07-19-2012, 05:09 PM | #1 |
CaRaHoLiC
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp Join Date: Aug 2011
Curbs
Ok I smacked my splitter on a parking curb. How much are these things?:(
2012 ZL1
2.55 upper, 10" lower pullies, Innovators west billet hub and sfi balancer, solid blower drive isolator, 50 mm idler kit, full length S/S headers no cats, comp cams custom grind cam, comp roller rocker trunion kit, comp push rods,dual valve springs retainers and locks, Injector dynamics ID850 inectors, Rotofab ZL1 cold air kit, Lingenfelter 160 thermostat, Rotofab intercooler reservoir, stock plugs, LS7 90mm throttle body, GTO clutch reservoir mod, my own custom catch can, Tuning by Jannetty, install by me. |
07-19-2012, 05:18 PM | #2 |
Drives: 2012 (ZL-1) #468 Join Date: Apr 2012
Let Me Know When You Find Out - I'm Always Watching The Speed Bumps And Curbs Too - With Only 6" Of Clearance I'm Too Going To Hit Something
07-19-2012, 05:33 PM | #3 | |
Drives: 2010 Duramax; 2012 CTS-V Coupe Join Date: Apr 2012
07-19-2012, 05:44 PM | #4 |
CaRaHoLiC
Ya I found the part number 22894223 95.00 not too bad. I'm in for the curb alert though....
2012 ZL1
07-19-2012, 06:03 PM | #5 | |
BeckyD Rocks :-)
2015 CRT 1SS/1LE RS/Recaro's/NPP/Nav/Rear vision pkg./BA speaker upgrade. Stage 3 BMR cam, ARH 1 7/8 headers, CAI,
BMR 1.25 drop springs, JPSS Billet Bushings, Peddars Cradle Bushings...460 whp...so far....SOLD, but not forgotten! |
07-19-2012, 06:13 PM | #6 |
Drives: 12 ZL1 & 08 Suzuki Boulevard C50 Join Date: Oct 2011
I got a replacement for $85.00
2012 ZL1 - #413 - IOM - Mods; Exhaust Commander. GMG Third Brake Light Pulsar, Tinted Windows, color matched Engine cover, ZL1 Floor Mats
07-19-2012, 06:29 PM | #7 |
Perpetual Order
Drives: indeed Join Date: Jun 2012
You split your splitter?
07-19-2012, 06:44 PM | #8 | |
Drives: 2017 ZL1 Status "Thank You!" Join Date: Feb 2009
GM Part # 22894223 List $131.17 You can get for under $100!! Then you need 8 plastic bolts to hook it up... maybe not if you can reuse the old ones, but in case you need them GM Part # 11570637 List $4.39 Can get for about $3 or less each |
07-19-2012, 06:59 PM | #9 |
Dry Heat My @ss
Drives: 2012 ZL1 SUMMIT WHITE Join Date: Mar 2012
I came within an inch on the 1st day.
Now I back in, almost always, or I'm 3 ft away and 50 yards from any other car on the lot. |
07-19-2012, 07:35 PM | #10 |
Drives: 2012 Blk ZL1 Join Date: Dec 2011
07-19-2012, 09:10 PM | #11 | |
Drives: '12 SIM ZL1, 1 of 49 Join Date: Sep 2011
I have installed the curb-alert on my Z. It works on a part-time basis. When the voltage is above 13.2 volts (alternator charging) the unit turns on. When the voltage drops below this the unit turns off. Our alternators turn on and off as the car is driven. If the voltage has dropped (alternator off - battery voltage only) the curb-alert does not alert. |
07-19-2012, 09:44 PM | #12 |
GEEZ!! Wasn't aware of that...thanks for the info.
07-19-2012, 11:14 PM | #13 |
07-19-2012, 11:14 PM | #14 | |
Drives: 2013 ZL1 Join Date: Oct 2011
shopping for 2017+1le or zl1
2009 CTS-V -sold 2015 Hellcat-sold 2013 ZL1 -sold 2007 Z06- sold 2014 Chrysler 300 2011 Duramax 8" lift, deleted tuned |
