Roto-Fab
Old 06-15-2011, 08:09 PM   #1
retro500
retro500's Avatar
Drives: 2013 Camaro 2SS Black L99
Engine Cover remove?
Is it ok to leave the engine cover off for a long extended period of time. It's freaking 100 degrees out here in Florida. If someone already asked this, my apologies, but I can't find the thread. Thanx in advance.
retro500 is offline   Reply With Quote
Old 06-15-2011, 08:14 PM   #2
2SS 2011
2SS 2011's Avatar
Drives: 2011 Camaro 2SS/RS M6 Black
I don't think it will hurt one bit to leave the engine cover off.. It really is just an added acessory to cover the fuel rails injectors wires etc.. You should be fine.. My 2000 Ls1 didn't have an engine cover .. it was fine..
You are ok
2SS 2011 is offline   Reply With Quote
Old 06-15-2011, 08:16 PM   #3
retro500
retro500's Avatar
ok thanx...ima just remove it......
Old 06-15-2011, 08:16 PM   #4
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
It's just cosmetic. A lot of people remove them.
Darth_Emma is offline   Reply With Quote
Old 06-15-2011, 08:18 PM   #5
retro500
retro500's Avatar
:fighting0040:thanx D/E.....
Old 06-15-2011, 11:10 PM   #6
Bama 2SS/RS
Bama 2SS/RS's Avatar
Drives: 2011 Inferno Orange 2SS/RS
Here's what the underside of my Camaro's hood has looked like for the past few months:
I haven't had any problems with my setup. I did an ignition coil relocation, GM Performance valve covers, relocated heater hoses and fuel line with the TechAFX kit, painted my intake cover, and installed a RotoFab cold-air intake. No problems whatsoever with running without the engine cover.
Actually, the only problem I've had since fixing mine up this way is that I have to keep wiping up drool spots when I show it off to people.
Bama 2SS/RS is offline   Reply With Quote
Old 06-15-2011, 11:21 PM   #7
rally yellow ss rs
rally yellow ss rs's Avatar
Drives: 2010 Rally Yellow 2SS RS
...plus the stock engine cover looks gay, painted or not. Should have come like the Corvette LS3 engine covers, but GM went cheap on the Camaro.
rally yellow ss rs is offline   Reply With Quote
Old 06-15-2011, 11:44 PM   #8
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
I took mine off for the small performance gain. About 5 lbs off the front of the car and the intake will run cooler.
SUX2BU is offline   Reply With Quote
Old 06-15-2011, 11:51 PM   #9
rally yellow ss rs
5 lbs...
Old 06-16-2011, 12:22 AM   #10
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Originally Posted by rally yellow ss rs View Post
5 lbs...
You wouldn't laugh at my last car. 98 SS that i took about 700 lbs out of and a lot of that was a bunch of little < 5lb stuff. With only bolt ons (stock cam, motor, no power adder) it dynoed 335 rwhp and ran a best of 11.04 @ 121 in the 1/4.
Taking weight out is the best mod you can do to a car.
Old 06-16-2011, 12:24 AM   #11
rally yellow ss rs
I completely agree...like when I see a "large" guy talking about all the mods he will putting on his car...the first thing that comes to mind is for him to lose weight.
Old 06-16-2011, 12:40 AM   #12
LimaCharlie
LimaCharlie's Avatar
Drives: 2011 Camaro SS/RS - 2004 Silverado
I removed my engine cover within weeks of getting my Camaro. I prefer the exposed look on engines and being able to see the hoses, fuel lines, clamps, etc.
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80
2004 Black Silverado 1500 2WD Regular Cab, Short Bed
-5.3 LM7, 4L60E, 3.42, G80
2014 White Caprice PPV
-6.0 L77, 6L80E, 2.92, G80
LimaCharlie is offline   Reply With Quote
Old 06-16-2011, 12:41 AM   #13
Bama 2SS/RS
Hey! That's the main reason I'm modding my car! Gotta add horsepower to haul my fat ass around quicker.
Old 06-16-2011, 02:05 AM   #14
IamJacksCamaro
IamJacksCamaro's Avatar
Drives: Camaro LS M6, Fiero, Ford F100
I leave my engine cover off. I don't like that it covers the radiator cap, among other critical things.
IamJacksCamaro is offline   Reply With Quote
How do you remove the engine cover?? RetroDude 5th Gen Camaro SS LS LT General Discussions 43 11-04-2014 03:37 PM
Any TSB for L99 leaking oil shockandawe Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 7 11-23-2010 08:44 PM
ENGINE COVER "SS" RED & WHITE FACTORY GM EMBLEM & POLISHED STAINLESS NAMEPLATE Kirban Performance V8 Bolt-Ons & Tunes 1 05-24-2010 02:06 PM
Car Cover domano 68 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 19 05-21-2010 09:51 PM
how to remove engine cover? SnMcGrew 5th Gen Camaro SS LS LT General Discussions 2 05-15-2010 10:58 AM
