01-23-2015, 09:55 AM | #15 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
I know some of you guys are running other wheel and tire combos that I don't have listed in the post, so if you could share that would be great.
Some folks are running other fronts and rears that are for example 27.x tall. I believe Martin (62Nalide) is running 27.x Phoenix fronts. Tim Martin I know has some 27.x M/T's in back, not sure on fronts?
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
01-23-2015, 09:59 AM | #16 | |
Writer
I'd like someone who actually owns and runs this combo to post that they fit:
PROJECT HEAVY CHEVY
01-23-2015, 12:53 PM | #17 |
Drives: 2010 2SS/RS Join Date: Jan 2013
Yup John stock brembos up front , bump for sticky
01-23-2015, 09:43 PM | #18 |
Boosted Moderator
Lol, there is no need to bump it. It is a sticky, right at the top...
If the car feels like it is on rails, you are probably driving too slow. -Ross Bentley
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
01-23-2015, 10:34 PM | #19 |
ANGRY Z
Drives: 2015 Camaro ZL1 Join Date: May 2012
Hoosier also makes a skinny front 27.5/4.5R17
2015 ZL1 A6 396 stroker RWHP- depends on nitrous
01-23-2015, 10:49 PM | #20 |
Drives: 2013 SS Join Date: May 2013
Old set 17x5 with a 27" Phoenix fronts
17x12 with 275/45/17 M/Ts ET2 17x12 with Hoosier 28x10x17 New setup 17x4.5 M&H 28" 15x10 with 275/60/15 Pros Wheels are RTS
01-24-2015, 01:46 AM | #21 |
Drives: 2013 A6 GT 5.0 Join Date: Nov 2009
TSW Nurbugrigs (not sure on spelling) and Interlogos in a 18x8" Front 18x9.5" rear make pretty good drag wheels because of the price, ease of fitment and low weight. Best tire size to use for those is 305\45R18 rear with 225/60R18 or 235/55R18 front tires that weigh around 25lbs, low rolling resistance and H or higher rated.
BLK/BLK 1SS/RS Ordered 11-01-2009 Took delivery 12-22-2009. Heads/cam/converter/bolt ons. SOLD Feb 2015 to fund 6th gen LT1 SS with 8L90E.
01-24-2015, 06:22 AM | #22 |
www.1baddogracing.com
Drives: 2010 IOM 2SS/RS Auto Join Date: Apr 2011
John - My front tires are M&H radials 185/55/17. They are 26" tall. Personally, I would have preferred a 28" tire, but they were the only radial available at the time. They worked well on the street, but you need a lot of extra braking room with these tires.
2010 Camaro 2SS/RS Aqua Blue Metalllic (bolt-ons)
2020 Camaro 2SS/RS Satin Steel Metallic - Shock and Steel Edition 1 of 98 - A10 (bolt-ons) 2010 Camaro 2SS/RS IOM - 1,023 RWHP 813RWTQ (Previous Paxton Record Holder: 9.82@139) Built and Tuned by Heintz Racing Go: DSS 9", RPM Trans TH400, Carlyle Racing 15" Conversion, ECS Vortech YSI-B, Fore Fuel System, ID1700, Gall Racing 427 C.I LSX, Mast 285CC Heads, HR Custom Cam Show: Custom Painted Stripes/Badges (Orange Pearl over White), Z/TA Spoiler, VFN Hood, Weld Wheels http://www.HeintzRacing.com http://www.youtube.com/user/1baddogracing |
01-24-2015, 06:27 AM | #23 |
Weld makes a 15" RT-S wheel that will work with the 15" conversions that are available. Beadlocks are available on the 15" wheel.
Also, 17" Alumastars will work on the front with a spacer and longer studs.
01-24-2015, 06:37 AM | #24 |
The new MT ET Street R is available:
17": 305/45/17 and is 28X12.5 18": 305/45R18 and is 29X12.5
01-26-2015, 09:20 PM | #25 | ||
Be careful when buying these because they do make a 57 offset that does not work without a spacer. |
01-27-2015, 10:38 AM | #26 |
Writer
Thanks Mike!
PROJECT HEAVY CHEVY
01-27-2015, 11:00 AM | #27 |
Thank you for starting this thread.
Was waaayyy overdue |
01-27-2015, 11:02 AM | #28 |
Writer
Thanks I did not know this, adding to the sticky!
PROJECT HEAVY CHEVY
