03-12-2018, 11:52 AM | #1 |
Drives: 2019 2LT 2.0T M6 Riverside Blue Join Date: Jan 2018
Performance increase during 1st year of ownership?
I am wondering what people's experiences were over the first 1000, 3000, 5000 and 10,000 miles. What changes have you noticed regarding overall performance? When did you first feel like your Camaro was "fully broken in"?
03-12-2018, 12:54 PM | #2 |
Drives: 2004 Z06, 2017 1LE Join Date: May 2017
Any change in performance would not be measureable. An engine will not make any more power at 5000 miles than it does at 500 or even 50.
03-12-2018, 01:41 PM | #3 |
HYPER SS
Drives: 2016 Supercharged 2SS Join Date: Feb 2014
that's kinda an open end question and mearly based on opinions. That said I broke mine in under Naturally Asperated, and around the 3000 mark, is when I boosted mine.
Ordered: 1/15/2016
2000 status 02/01/16 3000 status 02/29/16 3400 status 03/07/16 TPW of 03/14/16 4200 status 03/17/16 in transit! Delivered 03/23/16 2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points. | AWE touring - resinated catback with link pipes. |
03-12-2018, 01:47 PM | #4 |
Drives: 2017 50th Anniversary Join Date: Dec 2015
I doubt it would be measurable after the first 1000 miles. By that time everything is hopefully as broke in as it's going to get.
I've not experienced this in my car but I was present at both track days with my friends C7 Vette. He bought the car on a Monday, drove it back and forth to work for a week then we all headed up to WI for a couple of runs down the strip. The car had about 400 miles on it at that point and was running in the 12.50 range around 115 mph. I don't know the DA but I can tell you it was a mild day in the mid 60's. He then took a road trip to the Corvette museum and back putting on about 1200 miles. The following weekend was back to the track. No changes to the car but it was in the 12.30's with mph in the 117 range on a hotter day so it defiantly loosened up a little over the first 1500 miles or so. |
03-12-2018, 03:03 PM | #5 | |
Drives: 2017 1SS camaro ,2SS a 68 + 08 C6 Join Date: Dec 2017
My thoughts on this are as such 1st the car might have an Ecu code written into the programming To not perform at 100% to ease and " break in " the motor , maybe Al Oppenheimer can confirm or deny this ? 2nd is if you've ever assembled an engine , you'll know you have a compression ring a 2nd comp / tension ring and then an oil ring , as the engine puts on miles and the crosshatch and wear pattern develops the reduced friction from the cylinder walls will make an engine perform slightly better . Ring end gap , low tension rings ,etc. can all be contributing factors depending on your setup . But nearly ALL engines make more power after they are " broken IN " after a few dozen or hundred miles than when they are new . 3rd Sadly these engines are direct injection and as thousands of miles will develop carbon deposits on the valves . And these engines will slowly but surely make less and less power past 30,40 or even 50 thousand miles . These engines make the best power between 5000-30000 miles is my theory. |
03-13-2018, 12:39 AM | #6 |
The reason I asked is, with my '17 Trax and its 1.4L turbo (LUJ), it was super boggy when I first got it. Like even well passed the break in period. I still noticed it around 3000 -5000 miles. Very slow off the line, took forever to accelerate to highway speeds. Now at 10k miles, there is a very noticeable difference in performance, at least to me. I feel it accelerates much quicker and gets to highway speeds faster. I haven't timed it or anything, but subjectively, it's much quicker and more responsive, I know for a fact.
I am wondering if anyone had these type of observations regarding the Camaro. Mine only has 600 miles on it so far, and I'm trying to gauge what kind of performance increases I might see. I don't really care about tenths of seconds or whatever, I'm just interested in subjective opinions. |
03-13-2018, 12:45 AM | #7 |
Drives: 17 SS 1LE Join Date: Dec 2015
All engines loosen up over time.
03-13-2018, 06:55 AM | #8 |
Drives: Former 2016 Camaro 1LT Join Date: Jan 2017
Anyone see improvement in gas mileage? Typically with me whatever the car gets out of the gate, it gets. Hoping my RS V6 will get better, I only get 21-24 and it has 2800 miles on it. My 85 Vette gets the same with a 5.7.
2006 C6 Corvette Manual, 2019 Silverado, 1997 Jeep Wrangler
03-13-2018, 07:29 AM | #9 | |
Drives: 2018 2SS Join Date: Jan 2018
I dont know about break in for performance, but a complete truth for MPG. |
03-13-2018, 09:26 AM | #10 |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
The difference in mileage and power is definitely measurable between 50 and 5000 miles
03-13-2018, 09:47 AM | #11 |
Drives: 2017 SS 1LE, 2017 Volt, 2013 Pilot Join Date: May 2014
I noticed significant increases in power in the first year.
but 9lbs of boost will do that.
03-18-2018, 02:37 AM | #12 | |
03-18-2018, 04:58 AM | #13 |
i got an average of 29 yesterday with my 2015 RS.im thinking you will do better as the miles pile on.BTW around town i get 21-22.
03-18-2018, 08:30 AM | #14 | |
(HRFS -> heavy right foot syndrome) |
