Roto-Fab
Old 04-22-2014, 10:04 PM   #1
Cornflakes'Camaro
Counting down the days...
Cornflakes'Camaro's Avatar
Drives: Black 2011 2SS/RS
Top end build list, would like your opinion(s)
Car: 2011 2SS/RS
Will have roughly 50,000 miles when build is done (late July/early August)
An * means I am unsure whether these parts are needed or just safe to get. Everything else is part of the projected top end build. Give me an opinion of what I am missing to complete the job, the right way. It's a daily driver, so I am not willing to compromise on the dependability of the parts.
102 mm Fast LSX-r intake manifold
102 mm throttle body
Aftermarket fuel rails for 102 mm intake***
Cam shaft itself
Pushrods
Timing chain
Valve springs
Lockers
Valve seals
Aftermarket lifters***
Melling oil pump
Under-drive pulley***
Intake manifold gaskets***
Head gaskets***
Dyno tune
SN-I believe I am going with Tick Performance out of NC for the cam, additional parts and dyno tune as well, still not 100% since I am still working on the needed parts. Input on Tick Performance products/tune is very welcome.
Tick Performance Custom Cam w/ support mods/BBK LT Headers w/ midpipes/Straight Exhaust/Airaid Cold Air Intake/ZL1 Driveshaft/ZL1 Differential/Hendrix Engineering Offset Bushings/ZL1 Axles/BMR Rear Subframe Bushings/BMR Toe Rods/Carlyle Racing 15" Conversion/Jannetty Winsheild Bottle Scoop/Forgestar 15x10 Beadlocks wrapped in Mickey Thompson Radial Pros
Cornflakes'Camaro is offline   Reply With Quote
Old 04-23-2014, 10:12 AM   #2
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
The guys at Tick are great, you are in good hands.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II
13.15@106 1.95 | 100% Stock
12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune
12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune
11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts
10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800
Pro Stock John is offline   Reply With Quote
Old 04-23-2014, 10:49 AM   #3
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
Based on your build I think the FAST intake is a complete waste of money. You will see minimal gain and I think you would see better gains per $ just putting that coin towards porting your existing intake and heads instead.
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
Old 04-23-2014, 11:00 AM   #4
camaro500
camaro500's Avatar
Drives: 2017 Jaguar F Type R Tuned 498awhp
For the $1000 you want to spend on the FAST102, put that money towards porting and polishing your heads. Great power adder!
JRE cammed w.full bolt ons 444rwhp/422rwtq SOLD
''Life moves pretty fast. If you don't stop and look around once in a while, you could miss it.'' - F. Bueller
camaro500 is offline   Reply With Quote
Old 04-23-2014, 11:02 AM   #5
casper sc/1ss/rs
casper sc/1ss/rs's Avatar
Drives: 2011 camaro ss vortech supercharged
casper sc/1ss/rs is offline   Reply With Quote
Old 04-23-2014, 11:03 AM   #6
Hott12SS
Hott12SS's Avatar
Drives: 2012 2SS/RS
+1
Sent from my SAMSUNG-SGH-I717 using Tapatalk
2012 2SS/RS L99 - TSP 1 7/8" LT's, catless connections, 3" mids. ADM Race intake w/ scoop and VMax ported TB. More to come...
Hott12SS is offline   Reply With Quote
Old 04-23-2014, 11:07 AM   #7
Pro Stock John
Writer
Yeah if you talking to Tick, I think Martin S might suggest going into some heads ported by AI, he's a big fan.
PROJECT HEAVY CHEVY
Old 04-23-2014, 11:15 AM   #8
blake-b
blake-b's Avatar
Drives: 2009 ZR1
Don't forget to do a trunion upgrade
http://www.briantooleyracing.com/btr...union-kit.html
I also recommend Martin at Tick for a cam. The Fast 102/102 TB is also a waste of money that could be used elsewhere with more gain such as ported heads...
Old 04-23-2014, 07:55 PM   #9
Cornflakes'Camaro
Thanks guys. This is the kind of feedback I am looking for. I do have good news, I used to work at Fulton Competition, (Chesnee, SC) where I learned how to deck, port and polish racing heads and intake manifolds. The best part is, I can do it myself, for free. So now that I have an extra 900-1000 dollars from not getting the intake/TB, is there anything missing that I need? (Trunion kit is added to list)
Old 04-23-2014, 08:35 PM   #10
TXM62SS
TXM62SS's Avatar
Drives: 2012 2SS/RS LS3
3.91s are not needed but the extra $1000 you have would come close to covering it. One of the best mods I have done. Great build! Congrats!
Victory Red 2012 2SS/RS LS3 Camaro
Pat G. Spec Cam from Cam Motion 228/236 .599/.599 112+2LSA
Kooks 1-7/8" LTs w/ Cats
Roto-Fab, Bo White TB, Borla Touring Catback
3.91 1LE Gears, MGW
Tuned by Pat G
TXM62SS is offline   Reply With Quote
Old 04-23-2014, 09:21 PM   #11
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
+1, you will love some gears with a cam.
Old 04-23-2014, 09:51 PM   #12
Cornflakes'Camaro
That is what was on my mind. slightly off track here, but I am going to attack the whole rear end....bushings, tie arms, trailing arms, etc. So I might put the 1k towards the rear end, as a whole.
Old 04-23-2014, 09:52 PM   #13
Cornflakes'Camaro
Also, I will keep this thread active as I get closer to ordering parts, making "that or that" decisions, etc. I look forward to everyone's help here.
Old 04-24-2014, 05:33 PM   #14
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
front end gaskets for the timing chain swap, ls2 dampener, harmonic balancer bolt, belts for underdrive pulley, two gallons antifreeze, two oil changes worth of Driven racing Br30 break in oil. And a g.m. three bolt sprocket for the cam with bolts.....
christianchevell is offline   Reply With Quote
