Old 11-10-2015, 06:34 PM   #15
ChefBorOzzy
ChefBorOzzy's Avatar
Drives: 2016 F150
Originally Posted by SpeedIsLife View Post
Won't happen this time...but that's exactly what happened with the 5th Gen.
Just not 100 lbs
That's what happens year to year as changes are made to cars.
ChefBorOzzy is offline   Reply With Quote
Old 11-10-2015, 06:54 PM   #16
ADM PERFORMANCE
Drives: Anything I want
Originally Posted by SUMMIT WHITE SS View Post
It's possible the numbers are not corrected, the part thats shows that is blocked off. Also, differnt dyno, different day. This one seems a tad high to me as the other runs have been 399, 400 and 405 that I've seen.
Curious, anybody know if these are the same cars?
Knock versus no knock,probably bad gas
ADM PERFORMANCE is offline   Reply With Quote
Old 11-10-2015, 07:14 PM   #17
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Do you know if the car had premium fuel in it? Wonder if some of those other dynos had regular fuel by mistake. Just odd as three are so close, then one is a decent amout higher.
Old 11-10-2015, 07:25 PM   #18
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
I am extremely weary of any early dyno results. Not because I think the cars are ringers, but because I suspect a lot of people that want to post numbers up, do it explicitly because they want to show everyone some big numbers. Doesn't matter whether its a private owner or a shop thats about to start selling products. Some might say a shop would be prone to lowballing the 'before' to make their stuff look better, which is true. But if you have a dyno that tends to read high you'll also post better gains vs a more conservative dyno.
Even in the coming months when people do a before & after, I'm still skeptical that it might be a 'happy' dyno. If you dyno your car, are you going to be more likely to post it if the number is high or if its low?
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 11-10-2015, 09:42 PM   #19
KMPrenger
KMPrenger's Avatar
Guys this was posted on the "other" forum.
It was on ADMs dyno which is the dyno I use and it's pretty stingy. I was present for the pull today. 399 was with pump gas and it knocked, so they put a couple of gallons of race gas in it and it put down the 417. Same conditions otherwise.
I think it's interesting. Find it here: http://www.mustang6g.com/forums/show...postcount=2516
Old 11-10-2015, 09:53 PM   #20
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Wonder why it had some knock? My guess is it had regular fuel in it. Does Dallas TX (where the shop is I think) have 91 or 93 premuim?
Old 11-10-2015, 10:04 PM   #21
SpeedIsLife
Drives: Current Camaro-less
Hopefully it had rot gut in it...ping/knock on 91 would suck
Old 11-10-2015, 11:32 PM   #22
Dreng
Drives: 13 Camaro
To answer your question yes. Some petro stations have 91 and some offer 93 around here.
Dreng is offline   Reply With Quote
Old 11-11-2015, 06:34 AM   #23
ADM PERFORMANCE
The car makes around 400 rwhp
Based on all of the data it lands anywhere just shy of 400 rwhp and just slightly north of 400 rwtq. This was real world data with some knock retard in the datalog. Cooling it off,pulling the air filter tricks blah blah blah may show slight gains.
As for race gas comments,the car had a near full tank of gas.A bit difficult to put gas on top of gas to any substantial effect.
Cars dyno 8-15 hp different all the time day in and day out run to run,just asking any shop that does what we do everyday.
In conclusion- Gm built a lightweight,strong chassis,powerful emissions friendly car ....... Good job
Old 11-11-2015, 06:36 AM   #24
mcsoul
Drives: Want a gen 6
I think 417 is the outlier (race gas??) and 400 ish to just over is truth. But it puts it down really well as evidenced bu the 0-60 and 1/4 mile times which are right in line with that power.
mcsoul is offline   Reply With Quote
Old 11-11-2015, 07:09 AM   #25
ADM PERFORMANCE
Look what I found -
The result: All of it, and more! On Addiction Motorsports’ Dynojet, the 2016 Camaro SS with the six-speed manual threw down a stout 405.2 hp and 405.4 lb-ft at the wheels on its best run, with power and torque increasing with each of our three pulls.
Looks consistant to me !
Old 11-11-2015, 07:54 AM   #26
NASTY99Z28
Drives: 99z28 with bolt-ons and a mwc fab 9
What does a c7 put down?
I like my woman like my milk shakes, THICK!!!!
NASTY99Z28 is offline   Reply With Quote
Old 11-11-2015, 07:57 AM   #27
mcsoul
Very similar, 402-405hp in the c7 threads I read.
Old 11-11-2015, 08:05 AM   #28
xgnxs
xgnxs's Avatar
Drives: 2005 Cobalt Base - 5 speed
Yep, weight lines up exactly, even taking the missing fuel into account.
xgnxs is offline   Reply With Quote
