Hooker BlackHeart exhaust. Escort 360 radar detector & dashcam. Rockford Fosgate 1000w prime amp, 2X12” Rockford P3D2’s Build and mods done by R&D Motorsports in Baton Rouge Tune/Dyno done by ,,Engine Power Systems in Baton Rouge |
02-02-2017, 12:37 PM | #9 |
02-03-2017, 12:21 AM | #10 |
Drives: 2015 Camaro 2/SS M6 Join Date: May 2016
My Hooker Blackheart quad tip muffler delete race only cat back exhaust arrives tomorrow. I'll let you know how it is. With my mods it should sound incredible.
2015 Camaro 2/SS 820hp supplied by ADM Performance
02-03-2017, 04:13 AM | #11 |
Drives: '14 Camaro SS L99 Join Date: Feb 2017
Depends on what you like, if you want raspiness go with corsa ... if you want a more deep tone, go with borla or flowmaster.
02-03-2017, 06:22 AM | #12 |
Dan
Drives: 2010 Camaro 2SS IOM Join Date: Nov 2013
I had ARH 1 7/8 LTs / Corsa and loved it but too loud for the neighbors. I then went to a Magnaflow resonated x-pipe and borla S-type - now it is too quiet but still sounds great at wot. So... I am going to leave the magna flow X and put the Corsa muflers back on.
The Corsa sounded so great at wot. My buddy has a a full Kooks LT 3" cat back system on and he like his better at idle but my orig Corsa at WOT - he said it sounded like heaven being ripped open - LOL
Dan
2010 IOM SS YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust http://www.camaro5.com/forums/showth...&highlight=ysi |
02-07-2017, 09:24 AM | #13 |
Thanks everyone for the help! I totally appreciate your input!
02-07-2017, 09:32 AM | #14 |
Drives: 2023 Camaro ZL1 1LE Join Date: Feb 2016
If you ask 50 guys, you will get 50 opinions. Best thing to do is narrow down your choices and ask to hear someone's car who has the same set-up in person. Youtube vids don't do justice most of the time.
2014 Camaro SS Spring Edition LSX440ci
LSX Block, MAST 305 Black Labels, Exceldyne Valves, Diamond Pistons, Callies Crank & Rods, Cam Motion Cam, Johnson 2116LSR Lifters, Comp XDA Pushrods, Jesel Rockers, Mamo MSD, NW 102, Roto-Fab CAI, FAST 65# Injectors, ZL1 Fuel Pump, Kooks 2" Headers, Corsa Sport 3" Catback, Z28 Shifter, ZR1 Clutch, Katech LW Flywheel, 1LE 3.91 Diff, LPW Diff Cover, BMR - 1.4" Springs, LCA's, Trailing Arms, Toe Rods, Sway Bars, End Links, Diff Bushings, and Tunnel Brace, Z28/1LE Strut Tower Brace, Improved Racing Oil Cooler 2023 Camaro ZL1 / 1LE Stock |
Tags |
2013, axle back exhaust, camaro, camaro ss, muffler |
