Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > Engine | Exhaust | Bolt-On | Drivetrain Modifications
Old 08-25-2012, 03:27 PM   #15
Higgs Boson
Perpetual Order
Drives: indeed
Originally Posted by RoketRdr View Post
No thanks...I like mine better.
lol. just an option. yours is great when you have the file on your hard drive. just because I posted a link doesn't make it required....
Higgs Boson is offline   Reply With Quote
Old 08-25-2012, 03:49 PM   #16
RoketRdr
RoketRdr's Avatar
Drives: 2010 Duramax; 2012 CTS-V Coupe
No worries. I prefer to have immediate access to my calcs on the laptop and phone rather than having to have internet access. Was just offering these guys an easy to use calc with ZL1 numbers already plugged in.
RoketRdr is offline   Reply With Quote
Old 08-31-2012, 01:16 PM   #17
All-American ZL1
Chevy Power
All-American ZL1's Avatar
Drives: 13 ZL1 M6 #123, '98 Jeep Wrangler
What if you went the other way and used the 3.23 gear that is in the automatics, and tried to rev out third gear?
All-American ZL1 is offline   Reply With Quote
Old 08-31-2012, 03:11 PM   #18
Higgs Boson
Perpetual Order
Drives: indeed
as long as you are at the top of whatever gear at the finish line you are maximizing your rear gear ratio. however, you may not be maximizing your transmission ratios.....which means you aren't maximizing your horsepower potential.
Old 09-04-2012, 03:11 PM   #19
All-American ZL1
Chevy Power
Yeah I can see how that wouldn't be optimal in most situations. Could we tub the rear end so that we could fit bigger drag slicks back there instead of changing the gearing? How big do you guys think we could go?
Old 09-21-2012, 11:10 PM   #20
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp
I still don't get why nobody makes a gear set for this...?
2012 ZL1
2.55 upper, 10" lower pullies, Innovators west billet hub and sfi balancer, solid blower drive isolator, 50 mm idler kit, full length S/S headers no cats, comp cams custom grind cam, comp roller rocker trunion kit, comp push rods,dual valve springs retainers and locks, Injector dynamics ID850 inectors, Rotofab ZL1 cold air kit, Lingenfelter 160 thermostat, Rotofab intercooler reservoir, stock plugs, LS7 90mm throttle body, GTO clutch reservoir mod, my own custom catch can, Tuning by Jannetty, install by me.
2012ZL1 is offline   Reply With Quote
Old 09-21-2012, 11:21 PM   #21
FNBADAZ06
FNBADAZ06's Avatar
Drives: C6 Z06 Corvette
The 1LE cars get 3.90's from the factory....that should be close enough to 4.10's for those who want them.
http://i1217.photobucket.com/albums/dd383/FNBADAZ06/Tims%20house%20December%2016%202012/d07749d0-1009-4770-ade0-a7db069cd9b6_zps6eda1e16.jpg
slow a$$ Corvette
FNBADAZ06 is offline   Reply With Quote
Old 09-24-2012, 08:28 AM   #22
KD Innovations
Drives: 2012 ZL1, 2009 CTS-V
Originally Posted by 1st Gen Forever View Post
Not to sidestep but doesn't the ZL1 have 3.73 already? would 4.10 or 4.30 help much?
The manual does. The Auto has a 3.23.
A change is not really necessary when you can already pull 1.4X short times. First gear is very short and shifts in the mid 20 MPH area. The longer gear will then help up top.
KD Innovations is offline   Reply With Quote
Old 09-30-2012, 10:01 AM   #23
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
That may be close enough, but to have to buy them from GM would be a stupid price no doubt...
2012 ZL1
Old 08-17-2013, 12:40 AM   #24
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Actually I see the gear set from the 1LE (22813040) is only 291.00 which ain't too bad. Only gives a 5 percent increase in ratio though. 4.30 would be better.
2012 ZL1
Old 08-17-2013, 09:02 AM   #25
cam99
cam99's Avatar
Drives: 2012 ZL1
1le gears do not fit the zl1 carrier. The only way to alter final gear ratio at this point is changing rear tire diameter.
2012 CTF ZL1-stock
2012 ZL1 (sold)
JRE 75rwhp kit
catless
ported lsa TB
11.04 @ 128.35
on hoosier drs and skinnies
@ PRP with 1100DA
cam99 is offline   Reply With Quote
Old 08-18-2013, 11:41 PM   #26
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
Cam99 is right, the 1LE has a completely different rearend.
I see you are driving the manual. I have been told that the ring gear size is not the only difference in the ZL1 rears, the output shafts are different also or something like that. If you want the auto rearend ratios, you need the entire rearend from a auto car.
I asked about swapping rear-end gears when I first bought the ZL1 and was told that was not the way to go. You can swap a complete manual rear for the auto rear or vice versa but those are the only choices unless you go with a complete rear axel downgrade to the 1LE rear.
Right now my car is getting the manual transmission rebuilt an I'm getting different ratios and oversized gears for 5&6. 4th is fine at the dragstrip for me but I have more power. If you really want to change the ratios of 3 & 4 I'm pretty sure it is possible in the transmission and probably costs less than swapping the entire rearend.
Do you have drag radials on the car now? If your goal is lower ratios and you don't have wheels yet, get an 18" wheel and run the Mickey Thompson ET Street radial in size 315/30/R18. Tire will be 3 inches shorter than stock and give you about 11% less distance per tire revolution which should make a big difference of about 10 mph less speed in gears 3 and 4. Note, if you use about the same size tire on the front, the car will be real low. Get a front tire that is within 1" in height and you shouldn't have any problems with traction computer. My road racing tires are 2" shorter than stock and work great. If you are running stock tires you may gain 10 mph in the trap speed with a drag designed tire on the car.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
