03-27-2013, 04:46 PM | #1 |
Drives: 2010 IBM Camaro 1LT RS Join Date: Sep 2010
Amp troubleshoot
So I installed my magnum bass dual 10" system in my trunk about 3 months ago and the other day it just crapped out on me and idk why.
System info: I had it hooked up to the stock head unit using a ******** harness for non B/A systems. Getting power from the battery in the trunk and it is also grounded in the trunk. I ran through some of the basic stuff. checked my power and ground wires which I believe are ok. Checked for any blown fuses and there were none. Im starting to think that maybe my amp is what crapped out on me. When I have everything hooked up none of the lights on the amp go on. could this also be a remote lead problem? Im by no means an audio expert but I do have a decent grasp on the basic concepts. Anyone have any ideas? Is there a way to maybe test my amp outside of my car?
03-27-2013, 05:18 PM | #2 |
Drives: Tacoma/2LTRS Join Date: Jul 2011
Try connecting a wire from the +12 battery to the remote input on the amp
03-28-2013, 11:27 AM | #3 |
so basically hook two power wires to the amp? one for the power and one for the remote lead?
03-28-2013, 01:06 PM | #4 | |
Aural Assault Vehicle
Drives: 2010 IBM 2SS/RS, 2015 Sierra Denali Join Date: Jun 2011
If your wiring is good and your fuses are not blown (be sure to check the fuses with a meter as sometimes they can be blown with a hair thin crack and look fine), then your amp probably "gave up the ghost". How old is the system, and who made the amp? Is it the same as this? http://www.sonicelectronix.com/item_...MTX-Audio.html
My amplifier pop/click/thump solution thread
Power Mods * K&N Typhoon CAI, Flowmaster American Thunder cat-back exhaust, Hurst Short Throw Shifter Exterior Mods * Black Phantom Grille * 22" T.I.S. 537MS wheels w/ Nitto INVO rubber * OEM body kit Suspension Mods * BC Racing Coilovers * Lakewood Strut Tower Brace Audio Mods * Stinger SPP 2250 Battery * Mosconi 6to8v8 w/ RCD * Pioneer AVH-X7500BT * Scosche Dash Kit * 2 - Mosconi AS200.4 * 2 - JL Audio 13W6v2 * Focal 165KRX2 Power (active) * Mosconi Gladen One 240.2 * Rockford Fosgate Power T1692 |
03-28-2013, 03:47 PM | #5 |
Ahhh ok then ill give that a try. and yes that is the system I have. I know its not the greatest quality that's why I think it may be the amp. It was brand new when I got it and was running on the car for about 3 months. I have the amp mounted to the side of the box could that have caused a problem? I heard that while its not the best mounting location it shouldnt affect the amp to much. Also I read about the clicking, popping, thump problems and my car was experiencing that on start up so could this be an issue?
