09-09-2013, 03:23 PM | #15 |
Drives: 2018 ZL1 A10 Join Date: May 2012
What an awesome explanation !!! So lets see the same type of vid explain limited slip and posi track.
DAVENPORT STAGE 2 PLUS - 2" ARH ceramic coated headers - 3" ARH catless exhaust - Stock NPP mufflers - Kong ported SC - Katech 103 ported TB - Rotofab 5" Big gulp CAI - 22.5% lower pulley - ATI Harmonic balancer - Cordes SC expansion tank - MSD hi temp ignition wires - Koolsox spark plug insulators - custom tunes - 660hp/725tq pump - 713hp/763tq race
11-12-2013, 09:49 PM | #16 | |
Drives: 2012 2SS M6 Join Date: Nov 2013
Here's another good one that came up in the suggested videos:
It shows what Toyota calls auto LSD. It uses the brakes to limit wheel spin on an open diff. I think stabilitrack may do something like this.... I'm pretty sure camaro's have a torsen diff still? There's also a video of one of these on youtube, although it did not help my understanding of how the load is transferred with this setup.... lol A positraction differential uses a set of clutches in between the left and right side axles to allow slip under high differential speed, as when turning. An automatic locking differential uses differential inertia created by wheel spin to mechanically engage an axle lock. These usually will not activate over 30mph or so, giving you an open differential above that speed. These are mostly found in trucks. |
04-02-2014, 07:31 AM | #17 |
Drives: 2015 ZL1 Convertible Automatic Join Date: Sep 2011
Had my Chevy dealer install 3.91 gears in my SS L99. Kinda expensive way to go but kept my warranty intact. $1675 total. All I can say is holy crap, this bad boy runs like a scalded cat. Haven't even pushed it hard yet, got to break things in a bit. Worth every penny!!
04-11-2014, 09:31 AM | #18 |
What about speedo corrections???
11-06-2014, 02:07 PM | #19 |
So you need a tune after ear install?
Cold Air Inductions CAI Stainless Power LT's with HFC's Flowmaster American Thunder Cat Back APEX Scoop and WW Relocation Kit VMAX Ported Throttle Body Custom Dyno Tune Pfadt 1.25" Lowering Springs ZL1 Rims on 275 front 315 Rear custome underlay vinyl wrap Anvil Spoiler heritage grill APR Front Splitter Custom Emblempros emblems ZL1 Side Skirts 416.5 whp 410 torque (CURRENTLY) Up Next: BTR Stage 3 Cam and supporting mods (in garage now)
11-16-2014, 07:35 AM | #20 |
Drives: 2016 camaro 1SS Join Date: Jun 2013
2016 BLK Camaro 1SS/LT1 M6: NPP | black front/rear bowtie | Blacked out taillights 2011 IOM Camaro 1SS/RS LS3: Stainless works 1 7/8" LT headers w/ Offroad pipes | TSP Cam 235/239 on a 112 | Powerbound 25% UD Pulley Roto-Fab Cold Air Intake | SW Retro Chambered Catback Exhaust | VMax Ported TB | Hurst Short Throw Shifter Trunnion upgrade | LSA Oil Pump | BMR 1.25 Spings | R1 Concept d/s Rotors Tuned by Lashway Motorsports - 501 Hp 430 ft-lb |
12-21-2014, 08:52 PM | #21 |
so will changing from stock 3.27 to 3.91s in L99 reduce the top end?
Modifications
GM Dark Tail Lights / 3rd Brake Light & Reflectors | LED Reverse Lights | Diode Dynamics Side Markers | Borla "ATAK" Cat Back Exhaust |
12-21-2014, 09:13 PM | #22 |
Drives: 14 1SS Camaro 1LE, NPP, Recaros Join Date: Nov 2013
I want to change 5th gear on my 1LE to a .840 like a standard SS. The OEM .740 is too tall and is more of a over drive gear. Does anyone sell just a set of gears for 5th gear?
01-20-2015, 03:53 PM | #23 |
What is the best Gearing for a V6 I think the 1LS has the same as the all other V6 (except the 2LS with the 2.92 gears) I heard that the 3.91 gears are too much for the V6 and I would be peeling out in 1st gear. So would a 3.55 gear be better for daily use ??
Specs
TSP Stage 2 Boosted Cam 227/235 at 114 LSA Fore Innovation Triple pump staged (Walbro 342 primary and 2x Walbro 450 secondaries) Procharger D1x with a 3.85 pulley ID1050x Injectors Flex Fuel Sensor Monster LT1 Twin Disk Clutch Holley Sniper Efi Intake Manifold NW 103mm Boosted TB 747rwhp at 12psi on E85 |
05-14-2015, 10:35 AM | #24 | |
Drives: 2010 2LT Bumblebee Join Date: Apr 2013
AirLift Air Suspension, Stainless Works Long Tube Headers + Hi-Flo Cats, Resonated X-Pipe, MRT V2 Mufflers, VMAX Ice-olator and Ported Throttle Body, Barton Short Throw Shifter, CAI Intake + Air Scoop
05-14-2015, 12:13 PM | #25 | |
Drives: 2000 Camaro SS Join Date: Feb 2010
05-14-2015, 12:51 PM | #26 |
Homeless Life Chose Me
Drives: LS3 (sold 4/21) Join Date: Nov 2014
Lmao OHIOSS how exactly do u think u will get a ticket if your speedo isn't calibrated
Pity a man in familiar places, who yet feels like a stranger.
01-04-2017, 04:51 PM | #27 | |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
A very good old video explaining how the differential works.
Power is worthless without control. The 2nd protects the 1st.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
