Roto-Fab
Old 10-08-2018, 08:15 PM   #29
schul274
Drives: 2011 Camaro SS2RS, 1970 Camaro SS
Originally Posted by eLeSthree View Post
Love the band aid and the black X over 6.0. lmao
Which crank/rod/piston did you use?
i bought a full rotating assembly out of a lsx376 b15. got a great deal on it. so its like a beefed up lsa. Forged pistons, rods, and crank.
it may not look like it, but this was a budget build.
schul274 is offline   Reply With Quote
Old 10-23-2018, 09:41 PM   #30
schul274
Car is back at the shop. Trans issues pulled it off the dyno the first time. Made 565 in 2nd unlocked extra save (extra fuel, no timing).
Took it home. Had the 1-2 and 3-4 solenoids wired backwards. Trans is much happier now.
So hoping for bigger numbers, then switching to E and turning it up.
Old 10-26-2018, 07:27 PM   #31
schul274
So, good news and bad news.
made 1000 HP barely. Turbo ran out of steam. couldn't make any more boost.
Made the pull below with the converter locked up. without smoothing it made 1000, 9xx with the smoothing on.
on the next pull the trans let go. so the car will be back down.
Old 10-26-2018, 07:33 PM   #32
RealQuick
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust
Congrats!
RealQuick is offline   Reply With Quote
Old 10-26-2018, 07:35 PM   #33
Scuzz
Scuzz's Avatar
Drives: 2012 Camaro SS
Your 4l80 gave out on the dyno......
Was this like a stock 4l80?
2012 Camaro SS Automatic
AGP Twin Turbo LSX427 / ADM Magic / 4L80
“1360 Rwhp 1225 Rwtq 25 lbs of boost”
Scuzz is offline   Reply With Quote
Old 10-26-2018, 07:58 PM   #34
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
1000 through an auto is making some power, congrats!
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 10-26-2018, 08:46 PM   #35
schul274
Yes. stock 4l80 with 200k miles on and an HD2 shift kit. no idea why it blew.
Old 10-26-2018, 08:48 PM   #36
schul274
Old 11-04-2018, 01:07 PM   #37
schul274
Trans issue has been identified. Sheared the torque converter bolts.
Going to try to just drill the bolts out and put in a size larger.
Old 11-04-2018, 04:40 PM   #38
RealQuick
WTF? How does that happen?
Old 11-06-2018, 08:58 PM   #39
dookie454
Drives: 2010 Camaro 2SS LS3
I ballooned a converter then it ripped the mounts out of the converter - fluid spraying everywhere (bolts did not shear off) with only 550hp... the next converter had a metal ring connecting all of the mounting holes. This is impressive. Nice work!
dookie454 is offline   Reply With Quote
Old 11-11-2018, 11:48 PM   #40
schul274
I do not know exactly how it happened. Bolts were tight and had red loctite on them, so I don't think they loosened up.
They were not high quality bolts (I had ordered ARP, but they were the wrong size).
just going to drill them out and use ARP 7/16ths in bolts.
Old 11-12-2018, 03:53 AM   #41
1fast
8.60 @ 157 @ 4200lbs
1fast's Avatar
Drives: 2010 Gen 5
Props on the build their is more sweat and blood in the build the most realize
1fast is offline   Reply With Quote
Old 11-19-2018, 08:14 AM   #42
schul274
More photos of the carnage. Got a "new" trans and got the bits of bolts out of the converter this weekend. Moral of the story, don't use oriely's brand bolts in your converter and then forget to replace them with ARP.
1000hp, 4l80e, engine swap, on3performance, turbo
