Old 03-26-2017, 01:15 AM   #15
RealQuick
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust
If it is not too late I would step up to ID1000 injectors.
RealQuick is offline   Reply With Quote
Old 03-27-2017, 04:32 AM   #16
racesloth
Dan
Drives: 2010 Camaro 2SS IOM
I started hand porting the LSA heads last night. I am not looking to make gains near a CNC port, just a good clean up (remove rocker stud buldge, swirl dam, soften chamber, polish and port match. Stock LSA heads flow 290cfm at .600 lift and stock LS3 are around 310cfm at the same lift. So it I can get the homeported LSA heads to 320-330 I will call it a day. Putting the LSA heads on just to take advange of the stronger casting and use higher quality valvetrain parts.
I will let the YSi push the air through...
Dan
2010 IOM SS
YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust
http://www.camaro5.com/forums/showth...&highlight=ysi
racesloth is offline   Reply With Quote
Old 03-27-2017, 10:14 AM   #17
racesloth
Dan
Steped up to ID1050X injectors...
Dan
2010 IOM SS
Old 03-27-2017, 10:31 PM   #18
RealQuick
Good move!
Old 03-28-2017, 02:31 AM   #19
racesloth
Dan
and it was only $126 more...
Dan
2010 IOM SS
Old 04-04-2017, 04:38 AM   #20
racesloth
Dan
Meth kit is ordered.
Great working with Rodney at PROMETH. The Camaro stage II kit with stainless hard and soft lines, and progressive controller is on its way.
Dan
2010 IOM SS
Old 04-14-2017, 07:32 AM   #21
Dirtdog
Pro Hide n Seek Player
Dirtdog's Avatar
Drives: 2010 SS LS3/LSA 620whp/630tq
Send a message via AIM to Dirtdog
def great move. now you can handle e85!
620whp/630wtq. ADM LSA Conversion, E85, PFADT Tri-Y Headers into Borla S, PFADT Swaybars, Springs, Links, 20x10 20x11 Forgestar F14s, Lots of AAC
Dirtdog is offline   Reply With Quote
Old 04-17-2017, 05:54 PM   #22
SarGar
Drives: '13 BRM ZL1
OP - are you happy with the ID1050x? Wasn't sure what the main difference was from the 1000's.
SarGar is offline   Reply With Quote
Old 04-18-2017, 03:31 AM   #23
racesloth
Dan
Not happy yet - don't have anything yet....waiting...
From what I understang the 1000's are taller...
Dan
2010 IOM SS
Old 04-18-2017, 07:34 AM   #24
jeff657756
Drives: 2014 SS 1LE
I have 1050x and they are fine. The ID1000s are not a direct fit and are taller.
jeff657756 is offline   Reply With Quote
Old 04-21-2017, 05:55 AM   #25
racesloth
Dan
My YSi and supporting parts are in and supposed to ship today!
Dan
2010 IOM SS
Old 05-08-2017, 04:46 AM   #26
racesloth
Dan
All YSi components have arrived....
RGS Motorsports in Wellingborough UK had a little get together of sorts on Sat. I wanted to put my Camaro up on the dyno before I start taking it apart to install the new cam and supercharger. It laid down 495rwhp at 6000rpms on a Dyno Dynamics dyno which I think is reading a bit high. More realistic is probably 475rwhp but that is just by comparing it to other Camaros on the site with similar mods....
I have a car event coming up on June 11 (American Speedfest) and I know if I start taking it apart I probably won't have everything and the tune worked out between now and then. So I will start on the mods after the 11th...
Gone this weekend to watch the F1 race in Barcelona - it should be a spectacle....
Dan
2010 IOM SS
Old 05-08-2017, 06:35 AM   #27
Bo White
Bo White's Avatar
Drives: 2015 Summit White 2SS 1LE
Life starts at 3.47" pulley.....
Bo White is offline   Reply With Quote
Old 05-08-2017, 08:55 AM   #28
racesloth
Dan
Jannetty was predicting 10lbs of boost with 3.60 upper and 7.8 lower..
How would 3.47 or 3.33 work out to boostwise? I would really like to get to a bit over 700 on my stock bottom end. The preminum pump gas here is 94 octane and I can get 25 liters 100% pure meth for $39.
Dan
2010 IOM SS
cam, id850, twin disc, whipple
