07-28-2012, 12:24 PM | #1 |
CaRaHoLiC
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp Join Date: Aug 2011
plugs for headers
Just a question, when installing headers, cold air kit, pulley etc, what plugs are people using? hotter? colder? same?
Normally I would have said colder, but what are people on here using?
2012 ZL1
2.55 upper, 10" lower pullies, Innovators west billet hub and sfi balancer, solid blower drive isolator, 50 mm idler kit, full length S/S headers no cats, comp cams custom grind cam, comp roller rocker trunion kit, comp push rods,dual valve springs retainers and locks, Injector dynamics ID850 inectors, Rotofab ZL1 cold air kit, Lingenfelter 160 thermostat, Rotofab intercooler reservoir, stock plugs, LS7 90mm throttle body, GTO clutch reservoir mod, my own custom catch can, Tuning by Jannetty, install by me. |
07-31-2012, 07:14 AM | #2 |
Drives: 2013 red Lingenfelter ZL1 Join Date: Apr 2012
I was just looking a Lingefelter's 700+ hp kit and there is no mention of a plug change.
07-31-2012, 07:57 AM | #3 |
Drives: too many to list Join Date: Nov 2011
One stage colder is what we did on my car.
08-01-2012, 07:18 AM | #4 |
NGK TR6 is a suggested plug for anything over stock boost
08-01-2012, 09:31 AM | #5 |
Petro-sexual
Yup. This seems to be the most common for LS-motors. They aren't iridium-tipped, like OEMs, nor are they platinum, which means you have to change them somewhat regularly (what - 30K-miles?...), but you'll be less prone to detonation because they're cooler to run. They're pretty inexpensive, too
08-01-2012, 11:03 PM | #6 | |
Drives: 2013 Camaro ZL1 Join Date: Apr 2009
http://www.texas-speed.com/p-102-ngk...ark-plugs.aspx
Devliered July 20, 2012
08-02-2012, 12:12 AM | #7 |
CaRaHoLiC
Awesome,
Thanks for the info. I will pick up a set of these for my car.
2012 ZL1
08-02-2012, 12:30 AM | #8 |
750HP of Twisted Reaper!
Drives: Blk 2SS/Blk Carb Fibr NS-1 stripes Join Date: Oct 2010
+1
Fear the LMR Twisted Reaper Brotherhood!
08-02-2012, 09:29 AM | #9 |
You can pick these up directly from our website if required for modifications
08-05-2012, 07:08 PM | #10 |
Perpetual Order
Drives: indeed Join Date: Jun 2012
change those tr6 every 10k or every other oil change.
I am running tr55s but I have a lowly ss. :-) |
