dave@hennessey
Old 05-19-2017, 12:02 AM   #1
427K
427K's Avatar
Drives: 15 1SS 1LE
Goodyear F1 Tires
Hello Fellows ,
At approximately how many miles can you get out of the Goodyear F1 tires?
Currently my 1 LE has 17,809 miles with the stock tires. This is my first time having Z rated tire and I am not really sure if at what tread reading I should replace my tire. I usually changed my L rated tire between 2-3, and I am not sure for these Z rated should be change at that same rating.
Based on the tire reading, there is some positive Camber on both front and rear. Tires look good overall, but like I said I am not sure, if there ok. Do Camaro's need rear wheel alignment?
Any advice from previous experiences will be really appreciated.
Tread reading:
Tire outer Center Inner
DR 3/32 6/32 7/32
PR 3/32 6/32 7/32
DF 4/32 7/32 7/32
PF 4/32 7/32 7/32
Saludos,
I spent most of my money on beer and cars, the rest I just wasted.
427K is offline   Reply With Quote
Old 05-19-2017, 12:59 AM   #2
Superman09
Account SNAFU
Superman09's Avatar
Drives: 13 Tahoe 79 Scout II 15 1LE
I am averaging 9k miles on my rears and about 12 on the fronts. That said your tread wear looks really really good. I have bought used tires with less tread and run them
Sent from my VS995 using Tapatalk
Superman09 is offline   Reply With Quote
Old 05-19-2017, 07:30 AM   #3
Billy10mm
Billy10mm's Avatar
Drives: 2014 Camaro 2SS 1LE NPP
The speed rating has little to nothing to do with wear. Treadwear rating (220 on these) will give you an indication of how long they'll last, but how far you run them down is up to you. I've seen F1s run down literally to the point where they look like slicks. The person that owned that car only used it at the track (dry conditions) and had the alignment perfect, so there was no cord showing anywhere. But I daily my 1LE and my wife and kids are passengers in the car every single day, so I change them early.
In other words, quite literally, your mileage may vary.
P.S. it's "camber" not "Cambridge" and "alignment" not "aliment".
My thoughts on some things:
  • Driving Nannies: If I'm that far out of shape on the street, something has gone terribly wrong and by all means Mr. Computer man, come and get me.
  • G2s: Rock throwing is like like a tramp stamp; although problematic, it's a sign of good things to come.
Billy10mm is offline   Reply With Quote
Old 05-19-2017, 11:38 AM   #4
RyanR3KC
"1/LE Rebel Alliance"
RyanR3KC's Avatar
Drives: 18 Black 1SS 1LE “Siouxsie
I got 17000+ miles on my GYs and I track my car a couple times a year.
RyanR3KC is offline   Reply With Quote
Old 05-20-2017, 04:44 PM   #5
ecreps
Drives: 2014 1LE, 1996 z28
I got 23k out of the stock tires. Rears were probably 1/32 at that point.
ecreps is offline   Reply With Quote
Old 05-20-2017, 10:22 PM   #6
cabbe
Drives: 2014 2ss 1le
I'm at 22100, but the tires are done at this point.
cabbe is offline   Reply With Quote
Old 05-20-2017, 11:20 PM   #7
toehead93
Drives: 2014 2SS/1LE
How the hell do you get more than 12k? Two sets, both 12,000 miles. How are the new G3 tires for longevity and grip? Any rumors when sizes for our car with proper load ratings will be available ?
Used Racing Brake 2 Peice Rotors for sale:
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 05-21-2017, 04:59 PM   #8
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
I get 8k max outta em...bald and dangerous after that
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
Old 05-22-2017, 11:39 AM   #9
Camaro Dude
Camaro Dude's Avatar
Drives: ‘13 1LE
My rear F1 G:2's were very close(almost flush) to the treadwear indicators @ 15000km.
You'll have to covert to miles.
Camaro Dude is offline   Reply With Quote
Old 05-22-2017, 11:43 AM   #10
427K
427K's Avatar
Drives: 15 1SS 1LE
9K with normal driving? Anyway think for your input.
Old 05-22-2017, 11:48 AM   #11
427K
427K's Avatar
Drives: 15 1SS 1LE
I thought the speed rating had everything to do, but I will do research more on this. Coming from LT tires, there is not that much to worry about.
Thanks for catching those missed used words.
Old 05-22-2017, 11:49 AM   #12
427K
427K's Avatar
Drives: 15 1SS 1LE
[QUOTE=ecreps;9736161]I got 23k out of the stock tires. Rears were probably 1/32 at that point.[/QUO
You must had have a good alignment, to reach those number.. Thanks for the input.
Old 05-22-2017, 11:55 AM   #13
427K
427K's Avatar
Drives: 15 1SS 1LE
Dude, that about 9400 miles. That about what some of the guys are running at... So anything above 10k miles (16,100 KM) your above averaged.
Old 05-22-2017, 11:59 AM   #14
Camaro Dude
Drives: ‘13 1LE
Yup, and bare in mind, I never did a smoke show either, but......
