Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > Engine | Exhaust | Bolt-On | Drivetrain Modifications
Old 08-11-2012, 02:07 PM   #29
joes407
joes407's Avatar
Drives: 2014 ZL1m6 red hot #569
Originally Posted by 2012ZL1 View Post
Yeah, Its looking as if this isn't easy to do without major sacrifices. I just don't understand how on earth this car weighs so much. It doen't make sense. Its not that big.
try parking 2 of them in a 2-car garage and then tell me again how they are not that big. when i had my 3rd gen sitting in the garage next to my SS it made the 3rd gen look like an MG
joes407 is offline   Reply With Quote
Old 08-12-2012, 12:34 PM   #30
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp
hmm I guess its decieving until you do a side by side, but to me 4000 lbs is more SUV weight than sportscar weight for this size of car.
2012 ZL1
2.55 upper, 10" lower pullies, Innovators west billet hub and sfi balancer, solid blower drive isolator, 50 mm idler kit, full length S/S headers no cats, comp cams custom grind cam, comp roller rocker trunion kit, comp push rods,dual valve springs retainers and locks, Injector dynamics ID850 inectors, Rotofab ZL1 cold air kit, Lingenfelter 160 thermostat, Rotofab intercooler reservoir, stock plugs, LS7 90mm throttle body, GTO clutch reservoir mod, my own custom catch can, Tuning by Jannetty, install by me.
2012ZL1 is offline   Reply With Quote
Old 09-10-2012, 09:32 PM   #31
b4z
Drives: '06 Pontiac GTO M6, '19 F150 2.7TT
zL1 wheels are forged and lighter than the regular Camaro 20"s.
b4z is offline   Reply With Quote
Old 09-11-2012, 10:48 PM   #32
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Have you taken one off and lifted it?,,,Its HEAVY.
2012 ZL1
Old 09-11-2012, 10:58 PM   #33
880
880's Avatar
Drives: 2011 Z06, 2004 Cobra, 1991 MR2Turbo
Easy and reversible (but not cheap)
Cut off mufflers
Drain out windshield wiper fluid
Battery
Wheel/tires
Lightweight seats
880 is offline   Reply With Quote
Old 09-19-2012, 03:57 PM   #34
toehead93
Drives: 2014 2SS/1LE
Originally Posted by coanbread23 View Post
Things you can do to drop weight without sacrifice of safety or comfort.
Battery -10 lbs
Exaust -30 lbs
Air box -5 lbs
Driveshaft -15 lbs
Flywheel -10lbs
CF hood -5 to 10lbs
CF trunk -5 lbs
Racing seats 25lbs per seat
K-Member -15lbs
I have seen differnet numbers on this site depending on brand.
Battery -19-29 lbs with Braille battery (2 versions)
Exaust -30 lbs (12 headers + 18 mufflers)
Air box -5 lbs (not sure)
Driveshaft -6 lbs, the stock weighs under 25lbs.
Flywheel -22lbs
CF hood -1lb with Seibon SF hood
CF trunk -5 lbs (not sure)
K-Member -15lbs
2-piece Brake Rotors - 9lbs each
Used Racing Brake 2 Peice Rotors for sale:
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 09-19-2012, 04:00 PM   #35
austinjames
Account Suspend...Right
austinjames's Avatar
Drives: Synergy LS & Vulcan 1600cc
exercise and then ull lose weight. I guarantee theres guys on here around 250-300lbs means I've got a 100+lb advantage just from the drivers weight.
austinjames is offline   Reply With Quote
Old 10-28-2012, 12:44 PM   #36
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Who sells a k-member for a ZL-1?
2012 ZL1
Old 10-29-2012, 05:37 PM   #37
KD Innovations
Drives: 2012 ZL1, 2009 CTS-V
Originally Posted by gmgdave View Post
I changed out the battery yesterday. Smaller, 5lbs lighter, and easy. The only issue was reprogramming the windows.
I found one 27 lbs lighter. Car sat for a month and started right up.
KD Innovations is offline   Reply With Quote
Old 11-03-2012, 03:09 PM   #38
hooded
Drives: 2012 Zl1 Camaro
Just got back for the scales and came in at 3920 (crub Weight), with the following mods:
Sparco Evo Front Seat Driver
Sparco Evo Front Seat Passenger
Rear Seat Delete Kit
Front and Rear Seat Belts Removed
Front Bumper Removed
Rear Bumper Removed
Windshield Washer Removed
Light Weight Battery
Trunk Cover/Carpet/Compressor Removed
Engine Cover Removed
Was trying to reach GT500 weight at 3852. but looks like its not going to happen. Tried my best. Only lost my heated seats and annoying check air bag message everytime I start up.
hooded is offline   Reply With Quote
Old 11-03-2012, 10:19 PM   #39
Doc
Dances With Mustangs
Doc's Avatar
Drives: 2010 1SS/RS MT
Rear Bumper Removed
Does the ZL1 use the same brake rotors as the SS? If it does, then you can save about another 24 lbs by upgrading to 2-piece rotors from Racing Brake. That's 24 lbs of unsprung rotational weight which you'll definitely appreciate being gone.
Blue Angel is here!!
1SS/RS LS3 M6 IBM
Doc is offline   Reply With Quote
Old 04-29-2013, 11:19 PM   #40
Mkur
Drives: LS3 429ci vette, camaro zl1, '77BMW
Rear Bumper Removed
I dont understand how you couldnt get below 3800 with those, I did a weight reduction for my vette last year and this is the list of weight reducing mods I would suggest:
- Sparco Carbonfiber Seats (-20 - chould be more savings for the Camaro)
- Braille Battery (-20)
- Delete Trunk and Rear Carpeting (-10)
- Delete Winshield Washer Tank (-5)
- Delete Engine Cover (-1)
- Remove Air compressor (roughly -5)
- Ti Lug Nuts and other Ti washers and bolts (-3)
- 19inch CCWs with hoosiers (roughly 30)
- Smaller Diameter Steering Wheel no airbag (depending on size of wheel 5 to 8lbs)
- Long tube headers with no cat xpipe (-20)
- CAI (never measured might be -4)
- Carbon Fiber Trunk (-10)
- Race the car with the least amount of gas the racing club/organization allows: Half tank for me.
Notice I didnt remove the rear seats as I thought that would be removing too much from the rear of the car, thus would upset the balance of the car.
A ZL1 like this will be 3900 lbs with a 100lbs driver I am sure, time to go find that driver
Mkur is offline   Reply With Quote
Old 04-30-2013, 08:21 AM   #41
THR ZL1 #1
Perma Grinning
Drives: 2012 Tom Henry Racing ZL1
Exclamation
Slightly different front rotor, rears are the same
Just did rotors . . weighed them myself.
Front rotor 27 lbs. RB floating 2 piece 22.5 lbs
Rear rotor 23 lbs. RB floating 2 piece 18 lbs.
Total loss . . 19 lbs.
THR ZL1 #1 is offline   Reply With Quote
Old 04-30-2013, 10:06 AM   #42
Doc
Doc's Avatar
Great place to lose 19 lbs.
Here's another idea; replacing the windows with racing polycarbonate. If you get the whole kit which replaces all the windows that should save about 100 lbs. Giving this a serious look myself:
http://www.opticarmorwindows.com/racecar.html
1SS/RS LS3 M6 IBM
