Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 03-23-2024, 08:33 PM   #1
Jtouch81
Drives: 2014 Camaro ZL-1
Tuning issues
Having issues with getting the ZL-1 tuned. Just installed a BTR stage 2 cam kit and the tuner is telling me I’m having issues with a vacuum leak or air getting in the system after the maf sensor. Current mods are the following besides the cam. ID850 injectors / intake / 2.55 upper pulley and 10% overdrive pulley / longtube headers with catless xpipe / JMF fuel booster. That’s about it and we are tuning with HP tuners.
I’ve smoked tested the lines with zero leakes.. checked for exhaust leakes with none. I’m getting frustrated. Have no idea where to go from here. Below is the log.
Jtouch81 is offline   Reply With Quote
Old 03-23-2024, 09:05 PM   #2
Rob3D
Rob3D's Avatar
Drives: Car
Don’t you live about an hour from Cumming Ga?
Rob3D is offline   Reply With Quote
Old 03-23-2024, 09:15 PM   #3
Jtouch81
I do
Old 03-23-2024, 10:14 PM   #4
Rob3D
Rob3D's Avatar
Drives: Car
Originally Posted by Jtouch81 View Post
I do
Vengence could help you…I’m guessing you already considered though.
Old 03-23-2024, 10:30 PM   #5
Jtouch81
Was really trying not to take it anywhere honestly
Old 03-23-2024, 10:36 PM   #6
Rob3D
Rob3D's Avatar
Drives: Car
That was my only contribution.
Old 03-23-2024, 10:41 PM   #7
Jtouch81
No worries man.. I appreciate it.
Old 03-24-2024, 08:52 AM   #8
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
1. Are you running a catch can? If so, how are the hoses routed?
2. Have you done anything with the purge solenoid?
3. Have you done anything with the crankcase evacuation lines (some call PCV)
4. Have you ever removed the throttle body?
FasNuf is offline   Reply With Quote
Old 03-24-2024, 08:57 AM   #9
FasNuf
FasNuf's Avatar
Maybe unrelated but why is your IAT2 at 180°?
Old 03-24-2024, 10:10 AM   #10
Jtouch81
I am not running a catch can yet but that is my next purchase. I haven’t replaced the solenoid but I have taken it out and checked the o-ring and tested it with 24 volts. Seemed to be okay I could hear the clicking. I’ve sprayed throttle body cleaner on all the PVC lines and did the smoke test and didn’t get any smoke out of the the lines.
Took the throttle body off last night again to check the O ring and all looks fine there. That was the only other thing I could think of.
IAT’s were way high because I didn’t purge the air out of the system so the intercooler pump went in the fail safe mode. But I have since purged that since the log and all seems good to go.
I have noticed when I run the system check in the scanner on hp tuners it’s saying the Evp system is not ready. Read that it should go back to ready if you take the car out and drive it some but it still has not went to ready.
Old 03-24-2024, 10:26 AM   #11
FasNuf
FasNuf's Avatar
So please excuse my ignorance, but I cant tell from the screen shot why he thinks there's unmetered air getting in the engine.
Old 03-24-2024, 11:35 AM   #12
Jtouch81
Tuning issues
If you look at the MAF error circled it’s adding 20% at idle trying to compensate for some kind of leak and it’s only doing it at idle
Old 03-24-2024, 02:39 PM   #13
FasNuf
FasNuf's Avatar
Have you put a running log and the tune up to the HPT forum?
Old 03-24-2024, 02:45 PM   #14
FasNuf
FasNuf's Avatar
You could carefully use propane to try to find a leak. If the engine rpm rises, the leaked pulled the propane into combustion.
Have you had the blower or lid off?
